Betty White the '68 Squareback (Build Thread)
Page: 1, 2, 3, 4  Next
tbb
tbb is offline
PostPosted: Mon Mar 30, 2020 12:42 pm    Post subject: Betty White the '68 Squareback (Build Thread) Reply with quote
This is Betty White the '68 Squareback. Purchased from a dealer in Santa Monica, CA in 1967 she's lived in Southern California for all of her life. She's been sitting for the past 10+ years and needs quite a bit of work.
So far, I've replaced all the fuel lines with high-pressure lines, filter and pump have been also been replaced with Airtex2000.
This is my first time working on a car as I've always been a bicycle nut, but am having fun so far! I've been studying my Bentley brown book to get a better understanding of the systems within and things are beginning to click in my brain.
I've come across my first issue, no power seems to be going to any of the 4 fuel injectors. I've cleaned them out while hooked up to a power source and they all function well. Does anyone know why they aren't getting power? Or could anyone point me to a thread with the info I need?
Thank you!
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Mar 30, 2020 1:05 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Betty White is a legend!
Well, if you are sheltered at home with time to kill, maybe you can work your way through this (all 243 pages!):
https://www.thesamba.com/vw/forum/viewtopic.php?t=21015
Best advice is to resist the temptation to throw new parts at the problem. That will be expensive and probably won't fix it.
I'm not sure how you determined there is "no power" to the injectors. The pulse is too short for most meters (on the order of 50 milliseconds), and the problem can be as simple as lack of grounds in the other injector wires.
What manuals you have? The Muir "Idiot" book is good for the basics (though it gets much wrong on later models of the Type 3 FI, it's adequate and a simple start for your early model).
Start by checking out all resistances in your wiring The Idiot book covers this, and then study and learn how to re-crimp connectors with OEM-style terminals. Resistances foul the FI, and between wiring and vacuum leaks, explain 95% of all "FI problems." Not glamorous, but critical!
The Bentley manual is comprehensive and worthwhile for any repairs.
There are also some literature and troubleshooting guides on the Samba:
https://www.thesamba.com/vw/archives/manuals/elfri...dition.pdf
http://www.vwtype3.org/literature/clymer/service/Clymer.1972.07.pdf
https://www.thesamba.com/vw/archives/manuals/fi_ma...acific.pdf
https://www.thesamba.com/vw/archives/manuals/fi_se...0Check.pdf
Bobnotch
Bobnotch is offline
PostPosted: Mon Mar 30, 2020 1:44 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
In that list KTPhil made, the Elfrink manual will be the most help, as it even has wiring diagrams in it for the different years D-Jet FI was available for. Between it, and the FI sticky thread, you should be able to get it working. If not, ask here.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Mon Mar 30, 2020 2:37 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
FYI you're missing a big piece(s) of your cooling air intake.
QRP
QRP is offline
PostPosted: Mon Mar 30, 2020 4:01 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
I was just gonna say that . . Razz
Valley Glen . . We're practically neighbors.
tbb
tbb is offline
PostPosted: Mon Mar 30, 2020 5:41 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Turns out the injectors are in fact working and the engine was able to turn over! Sounds a little rough at idle, but smooths out at higher rpms. Below is a link to a video of Betty White running for the first time in a looooong time. Anybody have any thoughts on how the engine sounds?
Link --> https://youtu.be/2dvMU45b4RI
Mike Fisher
Mike Fisher is offline
PostPosted: Tue Mar 31, 2020 7:36 am    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Clean the crud off your trigger point contacts. You can pull the distributor out without disturbing your timing to remove/clean them by dragging a business card between both sets of contacts.
Blow air through your metal fuel return line. It can get plugged up with disastrous results! BTDT
Buy a water pressure gauge at home depot to set your fuel pressure at 28lbs for an initial setting.
Don't buy new parts until you test & know you need them!
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
tbb
tbb is offline
PostPosted: Sun Apr 05, 2020 10:47 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Thanks guys! I cleaned trigger points, and blew air through my return lines. Checked fuel pressure and its a bit over 30 psi. Should I bring it down to 28?
Aaaaaaaand a couple more issues have arisen.
1. One of the injectors is leaking pretty badly. Fuel is pooling up around the electrical connections and dripping at higher rpm. Is it possible to rebuild or salvage?
2. Strange things are happening with the air system. when the pressure sensor hose is connected to the intake manifold, the engine begins to sputter and lose power. Similarly, when the cold start is plugged in the engine will lose power, then return, lose power, then return. If I disconnect both the cold start and hose to intake manifold, it seems to run well. Any thoughts as to why they don't want to play nice?
Thanks again
Clatter
Clatter is offline
PostPosted: Mon Apr 06, 2020 8:40 am    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Having injectors serviced is very common,
And fortunately done to may cars and trucks besides ours.
They might call it a 'clean and flow test', or 'flow balance' or..?
Big-rig semi truck places do it a lot as part of routine maintenance,
and for good reasons...
A nice fine atomization with even flow makes for a more efficient engine.
One of the top places online for cars is a place called Witch Hunter.
I had mine done at a Peterbuilt place in Salinas.
They did make fun of my small injectors. Wink
I'll put this operation up towards the top of the list.
It's hard to tune a motor if the injectors are clogged up and spitting..
Bus Motor Build
It does not exist!
KTPhil is offline
PostPosted: Mon Apr 06, 2020 9:24 am    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Leaking at the connector probably can't be fixed, so look for a replacement. If its leaking at the short hose segment, the hose can be replaced.
The behavior with the cold start valve implies it may be stuck open. You really don't need it. Remove and plug the gas line.
The issue with the hose is more serious... can you explain it again? Have you checked the hose and MPS for leaks?
How is the hose to the AAR, and is that working properly?
tbb
tbb is offline
PostPosted: Mon Apr 06, 2020 1:32 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
What is an MPS and AAR? And any recommendations to where i can purchase an injector?
Bobnotch
Bobnotch is offline
PostPosted: Mon Apr 06, 2020 2:10 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
The MPS is the Manifold Pressure Sensor. It senses vacuum though. The AAR is the Aux Air Regular, and is like a choke on a carbed engine. Ideally you want to get the part numbers off the MPS, and let us know if it's the right one, as several were used over the years. You want a 311 part number that ends with either an A or B. If you have a different number and suffix, then it's the wrong part.
Tram wrote:
Tram wrote:
tbb
tbb is offline
PostPosted: Tue Apr 07, 2020 12:20 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Pulled the part number off the MPS --> "311 906 051 B"
The engine is having a tough time starting when cold without a little help. When I spray a little starter into the manifold and she'll start and idle fine. And once warm she'll start up just fine without any starter fluid. But when the air hose is connected to the MPS, she won't start at all or once started, will quickly lose RPM. Below is a link to a video of attaching and detaching the hose. Anybody know why the engine is acting this way?
Video --> https://youtu.be/wH3AGnPHRd4
KTPhil is offline
PostPosted: Tue Apr 07, 2020 12:52 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
With the hose disconnected you have a massive vacuum leak in the plenum (IAD). If it runs better this way, then the engine is starved for air.
Try opening up the idle speed adjustment on the IAD (essentially a large vacuum leak in itself!). Loosen the 15mm nut, and unscrew the stud to allow more bypass air until it idles okay with the MPS hose re-attached.
That MPS has been adjusted, based on the wear on the screw slot. It may not be adjusted RIGHT, so at some point when you have eliminated all else, it can be adjusted, but that's for another day.
tbb
tbb is offline
PostPosted: Tue Apr 07, 2020 3:41 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Opened up the idle speed adjustment but am still having issues keeping the engine idling when connected to the MPS.
To test if my issue is purely a matter of airflow, I plugged up the hose which connects to the MPS. The engine slows down at idle but doesnt react in the same way as when connected to the MPS itself.
Here is a video --> https://youtu.be/whiKCSzg5jw
What does the MPS do with the information it receives? Basically, what commands does the MPS give the ECU when it senses different levels of pressure? I'm thinking the MPS is giving incorrect commands. Is it possible that the MPS is telling the ECU to decrease how much power is going to the injectors which is what is decreasing idle RPM? And what happens when the flathead screw on the MPS is adjusted? Thank you Smile
KTPhil is offline
PostPosted: Tue Apr 07, 2020 4:53 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Check the MPS electrically (most manuals give the proper resistances pin by pin) and check that it holds vacuum.
The MPS is the heart of the system. It's circuits determine mixture throughout all driving conditions. If it isn't right, there are no band-aids to make it run right.
If it passes electric and vacuum tests, then it's been mis-adjusted badly. But again, it's the last thing you adjust. if it's wrong, someone probably adjusted it first, and then other fixes left it is the wrong state of adjustment.
Check for ANY AND ALL vacuum leaks, check electrically, and then give it a good tune-up first.
Bobnotch
Bobnotch is offline
PostPosted: Wed Apr 08, 2020 10:56 am    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Keep in mind you have the revised early MPS, and there should also be a vac can under the right side (passenger side in the USA) air tubes on the engine, along with an electrical plug. Those parts are for the injection system too, and act like an accelerator pump. It needs good vacuum hose too. It really sounds like your AAR isn't opening when the engine is cold. It's supposed to be open then, and slowly close as the engine warms up.
Tram wrote:
Tram wrote:
tbb
tbb is offline
PostPosted: Wed Apr 08, 2020 6:28 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Checked the electrical connections on the MPS today and the outer plugs read about 350 ohms and the inner read about 90. I believe that's good?
Saw the port for the hose was a bit oily so I opened it up the MPS and it was swimming in oil. Shocked Is there supposed to be this much oil?
And how do I check if my AAR is closed when the engine is cold?
KTPhil is offline
PostPosted: Wed Apr 08, 2020 10:52 pm    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
I've never seen one with that much oil. I'd remove all hoses for the IAD (plenum) and make sure the rest aren't full of oil, too.
What manuals do you have?
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 09, 2020 11:35 am    Post subject: Re: Betty White the '68 Squareback (Build Thread) Reply with quote
Agreed. Never that much oil.
As for checking the AAR, you can blow thru the hose going to the air cleaner. If it doesn't pass any air, it's closed. When cold, it should be open (note: they are adjustable), and pass air fairly easy.
Agreed, what manuals do you have. Since you have a 68, you should look for a Brown Bentley manual (on e-bay, or book 4 less, or some such site). I think Mike Fisher knows of a couple of sites as well.
Tram wrote:
Page 1 of 4
