My 67 Squareback
Page: Previous  1, 2, 3 ... , 24, 25, 26  Next
old_man
old_man is offline
PostPosted: Mon Jul 22, 2019 6:53 pm    Post subject: Re: My 67 Squareback Reply with quote
This week's issue: the blinkers.
-4 ways work fine,
-turn signals work fine,
-BUT the green indicator arrows in the dash stay on all the time, even when the turn signals are not in use. When the turn signals are in use they do not flash at all. The click-clack-click-clack sound that normally accompanies the use of blinkers is now a more subdued click - - click.
This use to only happen once in a while and just go away after a few minutes of driving.
I'm guessing this is a dirty/stuck contact in that big relay box. Any better guesses?
Bobnotch
Bobnotch is offline
PostPosted: Wed Jul 24, 2019 9:27 am    Post subject: Re: My 67 Squareback Reply with quote
That would be my guess too. Also check the ground screw that's holding it in place.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Thu Jul 25, 2019 8:31 am    Post subject: Re: My 67 Squareback Reply with quote
Unfortunately I couldn't take pictures as I smashed my phone lens a couple nights ago.
I believe the problem was a tiny spring that broke. Pardon my lack of technical terms. The spring returns a little metal plate from the 'click' position back to the 'clack' position. I bent what was left of the spring back into shape and reattached.
It sort of works now. It makes the click clack sound but the lights sometimes flash erratically. Are the replacement ones any good?
old_man
old_man is offline
PostPosted: Wed Aug 07, 2019 5:29 pm    Post subject: Re: My 67 Squareback Reply with quote
New question for everyone; roughly how much force should it take on the linkage rod to close the cooling flaps?
I just blew a second thermostat and wondering if something is wrong. Could the spring that is holding the cooling flaps open be incorrect and too powerful causing the thermostats too keep failing?
W1K1
W1K1 is offline
PostPosted: Thu Aug 08, 2019 7:34 am    Post subject: Re: My 67 Squareback Reply with quote
I have mine out right now, it takes very little effort for them to close with the stock spring in place.
1973 super 2110cc
1965 squareback 1500E-sold
1971 bay window westy- EJ2.5 subi swap
old_man
old_man is offline
PostPosted: Thu Aug 08, 2019 7:55 am    Post subject: Re: My 67 Squareback Reply with quote
Is that pushing in the actual flaps or pulling on the roof underneath?
Bobnotch
Bobnotch is offline
PostPosted: Thu Aug 08, 2019 9:48 am    Post subject: Re: My 67 Squareback Reply with quote
If you're pushing in on the flaps, you're closing them. If I remember right, the flaps spring is basically a long dual carb spring, so it's pretty soft (not stiff).
Maybe your linkage is binding somewhere?
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Thu Aug 08, 2019 5:22 pm    Post subject: Re: My 67 Squareback Reply with quote
[quote="Bobnotch"]
I don't remember it binding anywhere but I will check again. I remember the flaps being easy to close by hand but it requiring more effort when pulling on the rod due to lack of mechanical advantage.
I'm just trying to figure out why I blew 2 thermostats. It could be that they are 50 years old and fatigued. It could be that I tested them with out having them int he bracket which could weakened them. Or maybe there is something wrong with the flaps.
Bobnotch
Bobnotch is offline
PostPosted: Fri Aug 09, 2019 9:46 am    Post subject: Re: My 67 Squareback Reply with quote
[quote="old_man"]
Yes, for testing them, they should be in the bracket. This is to keep them from over expanding. If you did your testing without it being in the bracket, you could have caused premature damage to them.
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Sun Aug 11, 2019 9:23 am    Post subject: Re: My 67 Squareback Reply with quote
Here is the first one I had, the second one, and now I installed the third. The second one is a different temperature so that's why, I think, the number of bellows are different.
I couldn't find the failure of the first one but I think I found it on the second one. Cracked solder. In theory this could be fixed but I am not sure I am going to.
When I replaced it I discovered the spring had become loose. This went from a 20min job to a 90min job. Taking that upper tin off is a very involved process. I hope to do not it again.
old_man
old_man is offline
PostPosted: Mon Aug 12, 2019 12:32 pm    Post subject: Re: My 67 Squareback Reply with quote
So I was having problems with stability at speeds of 70 mph and above. It would really dance all over the place if there was a bit of wind. A bit of research led me to believe it was the front end getting really light due to aerodynamics.
$11 from a junkyard and the problem seems to be solved.
It's off an old Jaguar XJS, I just had to trim the ends. I still have to do some more testing and I may put a couple metal brackets behind it as a backing but it seems to be working.
Asethetically I don't think it's very obtrusive or even noticeable.
W1K1
W1K1 is offline
PostPosted: Mon Aug 12, 2019 1:09 pm    Post subject: Re: My 67 Squareback Reply with quote
I made a copy of the Kamei off the wifes superbeetle, at 100 mph it is smooth on my 65 square, even in the wind
1973 super 2110cc
Bobnotch
Bobnotch is offline
PostPosted: Tue Aug 13, 2019 11:44 am    Post subject: Re: My 67 Squareback Reply with quote
Check the front tire pressure, as it might be too high. These cars like 18-20 psi on the front, and 28-30 in the rear.
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Tue Aug 13, 2019 2:43 pm    Post subject: Re: My 67 Squareback Reply with quote
I just checked. 28/29 in the rear. 20/21 in the front.
oxsign
oxsign is offline
PostPosted: Tue Aug 13, 2019 3:30 pm    Post subject: Re: My 67 Squareback Reply with quote
I'll be honest, I didn't even notice it till the 3rd pic, lol. If it works, that's all that matters. As long as it's not some crazy "Fast & Furious" chin guard, lol.
1971 Squareback, fully bagged, 1776.
Build thread here.....
old_man
old_man is offline
PostPosted: Wed Aug 14, 2019 4:18 pm    Post subject: Re: My 67 Squareback Reply with quote
Out of curiosity, anyone ever install an altitude corrector into their solexes? I'm not really at altitude these days, just wondering if anyone had ever used one.
ibjack
ibjack is offline
PostPosted: Thu Aug 15, 2019 7:51 am    Post subject: Re: My 67 Squareback Reply with quote
I’ve got them in my automatic 68 T34. Runs similar to my 64 T34 without.
'68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074
old_man
old_man is offline
PostPosted: Mon Aug 26, 2019 2:13 pm    Post subject: Re: My 67 Squareback Reply with quote
So I've been chasing an overheating problem. I don't think it's anyone one thing wrong but rather a series of things that add up.
One of them might have been my single relief spring being tired. So I bought a new one. I read all the warnings about how new ones are the wrong length but I think I managed to find one......so I ordered 10 of them.
Here is the old one; that is no longer the correct length, and here is the new one; that is the correct length.
I created a rudimentary spring tester to see if it had the correct spring force according to Bentley and it was bang on. Well, at least as close as my spring tester could measure. I then tried to measure the old one but then my spring tester broke. It set the spring flying across the shop. I haven't found it yet.
Here is the invoice from where I got them. They are on clearance and very cheap so I thought I would spread that info if anyone else needs one.
old_man
old_man is offline
PostPosted: Thu Sep 12, 2019 12:23 pm    Post subject: Re: My 67 Squareback Reply with quote
Out with the old and in with the new (well, rebuilt anyways). The old one was giving me troubles every now and then necessitating a gentle tap with a hammer to get it working. Not fun in a rainy parking lot. I took it apart and the wires on the brushes that, I think, were contacting the housing. It helped but it still gave me trouble.
Amazon had a sale on this thing so I went for it. Hopefully it doesn't give me troubles. Not sure what I should do with the old one.
Bobnotch
Bobnotch is offline
PostPosted: Fri Sep 13, 2019 9:29 am    Post subject: Re: My 67 Squareback Reply with quote
Is the new for an automatic? Just asking as it's very large. As for the old one, I'd hang on to it, as it does work (sometimes). Maybe rebuild it.
Tram wrote:
Page 25 of 26
