Convert Westy Fridge to 1 lb Propane bottle?
LynnsABCs
LynnsABCs is offline
PostPosted: Tue Aug 06, 2019 7:27 pm    Post subject: Convert Westy Fridge to 1 lb Propane bottle? Reply with quote
Can you Convert Westy Fridge to 1 lb Propane bottle like you can the stove?
LynnsABCs
Knoxville, Tn
1990 Vanagon Westy
1961 Porsche 356 B Notchback Coupe
jimf909
jimf909 is offline
PostPosted: Tue Aug 06, 2019 7:45 pm    Post subject: Re: Convert Westy Frig to 1 lb Freon bottle? Reply with quote
LynnsABCs wrote:
Can you Convert Westy Frig to 1 lb Freon bottle like you can the stove?
I'm assuming that you mean propane, not freon. If that's the question then the answer is yes, you'd just plumb the 1lb propane bottle to the fridge propane line. I don't know how long out would last, perhaps a few days? The Westy three gallon tank holds about 12 lbs of propane +\-.
- Jim
Butcher wrote:
Guilty as charged.
Steve Arndt
Steve Arndt is offline
PostPosted: Wed Aug 07, 2019 10:48 am    Post subject: Re: Convert Westy Fridge to 1 lb Propane bottle? Reply with quote
North Westy has a kit:
http://north-westy.com/north-westy-parts/lp-elimination-kit
You can also go to a propane / bbq supply house and they can set you up.
Steve
Steve's 87 Syncro project
xoo00oox
xoo00oox is offline
PostPosted: Wed Aug 07, 2019 1:32 pm    Post subject: Re: Convert Westy Fridge to 1 lb Propane bottle? Reply with quote
The Westy Dometic fridge will only run for about 12 hours on a propane bottle. The modern 12v refrigerators are much more efficient.
msinabottle
msinabottle is offline
PostPosted: Wed Aug 07, 2019 2:44 pm    Post subject: Re: Convert Westy Fridge to 1 lb Propane bottle? Reply with quote
With my adapter rig, doped and tightened, Winston's Dometic and stove ran for two days on a 'double' canister with propane to spare. YMMV, I suppose.
Best!
'Winston,' '84 1.9 WBX Westy
many ways, but never, never, never in silence."
izzydog
izzydog is offline
PostPosted: Wed Aug 07, 2019 6:38 pm    Post subject: Re: Convert Westy Fridge to 1 lb Propane bottle? Reply with quote
I had a local propane company make me a short "rescue" hose for connecting 1lb bottles. It's long enough when attached, to let a 1lb propane bottle lay on the ground next to the van. I think it cost me around $15. (I call it a "rescue" hose because it rescued my breakfast one time when I ran out of propane right in the middle of cooking breakfast.)
The large fitting connects to the 1lb bottle and the small fitting connects to a "T" that is plumbed into the system BEFORE the van's propane regulator (2nd photo)The square thing in the middle of the photo is the plug that lives in the t-fitting when the rescue hose is not in use. I don't remember what size the small fitting on the hose is, but when you go to the propane place and ask them for a t-fitting that will fit "in-line" on your van, you can also have them match the t-fitting female port to the male fitting on the rescue hose.
Hope that all makes sense.
