Show off your Crank Triggers!!
Chickensoup
Chickensoup is offline
PostPosted: Wed Jan 15, 2020 1:41 pm    Post subject: Show off your Crank Triggers!! Reply with quote
I’m mainly looking for examples of trigger wheels that came off of production cars but customs ones are ok too. And yes, i know there is quite a bit of info but most of them seem to be bought kits from places like CB, etc.
Thanks
slalombuggy
slalombuggy is offline
PostPosted: Wed Jan 15, 2020 2:05 pm    Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! Reply with quote
Ya, it's store bought from CB. But for the amount of fking around chasing and modifying parts....my time is worth more than the kit is worth. I installed everything in 20 minutes if the engine would have been running at the time I could have had it fired up in under an hour if all I was installing was the crank trigger ignition.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jan 15, 2020 2:12 pm    Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! Reply with quote
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
TinCanFab
TinCanFab is offline
PostPosted: Wed Jan 15, 2020 3:22 pm    Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! Reply with quote
Dub shop trigger wheel on the back of a BMD serpentine pulley. Drilled and tapped wheel onto pulley myself, home made brakcket, crank sensor and harness is from a junk 2005 Ford Focus
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
Stripped66
Stripped66 is offline
PostPosted: Wed Jan 15, 2020 3:30 pm    Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! Reply with quote
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
Chickensoup
PostPosted: Wed Jan 15, 2020 4:01 pm    Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! Reply with quote
Stripped66 wrote:
That's a cool one. Out of curiosity, what technique did you use to get the trigger wheel perfectly centered? Also, I'm so going to copy that CPS bracket. KEEP THEM COMMING Very Happy
Thanks
Stripped66
PostPosted: Wed Jan 15, 2020 4:36 pm    Post subject: Re: SHOW OFF YOUR CRANK TRIGGERS!! Reply with quote
This was before I had a DRO; I used a rotary table on my mill to drill the pulley and trigger wheel. Once the two were mated, I then cleaned it up on the lathe.
With the DRO, the only thing I'd do differently is just indicate the pulley (and, separately, the trigger wheel), punch in the PCD and # holes into the DRO and drill away. (and clean it up on the lathe, once the two are mated together)
Onceler
Onceler is offline
PostPosted: Wed Jan 15, 2020 5:16 pm    Post subject: Re: Show off your Crank Triggers!! Reply with quote
Here’s a wheel off a 4.6 Ford I think. I was going to use it to replace the generic one I had but never got around to it. The one I did use I just scribed a x pattern, measured as best I could, then drilled. Then mounted an indicator and tapped it around until it was centered, before tightening down. Then fabbed up a mount for the sensor. Sorry no pic.’s of finished assembly. Kinda hillbilly but it ran great.
1972 Karmann Ghia
oprn
oprn is offline
PostPosted: Wed Jan 15, 2020 6:00 pm    Post subject: Re: Show off your Crank Triggers!! Reply with quote
I had plans to use a bicycle sprocket with the right number of teeth, drill and mount it on my type 4 engine, make a bracket to mount the sensor... then I priced the parts from the Dub Shop... bolt on and at a price that just erased the home grown idea out of my mind. All the hard work done and proven, works flawlessly!
kadub
kadub is offline
PostPosted: Wed Jan 15, 2020 7:32 pm    Post subject: Re: Show off your Crank Triggers!! Reply with quote
The Dub Shop is definitely the place to go for all things crank trigger. Mario machined the back of my CB dry sump pulley and installed a "hidden" trigger wheel for me. Easy install, zero problems.
Karl
aka Turbobaja
Krochus
Krochus is offline
PostPosted: Wed Jan 15, 2020 7:55 pm    Post subject: Re: Show off your Crank Triggers!! Reply with quote
One one I used the 4.6 wheel and on the other I used the cheap stamped ford wheel
1970 Turbo Baja Bug Turbaja 2165 t3/t4 Speeduino sequential EFI LS3 coil on plug ignition
1965 Chevy c30, Microsquirt turbo aluminum 5.3/nv4500
tzepesh
tzepesh is offline
PostPosted: Thu Jan 16, 2020 12:58 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
Here is mine. Trigger wheel from a Ford Escort, combined with EDIS4 and Megajolt. Ugly install, but I will replace it with a set from Mario @thebubshop. On the type4 I have another set from Mario, great design, nicely hidden.
'74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Korosi red (extra glitter)
UK Luke 72
UK Luke 72 is offline
PostPosted: Thu Jan 16, 2020 1:06 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
I think this is about the best solution I've found from VW Speedshop in the UK.
https://vwspeedshop.com/product.php?productid=16774&cat=507&page=1
The pulley can be changed from std vee, to power pulley or serpentine belt pulley leaving the trigger wheel and hub untouched.
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
Chickensoup
PostPosted: Thu Jan 16, 2020 5:41 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
HA, its not that your install wasn’t clean, its that your poor little vdub is dirty as hell! Very Happy
tzepesh
tzepesh is offline
PostPosted: Thu Jan 16, 2020 6:01 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
Very Happy Guilty as charged. That will change in the next iteration, because the Bug is now under re-construction. I say ugly install because I complicated things too much: initially I had TPS (although the bracket was not too nice, at least not visible), then I changed to MAP and this involved adding pipes from each manifold to the vacuum chamber on top of the shroud, then going to the MJ. I first tried urethane pipes but they were not good for heat and vacuum, so I changed to copper pipes as a quick and dirty fix.
But as I am building my type4 with MS2 Extra, I can transplant everything to this 1.6 engine if needed, and I will keep it nice and clean. I also tidied the wiring.
Dale M.
Dale M. is offline
PostPosted: Thu Jan 16, 2020 8:57 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
Make it easy on yourself...
https://www.cbperformance.com/product-p/2092.htm
Or..
https://www.cbperformance.com/product-p/2093.htm
And move on to ECU...
Dale
Chickensoup
PostPosted: Thu Jan 16, 2020 9:08 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
Or..
Dale
Maybe one day on a later build Smile
Chickensoup
PostPosted: Thu Apr 02, 2020 10:53 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
I’m reviving my thread instead of making a new one to help keep things neat here. So, I’m looking into the ford 4.6 trigger wheels and cant find any for sale that look like the ones mentioned previously here. Can someone please point me in the right direction?
Thank you
'65 Tourist Delivery Build
'66 RIP
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Thu Apr 02, 2020 11:11 am    Post subject: Re: Show off your Crank Triggers!! Reply with quote
I got mine off ebay.....was advertised as for an escort.
I made the custom pulley and hub.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
mark tucker
mark tucker is offline
PostPosted: Thu Apr 02, 2020 1:28 pm    Post subject: Re: Show off your Crank Triggers!! Reply with quote
oh I see now, those kinds of crank triggers..... Im glad I saw the car parts before I posted a pair of "crank trigger's" Shocked Rolling Eyes Shame on you Popcorn Dancing d'oh!
