Aftermarket Deck, cigarette lighter and map light not working.
jschwerdtfeger
jschwerdtfeger is offline
PostPosted: Tue Jul 02, 2019 9:31 pm    Post subject: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Hey All,
I have an '85 Westfalia and my aftermarket deck (which is a PITA to remove) 12v socket and map-light are not working. Since they don't share a common fuse I'm a bit perplexed. Perhaps they all share a common ground on the tree? Thoughts?
//JS
VicVan
VicVan is offline
PostPosted: Tue Jul 02, 2019 10:59 pm    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Hi,
Did you check the fuses just to make sure? Worth a shot...
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
dabaron
dabaron is offline
PostPosted: Wed Jul 03, 2019 5:05 am    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Ground 16 is common per the wiring diagram.
1991 Vanagon GL Camper
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Jul 03, 2019 5:58 am    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Fuse 8 would be worth a look.
Not just a visual check but with a voltmeter.
vegpedlr
vegpedlr is offline
PostPosted: Wed Jul 03, 2019 7:26 am    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Check the grounds. The ground wire from my map light had been cut. In dash, the light worked by grounding to the metal dash. When removed, testing the USB outlet I put in its place it wouldn’t work. As for the stereo, aftermarket installation seems different than stock, so who knows what was done. Also check fuses 8 and 9.
1985 Tintop 4 sp GW 2.3 “Connie”
2006 Mk V GTI 2.0 FSI “Penelope”
jschwerdtfeger
PostPosted: Wed Jul 03, 2019 11:01 am    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Fuses are all good, just replaced them all with a GW kit. I'll check the ground(s) this evening.
//JS
jschwerdtfeger
PostPosted: Wed Aug 07, 2019 4:09 pm    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Ended up running a new (+) for all these, problem solved. The dash wiring is a rat's nest (EJ22 conversion and multiple aftermarket decks, etc). One project down, ninety-nine to go...
//JS
eeebee
eeebee is offline
PostPosted: Wed Aug 07, 2019 6:35 pm    Post subject: Re: Aftermarket Deck, cigarette lighter and map light not working. Reply with quote
Isn't the dash lighting connected to each? Probably jumps through the radio plug.
Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time.
