swing axle
flabuggy
flabuggy is offline
PostPosted: Mon Aug 26, 2019 3:47 pm    Post subject: swing axle Reply with quote
I have a 68 swing axle that I just did a transmission swap on and for the life of me I cannot get the axle tubes shock mounts to line up right. I have swapped them from side to the other and the shock mounts still end up behind the axle instead of in front. There're are only 2 ways they can bolt up left or right side and neither one works.
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 4:08 pm    Post subject: Re: swing axle Reply with quote
I think you have the axles on the wrong side. Is that possible?
The bottom shock attachment point should point down and forward towards the spring plate not backward.
Q-Dog
Q-Dog is offline
PostPosted: Mon Aug 26, 2019 4:10 pm    Post subject: Re: swing axle Reply with quote
It goes like this.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Paul Windisch
Paul Windisch is offline
PostPosted: Mon Aug 26, 2019 4:14 pm    Post subject: Re: swing axle Reply with quote
It’s just clocked wrong. Rotate it one bolt hole. The shock should mount in FRONT of the axle tube.
*ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer
flabuggy
flabuggy is offline
PostPosted: Mon Aug 26, 2019 4:26 pm    Post subject: Re: swing axle Reply with quote
I have swapped the tubes from one side to the other several times and the shock mount always ends up on the wrong side. This shouldn't be this difficult. I'm just flabbergasted I can't get this right This is not my first car or buggy.
Paul Windisch
PostPosted: Mon Aug 26, 2019 4:39 pm    Post subject: Re: swing axle Reply with quote
Actually, they are on the wrong sides of the car. If you turn them to the next bolt hole, the brake line bracket will be wrong. Swap the tubes side to side, and make sure the shock mount faces forward and down. The shocks will mount to them on the FRONT of the axle tube.
1984 Mexican Beetle
-1914cc
-Engle W110 cam
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 4:40 pm    Post subject: Re: swing axle Reply with quote
It shouldn't be difficult. The axle tube should rotate to the correct orientation.
Remove the bolts on the brake backing plate, then rotate the axle tube to the correct orientation then redo. There should be 4 different variations possible.
Paul Windisch
PostPosted: Mon Aug 26, 2019 4:46 pm    Post subject: Re: swing axle Reply with quote
I thought that too, but then the brake line bracket will be down instead of up.
Unfortunately, they need to be swapped side to side.
1984 Mexican Beetle
-1914cc
-Engle W110 cam
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 4:47 pm    Post subject: Re: swing axle Reply with quote
That's what I said in my first post but the OP said he'd swapped them from side to side.
On mine the brake bracket is facing forward in a horizontal plane.
mukluk
mukluk is offline
PostPosted: Mon Aug 26, 2019 4:53 pm    Post subject: Re: swing axle Reply with quote
The key to figuring this out is the brake line brackets should be facing straight forward toward the front of the car. As noted, the axle tubes are currently on the wrong sides of the trans.
How they should be oriented:
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 5:00 pm    Post subject: Re: swing axle Reply with quote
Really dumb dumb question.
When you say you did a transmission swap did you use any existing parts or parts from the new transmission?
Is it possible you have two "right" hand or two "left" hand parts which you accidentally mixed up?
Edit: The two should be mirror images of each other not identical.
flabuggy
flabuggy is offline
PostPosted: Mon Aug 26, 2019 5:34 pm    Post subject: Re: swing axle Reply with quote
I have swapped them from side to side and the shock mount still ends up in the wrong place{behind the axle. The brake mounting tabs are welded on. I can't see how I can rotate the bolt holes, there are only 3, and there is only one way all 3 will line up. Here is a picture of both tubes side by side on the left side.
Paul Windisch
PostPosted: Mon Aug 26, 2019 5:54 pm    Post subject: Re: swing axle Reply with quote
In this picture, your brake line bracket is facing the rear of the car. If you take that tube off and put it on the right side, that brake line bracket will be facing the front of the car, the shock mount will be pointing forward and down, and the shock will mount FORWARD of the axle tube. Q-dog’s pic shows the proper orientation of the shock mounts and shocks, mukluk’s pic shows the orientation of the brake line brackets. Note that these pics are taken facing opposite directions, so make sure FRONT is FRONT!
1984 Mexican Beetle
-1914cc
-Engle W110 cam
flabuggy
flabuggy is offline
PostPosted: Mon Aug 26, 2019 6:14 pm    Post subject: Re: swing axle Reply with quote
Just to be sure, the swing axle plate has 3 holes, one forward and 2 back top and bottom. Isn't there only one way they will bolt up? I've swapped them side to side several times and when bolted up the shock mount is still on the wrong side. Here is the correct photo showing both axle tubes together. These are the axle tubes off the old transmission on the newer, Used transmission.
Paul Windisch
PostPosted: Mon Aug 26, 2019 6:24 pm    Post subject: Re: swing axle Reply with quote
They will index in more than one position.
1984 Mexican Beetle
-1914cc
-Engle W110 cam
flabuggy
flabuggy is offline
PostPosted: Mon Aug 26, 2019 6:34 pm    Post subject: Re: swing axle Reply with quote
Maybe this where I'm getting lost. Looking at this I have 3 holes in my plate and 3 in my axle tube. How is there more than one way to bolt them up?
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 6:36 pm    Post subject: Re: swing axle Reply with quote
I have a Euro '68 with swing axle but it should be identical. I always thought US '68's came with IRS?
I went and checked the orientation of the bolts on my axle.
When looking at it (LHS) towards the brake drum from the transmission the bolt aligns as approx 11, 3, 7 o'clock.
The right one should therefore be 1,5 and 9 o'clock.
The rear facing bolts line up (11,7 and 1,5) whilst the single bolt faces forward (3,9).
Any other orientation you have a problem elsewhere or they are the wrong axle tubes.
Edited to be 5 o'clock from 4.
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 6:41 pm    Post subject: Re: swing axle Reply with quote
If you blow up the section below it might help with the orientation. Not sure if your axle tubes are like mine. Hard to tell.
flabuggy
flabuggy is offline
PostPosted: Mon Aug 26, 2019 6:46 pm    Post subject: Re: swing axle Reply with quote
The 3 bolt holes on the plate are as you described. I have swapped side to side several times and with all 3 bolts in the tube to the plate the shock mount still ends up back of the tube instead of in front. There is only one way they can bolt on, correct?
viiking
viiking is offline
PostPosted: Mon Aug 26, 2019 6:51 pm    Post subject: Re: swing axle Reply with quote
I would say yes. Only way.
Only thing I can say is that you have the wrong part????
