greenterbo Samba Member
Joined: August 04, 2007 Posts: 49 Location: Chandler, AZ, USA
Posted: Sat Apr 01, 2017 12:15 pm Post subject: Question - seat interchangeabe |
What years of seats are interchangeable? Will 71 seats fit in a 69? |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8852 Location: Sunset, Louisiana
Posted: Sat Apr 01, 2017 12:45 pm Post subject: Re: Question - seat interchangeabe |
Seat tracks changed for '71-72 model year, and while the seats will fit onto an older track, they will wobble and not work well. If you can weld, you can install the later sliders in your older car.
The short answer is no, 1971 seats will not work properly in a 1969.
Also, seats mounts changed again for the 1973 model year. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sat Apr 01, 2017 12:47 pm Post subject: Re: Question - seat interchangeabe |
Great thank you |
Horance Samba Member
Posted: Sat Sep 30, 2017 8:30 pm Post subject: Re: Question - seat interchangeabe |
I was at my local bone yard this morning and saw some 92 golf seats the bottom tracks look like my 73 beetle seats does any one know how far forward the seat track design goes for after 73?
i would like these seats if they would fit. |
Rome Samba Member
Joined: June 02, 2004 Posts: 10585 Location: Pearl River, NY
Posted: Sat Sep 30, 2017 8:48 pm Post subject: Re: Question - seat interchangeabe |
The '73 style Beetle seat tracks went all the way to the end of US Beetle production for the '79 model year (which would've been a SuperBeetle cabriolet). Although the style appears similar to a '75 and later Rabbit/Golf, the vertical C shaped tracks themselves are spaced slightly wider apart on those cars. To make a seat from the Rabbit/Golf fit a Beetle, the down-arms need to be repositioned slightly closer together via welding. I think only one of the down-arms needs to be repositioned. You "can" bend one of the arms inward slightly to reduce the spacing, but that also brings the outer arm faces out of vertical on which the plastic slider spacers are positioned into the seat tracks. Not ideal on such an important safety item. |
