Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4570 Location: Cedar Falls, Iowa
Posted: Mon May 14, 2018 1:25 am Post subject: Re: Middle seats |
Colm5928 wrote: |
Anyone know what the internal bore and the external dimension is of of the pipe on the split bus seat is (where the grab rails go down into the backrest)
Here is the external dimension (mm) on the bay seat
Thank you. Colm
Been trying to do some patch work on the FRONT seat of my December 1955 Single Cab, and the tubing of that one is 20mm OD. I found some nice pieces in my basement from a store fixture that are about 19mm, so I think I'm gonna use that. It will get covered anyway! Still trying to figure out how to nice tight bends on it. Electrical conduit bender are like 5inch radius and I need more like 2" radius. _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
FritzCP Samba Member
Joined: October 23, 2005 Posts: 478 Location: Wisconsin
Posted: Tue May 15, 2018 12:30 pm Post subject: Re: Middle seats |
use donor seats for the corner bends _________________ Fritz Custom Products
Fritz Custom Products |
Posted: Tue May 15, 2018 11:20 pm Post subject: Re: Middle seats |
volksheime wrote: |
use donor seats for the corner bends |
These nice tubing pieces already have 90 degree bends in them so the plan is to utilize those bends. But I still have to do the 30 degree ish offsets they the rail jogs down.
Sellers offer air conditioning tube benders in 3/4 (20mm) OD size. If these benders are made with steel shoes, I would buy one.
Al _________________ Al Brase
Vanagons:
ozzmosis Samba Member
Joined: April 06, 2018 Posts: 15 Location: Santa Maria ca
Posted: Fri May 18, 2018 10:39 am Post subject: Re: Middle seats |
trying to confirm i was told a 1968 bay window middle seat would fit in a 64 split bus
can anyone let me know
thanks. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71528 Location: Phoenix 602
Posted: Fri May 18, 2018 6:05 pm Post subject: Re: Middle seats |
ozzmosis wrote: |
thanks. |
Long seat? Yes.
Short seat? Technically yes but the outside leg, the one toward the cargo door, won't line up with the floor mounts so you would have to drill new holes or weld-in new mounts for that leg. _________________ How to Post Photos
pupafly Samba Member
Posted: Mon Jun 04, 2018 4:46 pm Post subject: Re: Middle seats |
Hello All, 2018 miracle: TMI has found the pattern for the Double Flipper middle seat covers and so you can order them direct at $400+ with the usual wait time. Please check with TMI for more details.
Neville |
Mike A. Samba Member
Joined: November 28, 2015 Posts: 1 Location: Germantown, Wisconsin USA
Posted: Sun Jul 29, 2018 4:05 pm Post subject: Re: Middle seats |
Hi!
Do you ever come across a middle seat for a 1965 standard walk-through split-window bus for sale? It's the 2/3 seat with the arm rest and the salt & pepper color.
I kick myself for agreeing to throw out the frame of a rusted middle-seat without upholstery probably about 40 years ago. My older brother wanted to get rid of it and I said Okay. Ouch!
Thanks,
Mike Anas
(suburb of Milwaukee) |
mllks Samba Member
Posted: Tue Jul 31, 2018 8:48 am Post subject: Re: Middle seats |
Hi guys. I'm trying to define which year seats I have. Here's the middle seat. It definitely seems to be not correct for my bus which is 62, it looks older for me. I was wondering if it's missing one leg or something. I guess the seat is re-upholstered at some point by PO. What do you think?
What would be a suitable price for them both (middle seat + rear seat) if I decide to sell them? The rear seat is pretty much in the same condition with this.
Posted: Tue Jul 31, 2018 9:01 am Post subject: Re: Middle seats |
It looks like a "6-leg" middle seat, which is for Barndoor Buses and Buses up through early 1956 but it may be a seat that has been pieced together from 2 different seats.
It appears that the legs have been modified so that the back rests can be removed and then bolted back on.
Yes, there is one leg missing on the bottom - you can see where it comes down on the backside.
The bottom looks strange though, there should be more cross-bars, here's another photo of the bottom of a 6-leg seat
See how the 6 "legs" that come down from the seat back connect to cross-bars on the bottom of the seat frame?
It may be a "6-leg" back rest on a later 56-57 seat bottom.
The large springs on the bottom ended in 1957 so that is why I say it might be a 56-57 seat bottom.
This might be a valuable seat and very hard to find, even though it has been modified, if it can be determined exactly what is there.
Can you post photos in your Gallery of the back seat too?
It would be good to see if it's from the same year.
Barndoor (pre March, 1955) rear seats and and 55 and later back seats are also slightly different.
The Barndoor rear seat back rest has 2 tabs that stick out, like this:
and the bottom has a sharp center leg like this
(This is for later 1955 Buses too) _________________ How to Post Photos
mllks Samba Member
Posted: Tue Jul 31, 2018 9:17 am Post subject: Re: Middle seats |
EverettB wrote: |
It would be good to see if it's from the same year. |
I uploaded photos of the rear seat to my gallery as well. But I don't want to post them here because the topic is about middle seats. The back rest of the rear seat doesn't seem to have those barndoor tabs on them.
Interesting! So it seems that the middle seat has been modified quite a lot. |
bmoreindy Samba Member
Posted: Wed Aug 22, 2018 12:09 pm Post subject: Re: Middle seats |
Anyone have experience with the reproduction seats? One seller right now has a full middle for my 66 for $1600.
A friend tells me he heard bad things about them, but my search didn't turn up anything. Thanks in advance. |
NL-Scirocco75 Samba Member
Joined: August 31, 2013 Posts: 9 Location: Maarssen, The Netherlands
Posted: Thu Oct 25, 2018 2:45 pm Post subject: Re: Middle seats |
Working on a short middle seat in Como for my 64 Standard.
I have the repro short with lower springbed width of 39" and a (3/4) WW Como cover plus seat pad that both appears to be 43".
The part in this thread (page 28 ) covering the backrest plate indicates 39" is the correct width for the short middle seat.
Everett wrote earlier in thread:
"Short middle seat: 59-66 are the same" and (page 36):
"I have a 2/3rd middle seat from a '63, the frame is the same as a '60 seat.
Do you mean measure the distance between the ends of the legs?
End to end, from outside leg to outside leg, is 43".
Does the width for the short seat indeed varies over the years and in case it did, for which years?
In case not, what would be the correct width for the 59-66 period?
Thnxs for helping to sort out what needs to be corrected. |
Posted: Fri Oct 26, 2018 1:13 am Post subject: Re: Middle seats |
If there were no sizing differences , your support will be very helpful. I don’t see the logic why either the frame or the cover do not match.
Could you measure
- the width and depth of both the seat and back spring packages
- The distance between end of legs (end to end)
- A picture from somewhat aside to see the spring package position versus the frame legs (cargo doors site)
- It’s year of origin when you known.
I am aware of the 67 short seat exception, does this spring package differ in width or is it just the frame leg construction/position?
Thanks again! |
RockStock Samba Member
Joined: November 26, 2004 Posts: 4218 Location: England
sixtyonecrew Samba Member
Joined: October 15, 2015 Posts: 113 Location: Florida
Posted: Thu Nov 15, 2018 7:34 am Post subject: Re: Middle seats |
Nice double flipper Rockstock!
I have a question on this grab bar in my 58 pressed bumper standard bus. It looks like most 58 pressed bumper pgsg buses came with a black grab bar... Does anyone know when these white/cream grab bars with the aluminum mounts were manufactured and for which models. I do know it had an ash tray mount on the back originally... Here are some pics to help with my question.
If it helps the only thing I have been able to find on this site is " early -mid '61 deluxes have white ribed vinyl material on the grab bar"
There has to be more info out there on this grab bar...
Original pic of the seat prior to getting it redone...
Posted: Thu Nov 15, 2018 7:37 am Post subject: Re: Middle seats |
Nice score on that double flipper above!
On the vinyl grab bar seat above, what you posted is correct.
"early -mid '61 deluxes have white ribed vinyl material on the grab bar"
This is what Buses had this plastic-covered grab bar. 1961 Deluxes.
I can see your seat before it was redone has the upholstery for 59-61 Deluxe Bus. _________________ How to Post Photos
Posted: Thu Nov 15, 2018 1:11 pm Post subject: Re: Middle seats |
Any idea how long these middle seats with the white ribbed vinyl material on the grab bars were produced? Just the one year? |
