Emeraldlion Samba Member
Joined: April 13, 2005 Posts: 754 Location: Texarkana, TX
Posted: Tue Feb 27, 2018 5:38 pm Post subject: 100mm clutch arm |
Anyone know a source for the 100mm clutch arm? Other than a 75 or later beetle  |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2768 Location: Santa Cruz, CA
Posted: Tue Feb 27, 2018 7:06 pm Post subject: Re: 100mm clutch arm |
The ad doesn't say if it's 100mm, but it looks quite a bit longer than a regular arm.
https://www.thesamba.com/vw/classifieds/detail.php?id=801962
You might consider that a longer arm will change the angle of the clutch cable as it exits the end of Bowden tube. When used on an an older transmission, this'll cause the cable to start sawing into the end of the tube. Probably not the best thing for the cable... _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Tue Feb 27, 2018 7:41 pm Post subject: Re: 100mm clutch arm |
I appreciate the post, however that is an inactive ad. Bruce does not have any listed currently . You are correct in that the bowden tube may need to be adjusted, but with a heavier pressure plate and clutch the difference in clutch effort is more than worth it. |
Joined: May 17, 2003 Posts: 4876 Location: Harmony, PA
Posted: Wed Feb 28, 2018 5:45 am Post subject: Re: 100mm clutch arm |
The reason Bruce's ad is inactive is because they are no longer available new. Like everything else popular that's nla, they pop up in the classifieds every once in a while. I've been searching on-off the last few years for some, only to find one. Good luck. |
Posted: Wed Feb 28, 2018 5:47 am Post subject: Re: 100mm clutch arm |
That''s what I was afraid of. Will keep looking. I was hoping someone would have heard of a place that was making them. Question sera.... |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17601 Location: Left coast, Canada
Posted: Sun Mar 04, 2018 3:15 pm Post subject: Re: 100mm clutch arm |
rcooled wrote: |
You might consider that a longer arm will change the angle of the clutch cable as it exits the end of Bowden tube. When used on an an older transmission, this'll cause the cable to start sawing into the end of the tube. Probably not the best thing for the cable... |
I thought that would be the case, so I did some testing.
First, the various clutch arms:
# 1, 3, and 4 are what VW of Germany installed on Type 1 transmissions.
#1 was from about 1965 to 1972. 73mm long
#3 is from 73 to 75. 90mm long
#4 is 75 to 1980. 100mm long
Here's an early swing axle side cover showing how the cable lines up with the 90mm long arm. Note, this is a combination of parts VW never offered. The cast in support on the side cover was eliminated and replaced with a steel bracket by the time the 90mm arm appeared. The cable is perfectly centered in the clutch cable tube.
Here's that same side cover with the cable in the 100mm arm. As expected, the cable rides higher in the tube it exits.
Now the later bolt on bracket for the clutch tube and the 100mm arm. Still rides a bit high exiting the tube.
Here's a late model Mexican Beetle. Still exiting high in the tube.
What this shows is that it doesn't matter how the end of your clutch tube is supported, it's aimed exactly the same. It appears to me that VW didn't see the slight variation in the exit angle of the cable as a problem. _________________
Posted: Sun Mar 04, 2018 4:23 pm Post subject: Re: 100mm clutch arm |
Those are great reference photos Bruce, thanks. |
XXX-1.8T Samba Member
Posted: Sun Feb 17, 2019 6:11 pm Post subject: Re: 100mm clutch arm |
anyone have a part number for a 1975 Beetle Clutch arm? |
Posted: Sun Feb 17, 2019 6:46 pm Post subject: Re: 100mm clutch arm |
The 20mm shaft 100mm long arm is 111-141-719-F. |
Posted: Sun Feb 17, 2019 9:50 pm Post subject: Re: 100mm clutch arm |
Thanks what about for 16mm shaft? |
Posted: Mon Feb 18, 2019 6:23 am Post subject: Re: 100mm clutch arm |
Aircooled.net last had them listed as 080-141-719.1. CSP has Flat 4’s version they are making as 141 719 1130. Empi has a 16mm shaft arm that is as long as the early 20mm shaft arms, about 85mm, and it’s #16-9918. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2554 Location: Seekonk,Massachusetts USA
Posted: Mon Feb 18, 2019 7:02 am Post subject: Re: 100mm clutch arm |
That will work for the 20mm shaft. The VW version for the 16mm shaft has been nla for 5 years or so. |
