Header melting the engine seal
gringoloco2000
gringoloco2000 is offline
PostPosted: Tue Apr 21, 2015 7:31 pm    Post subject: Header melting the engine seal Reply with quote
I have a bugpack ceramic 1 5/8 header that I cannot keep from touching the back engine seal (closest to the bumper). I just fired up the engine in the car for the first time and it was smoking pretty badly as the rubber screams for mercy. I thought maybe it would just melt, harden and stop smoking at some point. I only drove a block so far, so not much of a test. It was smoking quite a bit. I can't see how I can prevent it from touching it without cutting some of it maybe. Is there something I could use to insulate it? maybe wrap something around the header at the point of contact to reduce the heat?
Cali_Army_Guy
Cali_Army_Guy is offline
PostPosted: Tue Apr 21, 2015 7:48 pm    Post subject: Re: Header melting the engine seal Reply with quote
I have the same problem. My header has also burnt through my fresh air hose. I'm going to try some header wrap and see if that helps.
Hilbilyrocker
Hilbilyrocker is offline
PostPosted: Sun Oct 27, 2019 8:55 am    Post subject: Re: Header melting the engine seal Reply with quote
I’m experiencing the same thing. Did anyone find a remedy to this issue?
beetlenut
beetlenut is offline
PostPosted: Sun Oct 27, 2019 9:46 am    Post subject: Re: Header melting the engine seal Reply with quote
I just went through this with a newly rebuilt motor and a 1 1/2 inch SS exhaust. Burnt right through the first seal! New motor running hot during break-in with new engine seal fitting tight is not a good combo. Since I have a removable rear apron, I only had to replace the part on the apron. I got some header wrap for motorcycles from Autozone which is supposed to reduce the heat transfer by 50%. I wrapped the primaries coming off 2 and 4 with 2 full layers of the wrap. I also rejetted my carb because I feel I was running lean, went to a cooler plug, and changed oil viscosity from 15-40 to 5-30 weight. With only 150 miles on the engine at that point, it significantly cooled things down. No more engine seal problems, and I can handle the dipstick after running for a good while. While searching on here for remedies, more than a few people felt running a thicker oil would cause heat issues having to do with the bypass to the oil cooler. I'm inclined to agree after my experiences.
scrapyards are for quitters
Wetstuff wrote:
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again.
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Oct 27, 2019 9:48 am    Post subject: Re: Header melting the engine seal Reply with quote
This is all related to the quality of aftermarket parts. They are all not made the same. Also if your car was ever hit in the back.
My Berg 1-5/8" clears the apron and seal. I've seen many other brands not and burn the seal.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
beetlenut
PostPosted: Sun Oct 27, 2019 1:40 pm    Post subject: Re: Header melting the engine seal Reply with quote
True! My car had a little tap in the rear....
Hilbilyrocker
PostPosted: Sun Oct 27, 2019 8:03 pm    Post subject: Re: Header melting the engine seal Reply with quote
Thanks for all your input. Great to have this forum to get help.
It’ll be a couple weeks, but I’ll post an update. 👍
Multi69s
Multi69s is offline
PostPosted: Tue Oct 29, 2019 12:08 am    Post subject: Re: Header melting the engine seal Reply with quote
Header wrap as mentioned will do the trick. If you get quality wrap, you can actually touch the exhaust when its hot and not burn your hand. I use it on my Type 1 in the area where the remote oil lines are close to the exhaust and it lowered my oil temp. I also use it on my Type 4 powered Squareback, but this time for the air conditioning lines.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
bluebus86
Banned
bluebus86 is offline
PostPosted: Tue Oct 29, 2019 10:26 am    Post subject: Re: Header melting the engine seal Reply with quote
Maybe the motor sits too high in the engine bay, thus allowing the header to touch the seal. This maybe a motor mount issue? Mount too tall?
Bug On!
Hilbilyrocker
PostPosted: Tue Oct 29, 2019 10:59 pm    Post subject: Re: Header melting the engine seal Reply with quote
I thought about that. I replaced the old ones. Maybe I need to use a different year motor mount w/ this rebuilt 2160 motor. Any suggestions?
Bashr52
Bashr52 is offline
PostPosted: Wed Oct 30, 2019 4:30 am    Post subject: Re: Header melting the engine seal Reply with quote
The mounts do not change for engine size, just for the trans year. How many miles are on the engine? It will run hot until it's fully broken in.
Hilbilyrocker
PostPosted: Wed Oct 30, 2019 12:32 pm    Post subject: Re: Header melting the engine seal Reply with quote
Brand new, maybe 5 miles.
I ordered heat warpath last night.
Bashr52
Bashr52 is offline
PostPosted: Thu Oct 31, 2019 4:30 am    Post subject: Re: Header melting the engine seal Reply with quote
That will be part of the issue. It's going to run hot until it's broken in.
Hilbilyrocker
PostPosted: Wed Dec 18, 2019 2:10 am    Post subject: Re: Header melting the engine seal Reply with quote
Update on high heat headers.
I wrap the header around the area which press up against the seal.
So far so good. It really helped to keep from melting the seal.
Thanks
gt1953
gt1953 is offline
PostPosted: Wed Dec 18, 2019 6:44 am    Post subject: Re: Header melting the engine seal Reply with quote
I wrapped mine prior to install never an issue.
72 type 1
72 Squareback
