wayne1230cars Samba Member
Posted: Mon Oct 07, 2019 6:45 pm Post subject: Height of fuel pump spacer |
I am replacing my fuel pump with a rebuilt pump from Bill Fowler. The old fuel pump spacer which I replaced about 30 years ago was cracked. It measured 13.81 mm in height. I have 2 new spacers. One is a Dansk , 12.25 mm and the other is from CIP1, 12.85 mm. The Dansk gives me 12.95 mm on the push rod distance above the spacer with one gasket which is very close to the 13.0 mm spec. The CIP1 spacer produces 12.35 mm. This is with a new 108 mm fuel pump rod for my generator equipped 1970.
I thought original spacers were about 13 mm in height. Just wondering if wear on the distributor drive gear where the pump rod contacts it would explain these measurements. Is that susceptible to wear? I am thinking that the thinner Dansk spacer would be best. I can always add a gasket to reduce fuel pump pressure but given the quality of the rebuild I don’t anticipate a problem.
Any suggestions or advice? Am I on the right track here? _________________ 1960 beetle
1970 beetle convertible |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80536 Location: Sneaking up behind you
Posted: Mon Oct 07, 2019 6:48 pm Post subject: Re: Height of fuel pump spacer |
1600 OEM flange.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Oct 07, 2019 7:20 pm Post subject: Re: Height of fuel pump spacer |
Thanks Glenn. Exactly what I wanted to know.
Another difference between the two spacers.
This is how the Dansk ( on the right) came out of the box. It had been sanded to reduce height. Who knows how much. The other one is shiny black but a little thicker than the 12.7 mm original.
As far as quality, the CIP1 spacer seems a little more sturdy and better made.
Last edited by wayne1230cars on Mon Oct 07, 2019 7:24 pm; edited 1 time in total |
Glenn  Mr. 010
Posted: Mon Oct 07, 2019 7:22 pm Post subject: Re: Height of fuel pump spacer |
The on on the left looks to be OE since it have the VW/Audi symbols. _________________ Glenn
Member #1009
#BlueSquare
wcfvw69 Samba Purist
Posted: Mon Oct 07, 2019 8:08 pm Post subject: Re: Height of fuel pump spacer |
Hello Wayne.
I went out and was able to measure my original VW 1960's bakelite fuel pump stands on two of my type 1 engine VW's. Both measured 12.10mm and with the 108MM pushrod, I had 13MM with it at its highest travel point.
Over the decades, who knows what previous owners installed as that stand or what modifications they did to it. Making it shorter as an example.
At the end of the day, VW wanted the pushrod to be at 13mm above the pump stand at its highest travel. You can shim the stand up with gaskets or sand the top of the stand down to make it's thickness smaller. If you're able to hit 12.95mm right now, you're fine.
_________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Mon Oct 07, 2019 8:36 pm Post subject: Re: Height of fuel pump spacer |
Thanks Bill.
The old aftermarket fuel pump pushrod was not exactly helping things. It was worn down to 107.4 mm. Another example of why original is best.
Meiang Samba Member
Joined: September 27, 2016 Posts: 661 Location: Perth, Western Australia
Posted: Mon Oct 07, 2019 10:28 pm Post subject: Re: Height of fuel pump spacer |
Original fuel pump from 1968 (used - 500,000+ miles):
Fuel pump push rod = 107.80mm
Fuel pump spacer = 12.80mm
New fuel pump from new VW industrial motor:
Fuel pump spacer = 12.74mm
The used fuel pump push rod had a polished flat end with a slight concave where is touched the fuel pump lever. Other than that there was no difference between the two.
All parts were original German Volkswagen. |
Posted: Tue Oct 08, 2019 8:49 am Post subject: Re: Height of fuel pump spacer |
New pump is installed and working great. Kudos to Bill for the high quality of his rebuild work. Managed to get very close to the 13 mm spec with the new fuel pump rod and spacer. _________________ 1960 beetle
Posted: Tue Oct 08, 2019 3:59 pm Post subject: Re: Height of fuel pump spacer |
I saw a guy selling an NOS VW made, bakelite fuel pump stand with the correct VW part number on ebay. I reached out to him and asked him to measure the base thickness. He said it was 12.20 mm which is right in line with the measurements of the original VW stands on my VW's I measured.
It's really kind of odd that there were two different height stands from what folks are posting here. I've heard reports that the type 3 engines used a different stand but that dose not make sense either.
I wonder if the 12.7 mm stands were for the alternator fuel pumps with the 100 mm push rod.
Anyone have an original alternator equipped engine with the original fuel pump stand in place? _________________ Contact me at [email protected]
Glenn  Mr. 010
Posted: Tue Oct 08, 2019 4:23 pm Post subject: Re: Height of fuel pump spacer |
| wcfvw69 wrote: |
Anyone have an original alternator equipped engine with the original fuel pump stand in place? |
Bill,
Type 1 "alternator" and "Generator" pumps use the same flange... so does the Type 3.
All the same part number. _________________ Glenn
Member #1009
#BlueSquare
Posted: Tue Oct 08, 2019 5:21 pm Post subject: Re: Height of fuel pump spacer |
| Glenn wrote: |
| wcfvw69 wrote: |
Bill,
All the same part number. |
Weird, huh? Why two different height pump stands then? Your picture showed 12.7mm on a VW stand while the NOS stand from the 60's matched my originals in my VW's of 12.2
Again, at the end of the day, the key measurement is that the fuel pump push rod measures 13mm above the plastic stand. _________________ Contact me at [email protected]
Posted: Thu Oct 10, 2019 7:01 am Post subject: Re: Height of fuel pump spacer |
I'm going to note this for future searchers of this information on fuel pump stands.
I spoke with a retired VW parts manager at a dealership from the late 60's and early 70's. He also said he wasn't aware of two different fuel pump stands. He did however state-
The original VW Part Number for those Blocks were 113 127 303. In the 1997 VW Parts Price Book the Number has now become 113 127 303 C indicating some changes have been made to the part but not what those changes were. There doesn't appear to be two different blocks available at the same time.
So, it's possible that the 113 127 303 stand made in the 60's and early 70's was 12.2mm and the later version 113 127 303C is 12.7mm.
Glenn, do you still have that NOS VW stand that measured 12.7mm? If so, does it have this 303c part number? _________________ Contact me at [email protected]
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8878 Location: Sunset, Louisiana
Posted: Thu Oct 10, 2019 7:16 am Post subject: Re: Height of fuel pump spacer |
| Q-Dog wrote: |
| The VW part sticker on the bag has a "c" in the part number. |
I missed that! Good catch. So, it appears we have the answer then. The 303C was a bit thicker than the 303 though we don't know why VW did that. _________________ Contact me at [email protected]
TK-CS Samba Member
Joined: April 15, 2019 Posts: 279 Location: D - Deutschland
Posted: Thu Oct 10, 2019 7:18 am Post subject: Re: Height of fuel pump spacer |
| wcfvw69 wrote: |
| I've heard reports that the type 3 engines used a different stand but that dose not make sense either. |
I always supposed that the Type 3 engine used the same part, but never checked the parts catalogue for reference.
But afaik the Type 3 pump gets a different pretension setting of the diaphragm than the Type 1 pump. _________________ AC:
'71 1600LE (Type 3 Notchback FI/AT) Sunroof
'75 1303 (Super Beetle) 1600DP, Sunroof
WC:
'77 Audi NSU Ro80
'88 GTI 16V
'91 Corrado G60
Daily:
'04 Passat Wagon 2.0TDI
'13 Passat Wagon 2.0TSI |
Posted: Thu Oct 10, 2019 7:26 am Post subject: Re: Height of fuel pump spacer |
| TK-CS wrote: |
| wcfvw69 wrote: |
But afaik the Type 3 pump gets a different pretension setting of the diaphragm than the Type 1 pump. |
There were a couple of pretension jigs sold by VW. One set the lower diaphragm to 14mm in the mid 60's and the other to 13mm afterward. The big difference in the type 3 pump was the main diaphragm spring wire was just a touch thicker. It gave the type 3 Pierburg pumps more PSI.
I've measured the spring wire on the diaphragm springs from the type 1 and type 3 pumps that had never been apart personally and found that wire thicker on the type 3. _________________ Contact me at [email protected]
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4150 Location: Seattle, WA
Posted: Thu Oct 10, 2019 12:07 pm Post subject: Re: Height of fuel pump spacer |
Hey now, we're not done yet: I have a pump stand, with VW logo, has part No. 040.127.303.1
cast into it. The flange is 13.05 mm thick. IMO, all these slight thickness variations are insignificant,
plus or minus a gasket's thickness, which will not affect pump operation to any practical degree. _________________ '67 bug: seized by the authorities
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1628 Location: The South Zone
Posted: Thu Oct 10, 2019 8:27 pm Post subject: Re: Height of fuel pump spacer |
I've got the same one: 040.127.303.1, and it has the VW logo. I just went out and measured mine. I got 0.519" (13.18mm). I'm with kreemoweet on this one; a fraction of a millimeter isn't a big cause for concern.
Oh, in case you're wondering, I cut that circular groove around the pushrod hole to help the excess oil that creeps up the pushrod drip back down the shaft and into the engine case, instead of spilling over and filling up those "reservoirs" in the stand. I don't know why I worry about stupid things like that, but I do. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Meiang Samba Member
Posted: Thu Oct 10, 2019 10:17 pm Post subject: Re: Height of fuel pump spacer |
The photograph below is of a spacer from late 1967/early 1968 and has a measurement of 12.8mm
Meiang Samba Member
Posted: Thu Oct 10, 2019 10:33 pm Post subject: Re: Height of fuel pump spacer |
I have access to five fuel pump stands which were fitted to to new VW industrial engines (with a generator) and all had only one gasket fitted either side of the fuel pump intermediate flange.
The fuel pump intermediate flange is 12.74mm thick. |
