Cracked Seam -- Fluid Film, Wax, Sealer + Paint ??
The Big Cheese
The Big Cheese is offline
PostPosted: Thu Sep 12, 2019 6:02 am    Post subject: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
I have several cracked seams that I plan on tackling this winter using the preferred method -- sand blast, treat, reseal, repaint, etc. However, I would like to protect my seams from the elements until I have the time to do it right. I've been reading all the forums and it seams that everyone has a different opinion on a quick preventive / solution for cracked seams. Should I put fluid film, wax, or panel sealer + paint on the cracked seams? If you recommend a method then please post the product you used.
dobryan Premium Member
dobryan is offline
PostPosted: Thu Sep 12, 2019 6:35 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
If you are going to do them this winter I would not do anything now. Introducing any kind of wax/oil/whatever into the seam will only make it harder to have anything adhere later when you clean them out. Nothing really bad will happen between now and this winter...
Dave O
The Western Syncro build
danfromsyr
danfromsyr is offline
PostPosted: Thu Sep 12, 2019 6:38 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
I agree, no wax no oils
maybe if you want to keep the rain and water out some clear sealing tape.
Abscate wrote:
MarkWard
MarkWard is offline
PostPosted: Thu Sep 12, 2019 6:48 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Related question. If you media blast the seams, how the heck do you get all the media out of the seams when you are done? We have a media blaster cabinet and you have to wash with soap and water to remove the imbedded media just so it will take a coat of spray paint.
Steve M.
Steve M. is offline
PostPosted: Thu Sep 12, 2019 7:09 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
What you might think about doing and this is open for feedback!
From what I have seen of the seams I have opened, the seam sealer does not get all the way down into the bottom of the seam so there is room for liquid to flow underneath the sealant.
At the top of the vertical seam use a small drill or pick to open the seam so you can stick a small syringe into the seam.
Get some OSPHO in a small syringe and slowly squirt/dribble it in so it flows under the seam seal.
If the OSPHO in the syringe is disappearing it is going somewhere! Check underneath at the bottom of the seam to see if it is in fact running all the way down the inside and out.
Seal up the opening at the top.
NOTE:WEAR SAFETY GLASSES AS YOU CAN GET "SQUIRTBACK' FROM THE SYRINGE.
Steve M.
Steve M. is offline
PostPosted: Thu Sep 12, 2019 7:23 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
I spray Brake Cleaner spray into the seam starting at top and push towards bottom to flush it before I apply the OSPHO to it. Then seal it after using a nylon toothbrush to remove the OSPHO white powder if it creates the white powder.
The Big Cheese
PostPosted: Thu Sep 12, 2019 7:29 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
This might be a dumb question but wouldn't rain getting into the seams make the cracks worse and rust the seams?
dobryan is offline
PostPosted: Thu Sep 12, 2019 7:54 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
In a perfect sense yes, but this is a 35 year old vehicle and a few more months is but a heartbeat to it.
Dave O
jlrftype7
jlrftype7 is offline
PostPosted: Thu Sep 12, 2019 9:20 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
I used Soda Blasting on my worst seams. It's so fine in size compared to Regular Glass Beads or Sand that plain compressed air, followed by Den. Alcohol removed any remaining.
‘84 Tin Top - Hilga....Auto
The Big Cheese
PostPosted: Thu Sep 12, 2019 9:21 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Very true but I'm taking a trip for a couple weeks and will probably experience rain which this van has not seen in a very long time. Is there anything I could do to help prevent further damage?
dobryan is offline
PostPosted: Thu Sep 12, 2019 9:25 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Rain will not hurt it. You'd not hesitate to wash it right? No real difference. Enjoy your trip and do not stress over this issue. Very Happy
Dave O
jlrftype7
PostPosted: Thu Sep 12, 2019 9:30 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Take a Foam Brush, 1" to 2" max size, dip the Brush into a small cup filled with Rust Converter, then apply the Converter to your Seams. If you get Converter on your Paint outside the seams, wipe it off right away with a soft rag that's wet with Mineral Spirits, Naptha, or Denatured Alcohol. Don't let the Converter dry on hot paint from the Sun.
Doing this would still allow you to dig out the old sealer later on and not have the adhesion issues of Wax or Oil when redoing the Seam Sealer.
dobryan is offline
PostPosted: Thu Sep 12, 2019 9:43 am    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
^^^ No harm in doing this if it eases your mind.
Dave O
The Big Cheese
PostPosted: Thu Sep 12, 2019 12:33 pm    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Thanks for the tip. Do you recommend a specific rust convertor?
jlrftype7
PostPosted: Thu Sep 12, 2019 12:46 pm    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Not really, I tend to get Permatex from my local NAPA because they've got 16 oz bottles of it versus little 8 oz bottles at other places of some other brand.
Vanagon Nut
Vanagon Nut is offline
PostPosted: Thu Sep 12, 2019 1:48 pm    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
x2
Good intentions and general lack of skills allowed Fluid Film that was only applied to the panels to creep in and out past new 3M sealant and touch up paint; that FF s**t does what it claims! I am loath to think what I'll have to do, if I can, to do that job over so new sealant adheres. Especially at that "hip" part of the seam near a tack weld. That said, the sealant is not peeling off of anything and I'm quite sure that seam isn't rusting. Wink
Neil.
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
dobryan is offline
PostPosted: Thu Sep 12, 2019 6:48 pm    Post subject: Re: Cracked Seam -- Fluid Film, Wax, Sealer + Paint ?? Reply with quote
Ospho is a good rust converter but again I’ll say you do not need to do
anything now. Just go on your trip and enjoy!
Dave O
