Kramer79 Samba Member
Joined: December 21, 2017 Posts: 29 Location: Connecticut
Posted: Sat Aug 11, 2018 10:16 am Post subject: Wiring Question |
Hi quick wiring question,
In the picture the one black wire is not connected... I am assuming I just put it on the empty clip.... just wanted to make sure. I know the green is for the wipers, but horn lights etc all work and the wiring diagram was not too clear, maybe a gauge light??
Thanks!! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53035 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Aug 11, 2018 10:20 am Post subject: Re: Wiring Question |
Kramer79 wrote: |
... I am assuming I just put it on the empty clip.... |
Danger, once you let the smoke out it won't go back in.
How about letting us know what year your car is?, or looking the appropriate diagram yourself.
Bet your brake lights don't work  _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat Aug 11, 2018 10:31 am Post subject: Re: Wiring Question |
On other cars there are empty spots to get power from because the fuse box is made for many vehicles. There could be a connector missing to attach one wire to another , etcetera.
You're better off looking at fuse locations and see what is supposed to get power from that spot. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Sat Aug 11, 2018 10:32 am Post subject: Re: Wiring Question |
71 Niagra Blue bug with two decklids.
Just kidding, 69 bug, just didn’t want to put it on the wrong clip, there are two with no wire on it. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3999 Location: Antioch, California, a block from the hood
Posted: Sat Aug 11, 2018 11:27 am Post subject: Re: Wiring Question |
Thanks,
That is what I thought but the second from the right only has one clip and the last one has two. One for wiper motor and one for the brake lights.... they look to be both switched on with the ignition so I think I will go green second from right and black last... fuses show horn/wiper on the last two blocks...maybe it does not matter if they bothe get power... brake lights work off either one, wiper motor looks shot so that will be next project. And yeah thanks have to replace some clips... |
vwoldbug Samba Member
Posted: Sat Aug 11, 2018 11:37 am Post subject: Re: Wiring Question |
Good catch on the white ( headlight ) wire . Also looking down to the right is the black & black with yellow stripe unhooked from the first connector . |
Posted: Sat Aug 11, 2018 12:32 pm Post subject: Re: Wiring Question |
See that one is connected... there is a blank below that... splits into two... I’m thinking brake below that? |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16685 Location: North Florida, USA
Posted: Mon Aug 13, 2018 6:22 am Post subject: Re: Wiring Question |
The green wire that runs to the wiper switch is the single largest load of all the wires powered from the ignition switched circuit. So if you have to choose just one devices to be powered by its own fuse it should be the wipers. Everything else can be powered from a single 8A fuse. The load of the turn signals + brake lights + horn are still below the limit for an 8A fuse... and the likely hood of all three being ON at the same time is small.
You should also consider which device is most important to driving. You don't want the wipers compromised in a storm because they were connected to the same fuse as the horn and brakes and one of them blew the fuse. Taking out your wipers AND brake lights in a storm. Separating them with different fuses is best. _________________ AshMan40
