Steering column safety PSA
Page: 1, 2, 3, 4, 5  Next
Basilbomb
Basilbomb is offline
PostPosted: Fri Jan 03, 2020 2:01 pm    Post subject: Steering column safety PSA Reply with quote
Maybe most folks on here already know this, but I just read a thread where a guy replaced his steering column support bolts with hardware store bolts.
We all know those stupid conical bolts can be a PITA to get off and on, but it's dangerous to replace them, as they are quite soft and designed to sheer off in case of a bad accident, allowing the steering column to collapse.
If you replace them with regular bolts and get in an accident (or the next person who owns the van), the column won't collapse and could crush your chest or even go right through you, just like in the bad old days.
These vans have minimal safety features as it is, we don't want to go canceling the few they do.
danfromsyr
danfromsyr is offline
PostPosted: Fri Jan 03, 2020 2:16 pm    Post subject: Re: Steering column safety PSA Reply with quote
these vans do not have minimal safety features and in fact instill the thrill of driving into the driver so that a vanagon driver is more apt to actually pay attention to the road.. well that's an opinion I guess.
as for the steering column it's designed to stay fixed to the dash. the lower coupling will uncouple with any deformation impact and the steering wheel will deflect or pivot forward towards the windshield.
you'r chest should not be so close to impact the steering wheel and the safety cage as designed should not crush the dash & wheel towards you. there are always the exceptions in the chaotic forces of a head on impact though.
it is safest to have yourself seated as far back from the dash & wheel as you can comfortably and confidently control the wheel. your seat belt restraint should keep you in that fixed distance.. many many people sit far to close to the steering wheel when driving.. most often an issue with women, but it's a height thing.. so both genders can be victim..
an area of more concern is that the seat belt mounting bolts in the front 'fender' are prone to corrosion that will weaken and negate the benefits of wearing a shoulder belt. this area should be inspected regularly for corrosion and proactive or counter measures employed to assure safety of your restraint harness.
Wildthings
Wildthings is offline
PostPosted: Fri Jan 03, 2020 2:18 pm    Post subject: Re: Steering column safety PSA Reply with quote
Not sure this is true. The shear bolts are designed to shear the head off in installation,leaving the cones as an anti-theft device. Have no idea what strength bolt should be used when the shear bolts are replace.
Basilbomb
PostPosted: Fri Jan 03, 2020 2:21 pm    Post subject: Re: Steering column safety PSA Reply with quote
I agree with you re seatbelts, but you are compromising the column release mechanism if you replace the conical bolts. if you mount the column with regular bolts, it can't pop down and disengage as it is intended if you strike the wheel with enough force. That's why they are those specialty bolts instead of just regular hardware.
?Waldo?
?Waldo? is offline
PostPosted: Fri Jan 03, 2020 2:26 pm    Post subject: Re: Steering column safety PSA Reply with quote
Basilbomb, what supporting source documentation do you have that the bolt design is for the reason you state? Please post it. I do not believe that to be true although I have seen is stated before. I have never seen any supporting documentation and would be inclined to change my view if given some.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Fri Jan 03, 2020 3:14 pm    Post subject: Re: Steering column safety PSA Reply with quote
So, what are the options?
Dremel a straight line across and try a screwdriver to remove and reinstall after work? Would that also change the intended safety properties?
Weld a nut on? Again, strength change? My welds seem really hard, lots harder than the steel I had previously ground down to prep for welding..
Or, at they available on the market somewhere?
-bobby
Basilbomb
PostPosted: Fri Jan 03, 2020 5:06 pm    Post subject: Re: Steering column safety PSA Reply with quote
-bobby
Ive always just reused them, putting them on the same way I got them off, with vise grips. They might not be torqued exactly, but unless you have the OEM tool used to install them, you're kind of out of luck.
T3 Pilot
T3 Pilot is offline
PostPosted: Fri Jan 03, 2020 5:21 pm    Post subject: Re: Steering column safety PSA Reply with quote
https://www.vancafe.com/211415549B-p/211415549b.htm
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
kamzcab86
kamzcab86 is offline
PostPosted: Fri Jan 03, 2020 5:24 pm    Post subject: Re: Steering column safety PSA Reply with quote
Yep.
Edit: Beaten to the link!
~Kamz Anxious
2016 Golf GTI S
Basilbomb
PostPosted: Fri Jan 03, 2020 5:32 pm    Post subject: Re: Steering column safety PSA Reply with quote
That would be internal engineering at VW, but it really stands to reason when you examine it:
First of all, legislation requires the a steering column must collapse when struck by the driver's chest so that the force on the chest doesn't exceed a certain threshold. This threshold is quite low: you should be be able to break away the steering wheel column without serious injury to the chest.
Second, you can see how the upper steering column is designed to push downwards and disengage from the lower steering shaft. The only way this can happen is if the cone bolts release. in case of accident the entire upper steering column will be completely broken away from both its supporting elements.
Third, there's nothing else like the cone bolts in these vehicles.
Fourth, those cone bolts are very soft. You can tell when you put vice grips on them, how much they dig in and score the metal. Obviously they aren't very strong.
Fifth, The steering column is bolted to a strong piece of structural reinforcing metal. If the steering column was bolted to this with ordinary fasteners, it's hard to see a person's chest hitting the wheel would be sufficient to bend this frame or the steering column without injury.
The only other way I could see this system working is if that section of the mounting frame is specifically engineered to distort under impact load, and that would be far more expensive than just installing a couple of break-away bolts. And personally, it looks far too robust for that.
vwwestyman
vwwestyman is offline
PostPosted: Fri Jan 03, 2020 9:45 pm    Post subject: Re: Steering column safety PSA Reply with quote
Interesting, I've encountered these type bolts in other 80s VWs.
Seems like this could be fairly easily resolved (or at least we'd get some clues) by observing some pics of crashed Vanagons and attempting to determine how many times the bolts broke by the position of the column.
Dave Cook
1973 Wild Westerner
My Thing
syncrodoka
syncrodoka is online now
PostPosted: Fri Jan 03, 2020 10:03 pm    Post subject: Re: Steering column safety PSA Reply with quote
The rag joints will fail, that is the breakaway you are thinking of.
The shear bolt snaps off the allen head when it is torqued to spec. If this bolt was designed to fail once it is installed it would be undercut giving it a place to fail, it does not have this. It isn't a "cone bolt", you are looking at the remnants of where the allen head sheared off.
PSA crisis averted
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Fri Jan 03, 2020 10:12 pm    Post subject: Re: Steering column safety PSA Reply with quote
I've pulled quite a few of these cone-bolts, and they all appear to be a regular grade 8.8 bolt with a funny head.
If you want a mushy bolt to replace them with, late model BMWs use aluminum hardware on their engines. They feel like they're gonna shear every time you put a socket to em.
Casey--
'01 Weekender --> full camper
y u rune klassik?
newerwesty1987
newerwesty1987 is offline
PostPosted: Fri Jan 03, 2020 10:41 pm    Post subject: Re: Steering column safety PSA Reply with quote
To reinforce Doka's post, a "Shear Bolt" of this type is called that because, like he basically said, it's designed to shear off at a given torque spec. In this case, it is for theft prevention. It has nothing to do with the bolt's grade rating or safety.
danfromsyr
PostPosted: Fri Jan 03, 2020 10:45 pm    Post subject: Re: Steering column safety PSA Reply with quote
they pivot forward like this by design
one of our own here survived this with minor injury.
the nice thing of a vanagon is the floor height and that the occupant isn't sitting down underneath the dashboard. where you'd get trapped in a conventional vehicle.
danfromsyr
PostPosted: Fri Jan 03, 2020 10:48 pm    Post subject: Re: Steering column safety PSA Reply with quote
ok heres better pics and direct experience dialogue
PDXWesty wrote:
Here's another photo of a van that shows almost the same deformation. The drivers compartmant is completely intact while the front and rear of the van crumpled. Notice the drivers side glass is still there too.
Here's a shot inside the cab after the crash. There was still plenty of room for the driver. The passenger side is mostly undamaged. The protective cage did it's job. After it happened, I was scared to look down at my feet fearing a bloody mess since I was barefoot. Luckily I barely had a scratch on me.
You can see in the next shot how the floor crumpled.
Here you can clearly see that the steering shaft broke away where it was designed to break. The bottom of the steering column was pushed towards the driver while the steering wheel pivoted away from the driver. The bolts everyone calls "sheer bolts" are intact and become the pivot point for the column. My flip flops are still in the position they were at the moment of the crash. Right foot on the gas and left under the clutch.
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jan 03, 2020 11:20 pm    Post subject: Re: Steering column safety PSA Reply with quote
This has been a part of mistaken Vanagon lore for as long as I've owned one. The word "shear" implies the bolts are designed to shear off in a crash to many people. They are not. It's just a security device to prevent vehicle theft. I was a part of vehicle design for many years. I have also taken a few of these off over the years and they are just a plain threaded bolt with a funny head as stated above. Ironically, I have never had trouble getting them loose in mere seconds using what everyone else does - vice grips.
Thanks for bringing it up, however. it is always good to clarify things that need it and this was one. Nobody should get their nose out of joint - it's been repeated a lot.
Witness the incorrect theory that old rubber brake lines can cause a brake piston to stick by holding pressure on the caliper. Not happening, yet it gets repeated here and all over the internet on car forums.
vanagonjr
vanagonjr is offline
PostPosted: Sat Jan 04, 2020 5:29 am    Post subject: Re: Steering column safety PSA Reply with quote
Ditto.
Also, there are typically shear pins within the steering column to break. I would think one absolutely does not want the top of the column to break loose, then it is really could be a safety hazard.
But at Waldo said, I.m open to changing my mind with supporting documentation.
danfromsyr
PostPosted: Sat Jan 04, 2020 8:53 am    Post subject: Re: Steering column safety PSA Reply with quote
Ooooohh boy, now yer wrong Razz
have had the behavior even after replacing the caliper with a new one.
I've had that happen to 2 vehicles. in fact it;s SOP now to just replace the inexpensive rubber lines when replacing/rebuilding calipers.
a caliper piston returns only from the twisted force of the square O-ring.. it doesn't take much to interfere with that action and limit it's rebounding motion
https://www.quora.com/What-causes-a-brake-piston-to-retract
Curtis McCully, Fleet Systems Analyst
Answered Aug 19, 2018 ยท Author has 293 answers and 319k answer views
Originally Answered: What causes disc brake calipers to retract when you take your foot off the brake pedal?
The caliper piston seal is square. When the brakes are applied the seal deforms slightly as shown in arrow 2 in the image below. When you take you foot off the pedal, fluid pressure disapears and the square o ring pulls the piston back away from the brake pads. Obviously, this is only a slight movement but it is enough to keep the brakes from dragging.
hdenter
hdenter is offline
PostPosted: Sat Jan 04, 2020 9:17 am    Post subject: Re: Steering column safety PSA Reply with quote
I have seen 30+ vanagon wrecks with front end damage. Not one of them had those bolts sheared off. Those bolts provide the pivot point that rotates the steering wheel away from the driver. The column is disconnected when a strong enough force applied to the bumper area forces the lower portion of the column up and disconnects it from the upper section. The previous pictures are text book examples of how the steering column works.
Hans
'79 triple white convertible bug
'84 sunroof vanagon
'85 weekender
Page 1 of 5
