LAGrunthaner  Samba Member
Joined: March 18, 2007 Posts: 5647 Location: 1st Coast
Posted: Wed Aug 22, 2018 7:23 pm Post subject: Battery strap too short. |
Perhaps with newer batteries taller is the reason my WW battery strap won't reach by almost 3 inches. What are some of the solutions to extend it besides designing a longer bolt down hole? Or perhaps I ordered/was sent the wrong strap? this is for 12 volt 67 bus. I see nothing in my search. _________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
| Lind wrote: |
| Have you considered simply starting with a nicer bus? I don't know what your skills are, but the race is easier if you can see the finish line. If you are not a runner, don't start off doing a marathon. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71896 Location: Phoenix 602
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15452 Location: Casa de Oro, California
Posted: Thu Aug 23, 2018 11:47 am Post subject: Re: Battery strap too short. |
And, although not necessary to bolt it, part 84 is a special bolt that cuts through the rust and acid muck if.
Posted: Thu Aug 23, 2018 4:56 pm Post subject: Re: Battery strap too short. |
Why is that bolt so long it only goes through sheet metal unless I'm getting all this wrong.
| BarryL wrote: |
Maui Roadsters
| Lind wrote: |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2087 Location: M*ssholia
Posted: Thu Aug 23, 2018 5:07 pm Post subject: Re: Battery strap too short. |
| Post a picture of your battery tray |
Joined: January 01, 2007 Posts: 17945 Location: sticksville, ct.
Posted: Thu Aug 23, 2018 5:13 pm Post subject: Re: Battery strap too short. |
| LAGrunthaner wrote: |
| Why is that bolt so long it only goes through sheet metal unless I'm getting all this wrong. |
because the captive nut that the bolt threads into is on a bit of an angle, on a V shaped plate of sorts. that, and it helps with variances in battery casing thickness. the battery tray should also have a C shaped channel for the battery to slide in and the clamp pinches the whole mess together _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
BarryL  Samba Member
Posted: Thu Aug 23, 2018 6:46 pm Post subject: Re: Battery strap too short. |
| BarryL wrote: |
The bracket is upside down and backward (sorry) and missing the lock washer. See Everett's diagram. |
Posted: Fri Aug 24, 2018 3:32 am Post subject: Re: Battery strap too short. |
The tray I bought was for a pre 67 bus probably 66 which has the loop for a traditional strap, 10 years ago I was a novice about a lot of bus information. I am not replacing that metal battery tray, well not in the near future anyway.
Therefore knowing that how is it that the strap is too short and what are people doing as an easy fix? I thought of taking hollow tubing and longer bolt for the opposite side so the hook can reach and yes I can always drill another hole and buy an aftermarket hold down battery bracket. I can't imagine I am the only one with this problem. I'll get a photo today. _________________ American Red Cross Safe And Well:
Maui Roadsters
| Lind wrote: |
Joined: August 31, 2013 Posts: 13354 Location: North Carolina
Posted: Fri Aug 24, 2018 7:09 am Post subject: Re: Battery strap too short. |
Not in a Bus but since I was driving the car off-road, the original clamp was not enough to keep the battery in place so I made a bracket to secure it out of a section of angle iron & threaded rod.
_________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2598 Location: UK (South)
Posted: Fri Aug 24, 2018 9:24 am Post subject: Re: Battery strap too short. |
| The tray I bought was for a pre 67 bus probably 66 which has the loop for a traditional strap |
| short and what are people doing as an easy fix? |
Don't thread the nut all the way down on the captive bolt on the tray.
The threads lower down on my bolt are ruined, so I can only thread the nut down half an inch or so. That leaves the strap loose over the 12V Bosch battery that I have in my truck.
I have to put a length of 2x4 on top of the battery to increase the height so I can clamp it down firmly. That also keeps the strap clear of the terminals so I don't risk shorting to the body (12V battery covers are like rocking horse poo). It's also the block of wood that I use on my trolley jack. I cut a notch cut in it to clear the center pin if I'm lifting by the front beam. Using it on the battery means I always know where that special block of wood it is, and it reminds me to disconnect the battery (usually ) when I'm working on the truck. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sun Sep 02, 2018 6:23 pm Post subject: Re: Battery strap too short. |
Thanks Who.Me?, I would like to use the 66 strap being I bought it, although I like what you designed. Back to the drawing board.
| Who.Me? wrote: |
I have to put a length of 2x4 on top of the battery to increase the height so I can clamp it down firmly. That also keeps the strap clear of the terminals so I don't risk shorting to the body (12V battery covers are like rocking horse poo). It's also the block of wood that I use on my trolley jack. I cut a notch cut in it to clear the center pin if I'm lifting by the front beam. Using it on the battery means I always know where that special block of wood it is, and it reminds me to disconnect the battery (usually ) when I'm working on the truck. |
Maui Roadsters
| Lind wrote: |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Mon Sep 03, 2018 8:23 am Post subject: Re: Battery strap too short. |
I’ve fixed this two ways:
1(easiest)- use a coupling nut and a small piece of all thread or cut off bolt to lengthen stud.
2- you can use the end of an old gas tank strap to cut and weld the battery strap to the correct length. Cut it so the seam isn’t seen behind the battery. _________________ Tim |
Posted: Mon Sep 03, 2018 9:35 am Post subject: Re: Battery strap too short. |
OMG Krustybus I just realized you are 100% correct with your solution, threaded rod or even longer bolt either way that would be an easy fix which I will try. Thanks
| Krustybus wrote: |
2- you can use the end of an old gas tank strap to cut and weld the battery strap to the correct length. Cut it so the seam isn’t seen behind the battery. |
No, Who.Me? it's not a half strap but interesting either way. What I would like to know is why the strap will not go over my 12 volt battery, I will assume 12 volt batteries are higher than the 6 volt. Is this correct? If this is so what do owners of pre 67 with straps do when they switch over to the 12 volt system? I like Krustybus's idea. Pictures to follow.
Maui Roadsters
| Lind wrote: |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26270 Location: Olympia Wash Rinse & Repeat
Posted: Mon Sep 03, 2018 10:34 am Post subject: Re: Battery strap too short. |
If you can get a battery box that fits pretty closely to the L/R side of the battery, it is a good investment to get a box. Keeps the battery acid that the batteries tend to sweat out of the top, from getting to the body work and causing more rust. _________________ In Stereo, Where Available! |
Posted: Mon Sep 03, 2018 10:45 am Post subject: Re: Battery strap too short. |
| I will assume 12 volt batteries are higher than the 6 volt. Is this correct? |
Battery choice may the problem.
I googled the battery in TDCTDI's picture above. Walmart's website says it's 8.9 inches high and 6.9 wide (226mm x 175mm).
I'm using a Bosch S3 065 battery that is 175mm high x 175mm wide.
A strap would need to be 100mm longer (about 4 inches) to go up and over TDCTDI's battery than the Bosch. _________________ Andy
BarryL  Samba Member
Posted: Mon Sep 03, 2018 12:16 pm Post subject: Re: Battery strap too short. |
| OMG Krustybus I just realized you are 100% correct with your solution, threaded rod or even longer bolt either way that would be an easy fix which I will try. Thanks |
| Krustybus wrote: |
1(easiest)- use a coupling nut and a small piece of all thread or cut off bolt to lengthen stud. |
You put the "all nut" onto the existing stud then go up from there with the "all thread" , which I'm sure you got that.
| What I would like to know is why the strap will not go over my 12 volt battery, I will assume 12 volt batteries are higher than the 6 volt. Is this correct? If this is so what do owners of pre 67 with straps do when they switch over to the 12 volt system? |
Depends on how tall your battery is and it should have a cover. 6 volts had a cover that actually had a place for the strap to lay on. |
suebug Samba Member
Joined: April 13, 2006 Posts: 1152 Location: The OC, SoCal, with my olympic cats
Posted: Mon Sep 03, 2018 8:26 pm Post subject: Re: Battery strap too short. |
Linda, here is my setup in my '66 bus converted to 12 volt. Tall battery like a 6 volt but it is a 12 volt with cutouts in the battery cover.
_________________ '67 Beetle
'67 Squareback
'66 Sundial
'60 Single cab
'70 Bitchen 3-speed Schwinn |
perello Samba Member
Joined: April 15, 2005 Posts: 902 Location: where social security comes for free
Posted: Tue Sep 04, 2018 1:13 am Post subject: Re: Battery strap too short. |
Fits perfect with a 12V optima
_________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
suebug Samba Member
