SBL74 Samba Member
Joined: November 25, 2013 Posts: 125 Location: Treasure Island, FL
Posted: Sun Jan 21, 2018 5:13 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
I have a 1973 Campmobile, and my problem is that the door needs extra oomph at the very end of closing, by pushing "in" with your left hand placed on the left side of the door, while sliding the door it forward with your right hand at the handle.
It opens easily, and rides on the track effortlessly. If I use the left hand method, it closes ok most of the time. If I don't, it closes but it is not flush, which is best seen on the left side.
I think it may be this piece of weatherstripping at the bottom, that gets caught in the seam.
The test would be to cut it out (?) or someway reposition it (it is glued in very well). And if I am wrong, then I have messed up that seal, although it is not right anyway.
Any suggestions?
steve |
SBL74 Samba Member
Posted: Sun Jan 21, 2018 6:35 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ - closing |
Well, I taped that weatherstripping back, and it is well interior now, and the door still behaves as described. Basically the front of the door goes in, but about 1/2 inch of the back (left as you look at it) does not unless you use the technique and more muscle that I think should be necessary. Is this an alignment issue? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52883 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 21, 2018 6:41 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
That seal definitely has some issues and likely isn't helping with the final latching of the rear striker. But in case you aren't aware a 73 slider requires you to turn the handle fully upwards (back on the inside) until it clicks to draw in and latch the rear of the door, even if it has the correct seal.
Sometimes on a summer day when the seals are really soft and all the windows are open you can get the rear to latch with just a good slam, but in most cases it needs a handle turn to finish the job. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SBL74 Samba Member
Posted: Sun Jan 21, 2018 10:31 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
Bus daddy,
I DID NOT know that. Easy enough to check tomorrow. Thank you.
steve |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5838 Location: Wamego, Kansas, USA
SBL74 Samba Member
Posted: Mon Jan 22, 2018 9:15 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
I am amazed. I tried it. The door closes at the front with very little effort, and then you pull up the leaver and the back end of the door pulls in flush.
Thank you.
steve |
markd89 Samba Member
Joined: November 04, 2005 Posts: 674 Location: Los Angeles
Posted: Sat Jul 27, 2019 8:24 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
The rear of my sliding door no longer pops out away from the bus when the door is opened. This just started happening.
I have been a bad bus owner and haven't lubed it recently, but as there is no hint of springiness where there was some last week, I'm thinking that the long spring or something else has broken.
Anyone have this happen? What was the cause?
Thanks,
Mark
78 Bus |
Antigrav Samba Member
Posted: Sat Aug 03, 2019 4:40 am Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
markd89 wrote: |
Thanks,
Mark
78 Bus |
This happened to mine recently. U piece was broken. Later busses are easy to get replacement. Earlier buses with bushings are not  |
cellobus1 Samba Member
Joined: June 10, 2014 Posts: 287 Location: East Tennessee
Posted: Sun Aug 18, 2019 7:19 pm Post subject: Re: Sliding Door Hinge Assy Refresh |
aeromech wrote: |
On my 1971 the latch that's supposed to hold the door open has a broken spring. In the past I've purchased the whole assembly but this time I'd like to ask if anyone knows of a replacement spring?
Hey, Aeromech, I just posted something about this, my spring is missing also. The rear catch still works if you use some force. I know the lever on the body is supposed to be spring-loaded, but I'm having trouble picturing where the spring is mounted and "springs" from, and what direction the pressure should be. The photo doesn't have much clarity about that. Is there a thread for using a clothespin spring? It looks very similar. _________________ 1976 unrestored daily driver Standard bus, "Stella"
formerly, 1959 Standard bus
formerly, 1973 transporter which was 4 years old when it taught me to drive |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6541 Location: East Bay, CA
Posted: Mon Jan 11, 2021 4:26 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
I'd originally started following this thread because I knew I was going to have to swap out my nylon block. Turned out my entire roller unit was broken and needed replacing. This thread was invaluable. Thanks so much! _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
61Ragster Samba Member
Joined: February 04, 2008 Posts: 264 Location: southern Orange Co., CA
Posted: Wed Apr 07, 2021 12:31 pm Post subject: Re: Sliding Door Hinge Assy Refresh |
(Photo from above, by cdennisg. Thank you, cdennisg)
Has anyone replaced this failed (assumed bronze) bushing or found an acceptable work-around?
SLVRSRFR Samba Member
Joined: October 02, 2008 Posts: 154 Location: Guelph, On, CANADA
Posted: Wed Apr 07, 2021 12:35 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
https://www.busdepot.com/j18875 _________________ Brian
'78 westy, '64 sedan |
Posted: Wed Apr 07, 2021 12:46 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
Perfect! Thank you SLVRSRFR.
Have you or anyone else had the pleasure of performing this sort of corrective maintence? Easy? Difficult? A press fit? Freeze the bushing and heat the door-actuating-spring mounting case? Any special tools required? Just wanted to ask, and maybe avoid any surprises. |
Posted: Wed Apr 07, 2021 1:20 pm Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
I had no problems just tapping them out from the other side with a brass drift...
If I remember right they were not too tight in there.
And because I love the before and after shots - here is mine...!
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13530 Location: West Coast, USA
Posted: Fri Apr 09, 2021 12:16 am Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
Now THAT needs filtering from forum users at work! Do I smell zinc? 🙃
I hope your door rolls as well as it looks,
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Fri Apr 09, 2021 11:14 am Post subject: Re: Sliding Door Hinge Assy Refresh FAQ |
For the first time in 20 years I have a sliding door that people other than myself can operate (without the very likely possibility of it falling off) - it is a think of beauty! _________________ Brian
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2731 Location: Gullane, Scotland
