1967 Beauty Ring part number?
harrymarlin
harrymarlin is offline
PostPosted: Thu Jan 31, 2019 2:05 pm    Post subject: 1967 Beauty Ring part number? Reply with quote
I am trying to find NOS beauty rings for my 1967 Beetle convertible, and I have found a few which have the right number of vents (10), but say they are for 4 lug nut wheels (Ghia 1967 was 4 lug nut?). As the 1967 was a 5 lug nut wheel, would these still work? What would be the difference (fit a slightly different hub cap)?
Does anyone know the part number for this part (such as 311 601 155)?
Thanks!
-Harry
aa390392
aa390392 is offline
PostPosted: Thu Jan 31, 2019 2:22 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
I like to think there 2 types of rings, can you send pic. To be specific.
Thomas
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet
harrymarlin
PostPosted: Thu Jan 31, 2019 2:40 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
Here is an example of one:
aa390392
aa390392 is offline
PostPosted: Thu Jan 31, 2019 2:54 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
Not certain, but that ring should fit all VW's . Flat caps and baldies.
55 ragtop
56 delux sedan
56 Kabriolet
harrymarlin
PostPosted: Thu Jan 31, 2019 3:06 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
Great! If I'm understanding correctly, you are saying that the # of lug nuts has no impact on the design of the beauty ring or hubcap?
Thanks!
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Jan 31, 2019 3:57 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
4-lug wheels had hubcaps that fit over bumps in the wheel; 5-lugs fit inside. Whether this affects the trim ring or not I can't say, but I would worry it might unless KNOWN otherwise.
mukluk
mukluk is offline
PostPosted: Thu Jan 31, 2019 3:59 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
I'm seeing 141 601 155 B listed for '66 convertibles (specifies 5 hole mount), and 311 601 155 for '67-'69 convertibles (specifies 4 hole mount).
KTPhil is offline
PostPosted: Thu Jan 31, 2019 4:09 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
Hmmm... the Type 3s had a different wheel offset; whether that affects the trim ring or not I'm not sure, but I always assumed it did.
PostPosted: Thu Jan 31, 2019 6:15 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
I'm not 100% sure but I think 4-lug wheels are all the same.
5-lug trim rings are definitely different for 5-lug Type 3 wheels, Bug 5-lug ones don't fit properly.
harrymarlin
PostPosted: Thu Jan 31, 2019 7:26 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
mukluk - where are you seeing those part numbers? 141 would be Karmann Ghia, right (which is a type 1, which would make sense), and 311 is a 1500?
-Harry
mukluk
mukluk is offline
PostPosted: Thu Jan 31, 2019 8:02 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
The part numbers are pulled from the parts catalog.
Yes, 141 would be KG and 311 a Type 3, but VW's numbering system used the vehicle the part was first used on in the initial three digits -- if the part was subsequently used on a different line/type the part number retained the original three digits. A good example of this is with your typical 1600 dual port heads: their part number starts with 311 as they were originally designed for and used on the Type 3.
hitest
hitest is offline
PostPosted: Thu Jan 31, 2019 8:31 pm    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
Exactly right ^^. An easy, popular example is the horn bar used on beetles from '64 to some time later. They have a 311 number.
FU#5
codycat
codycat is offline
PostPosted: Fri Feb 01, 2019 9:54 am    Post subject: Re: 1967 Beauty Ring party number? Reply with quote
call me 'old-school' but i prefer not to cover the two-tone wheels so famous to beetles...
the chrome is cool yes...so to me is a toss up -- but i dig my two-tone wheels tho
Did you ever stop to think, and forget to start again?
Winnie the Pooh
Sometimes the questions are complicated and the answers are simple.
Dr. Seuss
Jos.Hall
Jos.Hall is offline
PostPosted: Tue Oct 06, 2020 4:02 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
Harry, did you ever figure out the answer to this question? I'd like to pick up an NOS set as well but don't want to buy the wrong set.
PM ME TO ADD YOUR '67 TO THE '67 BUG REGISTRY!!!!
https://vintagejalopy.com/67bugregistry/vwbugregistry1967_view.php
'67 L41 Sedan 117333192
'67 L41 Vert 157343589
'67 L19K Vert 157452166
'67 L19K Vert ??????
'67 L282 Vert 157419653
'67 L620 Sedan 117534350 (Sold)
'67 L54 Vert 15745800 (Parted out)
'52 Split based Devin
harrymarlin
PostPosted: Wed Oct 14, 2020 1:13 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
Whoa - somehow I missed this post! It's probably too late, but the original part number is CK 141 601 155 B. *HOWEVER* The exact same ring also has a different part number CK 311 601 155 - that just wasn't the original for the Bug (but only a purist will know). As long as they aren't too damaged, you *can* find the part number stamped on each ring.
I hope that helps!
-Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia
67 Florida Deluxe
Samba Purist
67 Florida Deluxe is offline
PostPosted: Wed Oct 14, 2020 7:10 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
I hope that helps!
The 141 is what are on my '66 KG, and I bought an NOS set in the original box (also 141) and they are remarkably nice. Given the wheels and wheel covers are interchangeable for '66 and '67 Type 1s and KGs, who would know unless you looked at the part number stamped in the inner edge of the trim ring. I don't know if there's even a specific one for the Type 1 with a different part number, since they are interchangeable wheels. The guy I bought my set from in England has one more NOS set, unless he sold it in the last 6 months. Message me for his info if you're interested in his contact info.
These are the ones I have.
-Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental
Last edited by 67 Florida Deluxe on Wed Oct 21, 2020 7:27 pm; edited 1 time in total
Jos.Hall
Jos.Hall is offline
PostPosted: Sun Oct 18, 2020 6:15 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
67 Florida Deluxe wrote:
I hope that helps!
The 141 is what I have for my '66 KG, I bought an NOS set in the original box and they are remarkably nice. Given the wheels and wheel covers are interchangeable, who would know unless you looked at the part number stamped in the inner edge of the trim ring. The guy I bought my set from in England has one more NOS set, unless he sold it in the last 6 months. Message me for his info if you're interested in his contact info.
I'd love to know who the guy in England was if you don't mind passing the info! They seem like a part you can't buy too early in the process Smile
67 Florida Deluxe
Samba Purist
PostPosted: Wed Oct 21, 2020 6:54 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
I sent you a PM
daven
daven is offline
PostPosted: Tue Jan 25, 2022 3:12 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
Reviving an old post.
Since the late (?) 1966 and 67 bugs used a specific rim/hubcap (5 lug) are the beauty rings different also?
I got a set of rings and compared them to the beautiful rings posted and the interior portion of my rings are flat while the ones in the pics have a "bump"?
Any help?
Dave
67 Florida Deluxe
Samba Purist
PostPosted: Tue Jan 25, 2022 6:16 pm    Post subject: Re: 1967 Beauty Ring part number? Reply with quote
Any help?
Dave
Post some photos
