67' Dual Carb Idle Too High
Jeff67sqbk
Jeff67sqbk is offline
PostPosted: Tue Sep 18, 2018 7:58 am    Post subject: 67' Dual Carb Idle Too High Reply with quote
'67 Sqbk, stock dual Solex carbs. Just rebuilt motor (by AVP).
Set carbs at the defaults, 1/2 turn idle, 1 1/2 turn mixture screws.
Idles at about 900 RPM.
Checking carb flow with Unisyn reveals that left carb flow significantly more than right.
Adjusted left carb as low as it can go (then adjust mixture) still 900 RPMs.
Can adjust right carb (then adjust mixture) to match left flow brings idle to 1100 RPM.
Not sure what to change or adjust now to get idle lower.
Jeff '67 Sqbk stock
Nevada City, CA
sqbk1971
sqbk1971 is offline
PostPosted: Tue Sep 18, 2018 10:24 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
I had similar issue after rebuild. Have you tested for vacuum leaks around manifold and head. I found that the shape of my manifolds did not seal well with generic metal gaskets that comes in a standard engine rebuild kit.
Bobnotch
Bobnotch is offline
PostPosted: Wed Sep 19, 2018 8:59 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Jeff '67 Sqbk stock
Nevada City, CA
You might want to have a look at this thread.
https://www.thesamba.com/vw/archives/manuals/t3dualcarbtuning/index.php
It goes into detail about dialing in the carbs. It might also help you find your problem.
Also, never use the metal gaskets for the intake manifolds commonly found in the standard "complete" gasket kits. This is mostly because they don't seal very well, and have a tendency to loosen up with time (causing leaks). They also transfer heat into the intake manifold.
I hope this helps.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
DQDan
DQDan is offline
PostPosted: Wed Sep 19, 2018 4:00 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
"Also, never use the metal gaskets for the intake manifolds commonly found in the standard "complete" gasket kits."
I'm getting ready to bolt up two 32PDSIT's on my 66 build and was going to use those metal crush washers at the base of the intakes. What do you suggest as substitutes? TIA
Bobnotch
Bobnotch is offline
PostPosted: Thu Sep 20, 2018 8:12 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Thick paper gaskets available from good VW parts suppliers like CB Performance, Air Cooled.net, and others. I think the last set I used were Bug Pack gaskets.
Tram wrote:
Tram wrote:
Erik G
Erik G is offline
PostPosted: Thu Sep 20, 2018 9:08 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
and if you need it in a hurry, your flaps will have gasket material by the roll. They may actually have the gaskets too, you'd be surprised. For beetles and buses, the "heater hose" from autozone is great from the shroud to the heater box. better than the crap at the VW shop
Jeff67sqbk
PostPosted: Thu Sep 20, 2018 8:55 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
I replaced the manifold and carb gaskets with proper paper style ones tonight.
My local VW FLAPS, Parts for Imports, had the thick paper manifold gaskets, and I cut the carb gaskets from gasket material.
It still runs rich in the left carb.
Looking down into it I can see liquid fuel in the the left carb, whereas in the right one I don't see any liquid.
Closing the mixture screw didn't change it at all.
Thoughts?
Jeff '67 Sqbk stock
Nevada City, CA
Erik G
Erik G is offline
PostPosted: Thu Sep 20, 2018 9:06 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Check you floats (one may have a hole) the needle valves, float height, fuel pressure
I think you probably have a stuck needle valve or a float that ain't floating. You can shake it and hear it, or weigh it. Or put in gas and look for bubbles
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 21, 2018 1:42 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Agreed, check your float and needle and seat valve on the left carb. It sounds like the float isn't sitting right allowing fuel to continue to dump when it should stop the flow.
The needles and seats (for the float) are known to cause problems too. If you still have the old ones, put them in and try it again.
Tram wrote:
Tram wrote:
Jeff67sqbk
PostPosted: Sat Sep 22, 2018 10:00 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Float floats, no holes and moves freely. Replaced float valve and no change. Still too much fuel getting through.
Jeff '67 Sqbk stock
Nevada City, CA
Jeff67sqbk
PostPosted: Fri Oct 12, 2018 8:38 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Update. I replaced the left carb with another I had hanging around. It is a 32PDSIT instead of the 34 that was installed.
Same exact problem with this carb too! Too much fuel getting into the left head.
As someone suggested it might be high fuel pressure, so I swapped the fuel lines left to right hoping that there might be an obstruction.
No dice, same problem, again. Maybe I'll have to try the other spare carb I have.
W1K1
W1K1 is offline
PostPosted: Sat Oct 13, 2018 5:48 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
put a gauge on it to find out what the fuel pressure is. too much pressure will push past some needle valves. some stock pumps can put out 7-10 psi when you only need 2.5psi
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
Bobnotch
Bobnotch is offline
PostPosted: Sat Oct 13, 2018 11:32 am    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Yup, like I mentioned to Monte, use paper pump to bakelite gaskets to lower fuel pressure.
Tram wrote:
Tram wrote:
Jeff67sqbk
PostPosted: Wed Mar 06, 2019 2:58 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
I swapped floats around and the amount of fuel flowing at idle was reduced.
I added paper gaskets to the fuel pump and now I don't see any fuel dripping into the carb looking down inside while running.
However even with the idle screw not touching at all, the lowest idle I can set is about 1200 RPMs.
According to the Unisyn, the left carb is still the source of the extra fuel.
What is the next step to try and get a reasonable idle?
Mike Fisher
Mike Fisher is offline
PostPosted: Thu Mar 07, 2019 2:31 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
It's probably maladjusted rods. There is a procedure for setting them All in proper order Correctly. Idea
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Bobnotch
Bobnotch is offline
PostPosted: Thu Mar 07, 2019 3:32 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Yup, see the link I posted near the top of this thread.
Tram wrote:
Tram wrote:
notchboy
notchboy is offline
PostPosted: Thu Mar 07, 2019 3:35 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Rolling Eyes
This would of been the first thing to check as the idle drop down cam under the choke needs to be able to let go or the idle stays high. Wink
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Mar 07, 2019 11:35 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
'66 is single port and uses the crush washers. '67 is dual port and those are the gaskets they are talking about.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Mar 07, 2019 11:41 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
notchboy wrote:
Rolling Eyes
Yup. If that cam isn't dropping off the offending carb will pull. This adjustment is the bent rod that has two 7mm nuts at the threaded section at the bottom through a linkage lever off the base of the carb. Adjust the length of the rod by using the nuts so that it's the same length as the right side.
Bryan67 wrote:
Those who can- do.
Jeff67sqbk
PostPosted: Sat Apr 13, 2019 5:56 pm    Post subject: Re: 67' Dual Carb Idle Too High Reply with quote
Got it!
Adjusted the rod on the carb and managed to get the idle lowered enough to balance carbs and again at higher revs.
Took it out for a quick spin around town. Feels nice to drive it again after many, too many years of not being able to!
Thanks all!
Here's a picture of the cobbled together stuff I use to hold the RPMs high for balancing carbs.
The threaded piece has a 90 degree bend to fit into the open wrench, the other piece is a bent tent peg. Wing nut for adjustment.
