New Syncro emblems cast in aluminum
tjet
tjet is offline
PostPosted: Mon May 13, 2019 4:48 pm    Post subject: New Syncro emblems cast in aluminum Reply with quote
Some teaser pics for original large Syncro rear deck emblem in-work. These larger ones are no longer available. These will be cast in aluminum instead of plastic, with high polished lettering and darkened shadow area as original. I hope I'm not going against forum policy showing off these emblems. I just want to share something new Cool - not mine BTW.
Factory emblem
jimf909
jimf909 is offline
PostPosted: Mon May 13, 2019 5:11 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
Neato!
- Jim
Butcher wrote:
Guilty as charged.
Scubavw
Scubavw is offline
PostPosted: Mon May 13, 2019 6:16 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
Well this be offered in the classifieds when they are ready?
tjet
tjet is offline
PostPosted: Mon May 13, 2019 6:53 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
Yes. Let me get with a mod first to see if it's ok to post the samba member's name who is making these.
For a size reference, Below are a couple of links to the 130mm replacements. The original was 180mm
https://campervanculture.com/shop/syncro-rear-hatch-emblem-t3-t25-vanagon/
https://www.gowesty.com/product/emblem-inscription/4213/syncro-rear-hatch-emblem?v=
130mm replacement
180mm original
Team WorldTour
Team WorldTour is offline
PostPosted: Tue May 14, 2019 12:37 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
I'm guessing mine is an original.
It was looking faded, so I did a bit of Alu-tape refurbishment.
Now it looks like it has Alu-tape on it.... Rolling Eyes
1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat!
tjet
tjet is offline
PostPosted: Tue May 21, 2019 11:12 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
outcaststudios
outcaststudios is offline
PostPosted: Wed May 22, 2019 7:17 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
Cool
'88Doka JX td
'69 westy
(rip)couple bugs
(rip)three type III"s
(rip) '81 vanagon
a bunch of french stuff,and 9 motorcycles.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573791
dabaron
dabaron is offline
PostPosted: Wed May 22, 2019 8:00 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
tjet wrote:
missing the H in synchro? hahahaha
1991 Vanagon GL Camper
tjet
tjet is offline
PostPosted: Sat Jun 01, 2019 11:40 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
I love it. Reach out to Greg at Outcaststudios. 50 bucks each.. Hes only got 2 or 3 left...
outcaststudios
PostPosted: Sat Jun 01, 2019 5:45 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
nice dude, glad it made it safe! post pics when you get it on the rust farm, Laughing thanks tjet!
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
ALIKA T3
ALIKA T3 is offline
PostPosted: Sun Jun 02, 2019 1:03 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
That looks great!!
Are the pins in the back cast too or will it be drilled and tapped?
tjet
tjet is offline
PostPosted: Sun Jun 02, 2019 3:47 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
My original emblem was flat with 2-sided tape. This sand casting it made the same way. I may drill 2 shallow holes that will accept screws, or just use tape like the factory did...
Here is a pic of the back
Here's some detail of the front. You can see that it's a sand cast, not a die-cast. Greg is the expert and can explain the different casting methods. I actually prefer how this looks vs the plastic OEM one. I'm going to darken the background a little & buff up the front.
Here's an NOS one for comparison...
https://www.thesamba.com/vw/classifieds/detail.php?id=2279597
outcaststudios
PostPosted: Sun Jun 02, 2019 5:13 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
Looks good tjet! I think that background needs to be darker for sure . As you said these were cast in resin bonded sand , and I agree they look better than the plastic one for sure , plus it won’t turn totally black like the plastic ones do when the aluminum colored paint wears off of them! As for pins , if people need pins I can pin them. Flat with the double sided tape seems to be the easiest though.
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
E1
E1 is offline
PostPosted: Sun Jun 02, 2019 5:40 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
SWEETNESS!
Any plans to do 2WD hatch versions of "Volkswagen" and "Vanagon?"
1984 Westfailure/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
— Colin Chapman
outcaststudios
PostPosted: Sun Jun 02, 2019 5:47 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
E1 wrote:
SWEETNESS!
I need a Transporter badge so maybe I’ll do that next , but I think the logo is verboten? Think
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
tjet
tjet is offline
PostPosted: Sun Jun 02, 2019 8:09 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
I can send you a free transporter badge you can keep.
E1
E1 is offline
PostPosted: Sun Jun 02, 2019 11:00 pm    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
outcaststudios wrote:
E1 wrote:
SWEETNESS!
Sorry, meant the two emblems on the hatch (not the V-Dub logo).
But Yeah, not sure about copyright law regarding that type...
— Colin Chapman
outcaststudios
PostPosted: Mon Jun 03, 2019 5:44 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
I’d be down to make the Vanagon logo, i will hunt for one.
Tjet- transporter logo?! Hell yes , right now I only have one that I 3D printed but my machine isn’t big enough to print it the full length 😂 So I have a midget one I made !
'88Doka JX td
'69 westy
(rip)couple bugs
(rip) '81 vanagon
tjet
tjet is offline
PostPosted: Mon Jun 03, 2019 9:21 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
Looks good tjet! I think that background needs to be darker for sure . ....
I experimented with some acid to darken the 3-D area. It's a mild acid designed to darken aluminum. You can see some difference in the dark area of the "c". You apply it with a swap, then rinse with cool water for a min or so. Since it etches the metal, you do not want to get this on the polished areas. It may leave a permanent stain.
I need to do another application
dobryan
dobryan is offline
PostPosted: Mon Jun 03, 2019 10:11 am    Post subject: Re: New Syncro emblems cast in aluminum Reply with quote
I do not even own a syncro and I want one!
Dave O
The Western Syncro build
