judson supercharger choke cable???
59sweetrag
59sweetrag is offline
PostPosted: Sat Jun 25, 2005 2:13 pm    Post subject: judson supercharger choke cable??? Reply with quote
i have a 59 with a cable that runs to a knob on the lower right side of my dash ( looks factory) the car had no motor when i purchased it. Is that the choke cable for a judson supercharger?? if not what is it ????
View user's profile Send private message MSN Messenger Classifieds Feedback
RareAir
RareAir is offline
PostPosted: Sat Jun 25, 2005 2:27 pm    Post subject: Reply with quote
It is a choke cable, but for the stock 36hp motor. What makes you think it was installed primarily for a Judson?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
coolairX2
coolairX2 is offline
PostPosted: Sat Jun 25, 2005 6:08 pm    Post subject: Judson choke cables Reply with quote
Cars with Judson's use the same choke cable but the routing through the fan shroud has to be changed. Also the original Judson kit had a extender cable so that the normal cable would reach the new location of the carb.
Other than that the choke cables are the same.
-Craig
Steve22
Steve22 is offline
PostPosted: Sat Jun 25, 2005 8:41 pm    Post subject: Re: Judson choke cables Reply with quote
-Craig
I don't remember seeing a choke cable listed with any VW Judsons or on George Folchi's or Alejandro Martin's parts lists either... educate me please, where did you get this info?
'65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter
coolairX2
PostPosted: Sun Jun 26, 2005 4:34 am    Post subject: Choke cable Reply with quote
I had George Folchi do some work on my Judson that I installed in my 58 Ghia. In talking with him he mentioned that cable extender. I have also seen pictures of an NOS Judson kit that had this piece. It is not a complete cable only a 4 inch section of cable which is easily sourced. If you don't have it the stock cable will be short by that amount because of the reroute.
-Craig
1958ghia
1958ghia is offline
PostPosted: Tue Jun 28, 2005 12:15 pm    Post subject: Reply with quote
Craig,
I was able to re-route the stock choke cable on my ghia to make it work. I didnt route it through the stock hole in the front engine tin, just between the rubber and tin. Then I was able to slide the choke cable further to the driver's side where the choke cable was re-drilled through the fan shroud... It was actually the exact right length... Works great too!
Kyle
