Synthetic oil or natural oil?
Page: Previous  1, 2, 3  Next
Randy in Maine
Randy in Maine is offline
PostPosted: Fri May 27, 2005 11:43 am    Post subject: Reply with quote
In olden days (when we all had mechanical lifters and no oil filters) we always adjusted the valves and changed the oil every 3K.
Now that I have an oil filter and hydraulic lifters Dancing I know that I can get by with doing it every 7.5K, but I do it every 5K because it makes ME feel better.
Even if I were still using dino oil, I would still change it every 5K. I think it is important to get the acid by-products of combustion out of the oil on a regular basis.
pocvw
pocvw is offline
PostPosted: Fri May 27, 2005 2:33 pm    Post subject: Reply with quote
These have been great replies....from great sources too. According to the owner's manual, as mightyart said, twice a year would fall in my category (since i don't put that many miles on mine). And I think i'll make the switch to synthetic. Again...thank you all for your opinions!!
Life is a garden - dig it!
1980 VW Westfalia
Rocky_rozen92
Rocky_rozen92 is offline
PostPosted: Sun Jun 08, 2014 5:04 pm    Post subject: Reply with quote
How is synthetic holding up for you since this post? I'd like to make the switch either to this group III "synthetic" stuff or a full syn.
Mo' Money Mo' Problems. Keep your life simple and you will simply be rewarded.
'79 Champagne II, '01 Passat Wagon 4-motion, '99 Dodge Ram 1500 Van
VdubVanner
VdubVanner is offline
PostPosted: Sun May 05, 2019 9:02 am    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Synthetic vs Dino Oil: https://www.youtube.com/watch?v=0GZy5mrB4Ng&feature=youtu.be .
Of interest to those of us in COLD climates.
"Fritz", a temperamental and unforgiving 1989 Westy that proudly bears his German flags and status as a member of the exclusive GoWesty Belly Flop Club.
1989 Westy Makeover: GoWesty 2.3L Engine plus plus plus https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
E1
E1 is offline
PostPosted: Sun May 05, 2019 9:55 am    Post subject: Re: Synthetic oil or natural oil? Reply with quote
I am a huge believer in synthetic for its ability to maintain viscosity under severe strain.
But I find the video may be misleading, if only for failing to mention oil weight in this test. I can only presume they used heavy oil to dramatize the test, and it would have been good to know the Dino brand and viscosity they used and whether or not both were the same weight.
That said, I ran heavy oil year-round when living in Denver, Castrol dino 20/50, though in our vans it's been synthetic all the way.
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
djkeev
djkeev is offline
PostPosted: Sun May 05, 2019 11:22 am    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Wow!
Holy gravedig batman!
Since this post originated oil discussion has been funneled into a few main threads found in the FAQ section.
One of them is about synthetic use.
Let's use them to further the discussion so the Big Boys don't need lock this ancient thread.
Thanks
Dave
Ghia
Vanagon
Beetle
VdubVanner
PostPosted: Sun May 05, 2019 1:10 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
djkeev wrote:
Wow!
Thanks
Dave
Actually, Dave, the FAQ section is where I went with my shovel to dig up that grave. Very Happy Hit the Synthetic Discussion link and you end up with this wee thread. Since the grave is now open, does anyone use/favor this stuff: https://www.amazon.com/Liqui-Moly-2041-Premium-Syn...op?ie=UTF8 . There's a High Tech (high mileage) version as well. I've been using Castrol Syntec 5W50 but may switch to the LM after the new engine is broken in. GoWesty recommends using Red Line 10W60 after the break-in period but I'd prefer something that better addresses cold temperatures.
BTW There are almost 22,000 visits to this tiny thread so folks are obviously hungry for info on the subject.
Abscate Premium Member
Abscate is offline
PostPosted: Sun May 05, 2019 1:26 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Oil has the ability to scavenge acid deposits, and they effectiveness can be measured as 'TBN' by a number of services such as Blackstone; changing oil with TBN still in spec is wasteful, expensive, and of no benefit with regard to engine life.
djkeev
djkeev is offline
PostPosted: Sun May 05, 2019 1:29 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Ha! I almost went in to the FAQ to check the link like I normally do, this time I was lazy!
That'll learn me good! Laughing Laughing Laughing Embarassed
Dave
Ghia
Vanagon
Beetle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun May 05, 2019 1:40 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Come over to the dedicated topic in the Performance Forum... we have 4400 posts with almost 800,000 views. We don't bite Wink
Official "What oil / additives should I use" topic
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
djkeev
djkeev is offline
PostPosted: Sun May 05, 2019 1:57 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Always an option one can utilize ........ If one desires Air Cooled opinions...... Laughing Laughing
(There's an inside joke (sticking point?) here folks.....)
Dave
Ghia
Vanagon
Beetle
Mr. 010
Glenn is offline
PostPosted: Sun May 05, 2019 2:03 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Dave
Didn't Vanagons come with aircooled engines?
Also Vanagon engine are great for big displacement aircooled when you cut the water jackets off.
Yes.. we know a bit about engines.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
Wildthings is offline
PostPosted: Sun May 05, 2019 2:13 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
For WBXer Vanagons the advantage of synthetic is that it keeps the lifters cleaner. I agree with the comment above that changing oil with a good base number is a waste of time and money. When my wife was driving 25-35,000 miles a year I changed the Mobile 1 I was using once a year after doing some oil analysis, the TBN was always fine, and the engine ran until rod bolt stretch became an issue at 180K miles at which point it was taken out of service.
djkeev
djkeev is offline
PostPosted: Sun May 05, 2019 2:31 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Yeah.... and here is an Air Cooler who woke up and saw the error of his ways! Laughing Laughing Laughing
https://www.thesamba.com/vw/forum/viewtopic.php?t=435801
Dave
Ghia
Vanagon
Beetle
Mr. 010
Glenn is offline
PostPosted: Sun May 05, 2019 2:35 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Dave
Saw that, but I would of done what the "smart" Vanagoners do and go Subaru.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
djkeev
djkeev is offline
PostPosted: Sun May 05, 2019 2:57 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Ha! Yet another Air Cooler correcting his errant ways! ^^^^ Laughing Laughing Laughing
Dave
Ghia
Vanagon
Beetle
tjet
tjet is offline
PostPosted: Sun May 05, 2019 3:03 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
I only use Valvoline VR1 racing (non-syn) in my 2.2 WBX. I use a different viscosity depending on outside temps.
Merian
Merian is offline
PostPosted: Sun May 05, 2019 3:47 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Sure. But the cost for oil analysis is close to that for an oil change (DIY). Good to do an analysis periodically, just to see if metal ions from the bearings are starting to show up...
therastavan
therastavan is offline
PostPosted: Wed Nov 11, 2020 9:06 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
I have a 1987 Vanagon with 2.3L GoWesty engine with only 30K miles on it and I switched to Redline 10W60 as GoWesty recommends. Prior to the change I used standard dino oil 20w50 and oil consumption was quite low. After the change to the Redline synthetic it increased dramatically, I would say 1 quart for 500 miles. Any ideas why this is happening? I have not read any posts of Vanagon owners switching to synthetic and having such a dramatic increase in consumption.
Wildthings
PostPosted: Wed Nov 11, 2020 10:46 pm    Post subject: Re: Synthetic oil or natural oil? Reply with quote
Never known an engine that required 60wt oil unless it was bum f*ck worn out. I would think that oil flow would be severely hampered using something that thick as the pressure would tend to be high causing thus more oil to be dumped by the relief valve so overall less oil would be reaching the bearings.
Page 2 of 3
