Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Wed Jan 15, 2020 1:41 pm Post subject: Show off your Crank Triggers!! |
I’m mainly looking for examples of trigger wheels that came off of production cars but customs ones are ok too. And yes, i know there is quite a bit of info but most of them seem to be bought kits from places like CB, etc.
Thanks |
slalombuggy Samba Member
Posted: Wed Jan 15, 2020 2:05 pm Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! |
Ya, it's store bought from CB. But for the amount of fking around chasing and modifying parts....my time is worth more than the kit is worth. I installed everything in 20 minutes if the engine would have been running at the time I could have had it fired up in under an hour if all I was installing was the crank trigger ignition.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79434 Location: Sneaking up behind you
Posted: Wed Jan 15, 2020 2:12 pm Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! |
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3508 Location: Charleston, SC
Posted: Wed Jan 15, 2020 3:30 pm Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! |
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Wed Jan 15, 2020 4:01 pm Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! |
That's a cool one. Out of curiosity, what technique did you use to get the trigger wheel perfectly centered? Also, I'm so going to copy that CPS bracket. KEEP THEM COMMING
Thanks |
Posted: Wed Jan 15, 2020 4:36 pm Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! |
Chickensoup wrote: |
Out of curiosity, what technique did you use to get the trigger wheel perfectly centered? |
This was before I had a DRO; I used a rotary table on my mill to drill the pulley and trigger wheel. Once the two were mated, I then cleaned it up on the lathe.
With the DRO, the only thing I'd do differently is just indicate the pulley (and, separately, the trigger wheel), punch in the PCD and # holes into the DRO and drill away. (and clean it up on the lathe, once the two are mated together) _________________
66brm wrote: |
Bodacious wrote: |
Onceler Samba Member
Posted: Wed Jan 15, 2020 5:16 pm Post subject: Re: Show off your Crank Triggers!! |
Here’s a wheel off a 4.6 Ford I think. I was going to use it to replace the generic one I had but never got around to it. The one I did use I just scribed a x pattern, measured as best I could, then drilled. Then mounted an indicator and tapped it around until it was centered, before tightening down. Then fabbed up a mount for the sensor. Sorry no pic.’s of finished assembly. Kinda hillbilly but it ran great.
_________________ 1972 Karmann Ghia |
oprn Samba Member
Joined: November 13, 2016 Posts: 14717 Location: Western Canada
Posted: Wed Jan 15, 2020 6:00 pm Post subject: Re: Show off your Crank Triggers!! |
I had plans to use a bicycle sprocket with the right number of teeth, drill and mount it on my type 4 engine, make a bracket to mount the sensor... then I priced the parts from the Dub Shop... bolt on and at a price that just erased the home grown idea out of my mind. All the hard work done and proven, works flawlessly!
kadub Samba Member
Joined: November 04, 2004 Posts: 444 Location: Auburn, Wa
Posted: Wed Jan 15, 2020 7:32 pm Post subject: Re: Show off your Crank Triggers!! |
The Dub Shop is definitely the place to go for all things crank trigger. Mario machined the back of my CB dry sump pulley and installed a "hidden" trigger wheel for me. Easy install, zero problems.
_________________ Karl
aka Turbobaja |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Wed Jan 15, 2020 7:55 pm Post subject: Re: Show off your Crank Triggers!! |
One one I used the 4.6 wheel and on the other I used the cheap stamped ford wheel
_________________ 1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
1965 Chevy c30, Microsquirt turbo aluminum 5.3/nv4500 |
tzepesh Samba Member
Posted: Thu Jan 16, 2020 12:58 am Post subject: Re: Show off your Crank Triggers!! |
Here is mine. Trigger wheel from a Ford Escort, combined with EDIS4 and Megajolt. Ugly install, but I will replace it with a set from Mario @thebubshop. On the type4 I have another set from Mario, great design, nicely hidden.
_________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2875 Location: Little Britain
Posted: Thu Jan 16, 2020 5:41 am Post subject: Re: Show off your Crank Triggers!! |
tzepesh wrote: |
HA, its not that your install wasn’t clean, its that your poor little vdub is dirty as hell!  |
Posted: Thu Jan 16, 2020 6:01 am Post subject: Re: Show off your Crank Triggers!! |
Guilty as charged. That will change in the next iteration, because the Bug is now under re-construction. I say ugly install because I complicated things too much: initially I had TPS (although the bracket was not too nice, at least not visible), then I changed to MAP and this involved adding pipes from each manifold to the vacuum chamber on top of the shroud, then going to the MJ. I first tried urethane pipes but they were not good for heat and vacuum, so I changed to copper pipes as a quick and dirty fix.
But as I am building my type4 with MS2 Extra, I can transplant everything to this 1.6 engine if needed, and I will keep it nice and clean. I also tidied the wiring. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20802 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jan 16, 2020 8:57 am Post subject: Re: Show off your Crank Triggers!! |
Make it easy on yourself...
https://www.cbperformance.com/product-p/2092.htm
Or..
https://www.cbperformance.com/product-p/2093.htm
And move on to ECU...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Thu Jan 16, 2020 9:08 am Post subject: Re: Show off your Crank Triggers!! |
Maybe one day on a later build  |
Posted: Thu Apr 02, 2020 10:53 am Post subject: Re: Show off your Crank Triggers!! |
I’m reviving my thread instead of making a new one to help keep things neat here. So, I’m looking into the ford 4.6 trigger wheels and cant find any for sale that look like the ones mentioned previously here. Can someone please point me in the right direction?
Thank you _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
DeathBySnuSnu Samba Member
Posted: Thu Apr 02, 2020 11:11 am Post subject: Re: Show off your Crank Triggers!! |
I got mine off ebay.....was advertised as for an escort.
I made the custom pulley and hub.
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Thu Apr 02, 2020 1:28 pm Post subject: Re: Show off your Crank Triggers!! |
oh I see now, those kinds of crank triggers..... Im glad I saw the car parts before I posted a pair of "crank trigger's"  |
