| best place |
| under the car next to the transder the nose of the car |
45% |
[ 5 ] |
| under the nose of the car |
9% |
[ 1 ] |
| somewhere else |
36% |
[ 4 ] |
| behind the kamei |
9% |
[ 1 ] |
| Total Votes : 11 |
MitchS046 Samba Member
Posted: Thu Apr 30, 2020 6:59 am Post subject: best place for an remote mounted oil cooler |
| I recently came in possession of a Gol cooling kit that I want to mount on an 1915 engine I'm going to build somewhere next year. I know they have a really tiny oil cooer but as I don't have it I want to go remote mounted. I don't really know where the best place is to put it. under the car next to the trans? behind my kamei frond lip? somewhere under the nose of the car? the car is a euro spec 1973 1303 known in the use as super beetle's. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1064 Location: St. Louis, Mo
Posted: Thu Apr 30, 2020 8:42 am Post subject: Re: best place for an remote mounted oil cooler |
Keep it in the back. You don't want all that oil line going to the front of the car and back. Placing the cooler over or next to the transaxle will do fine, if you even need it. IDK where you are located, but under normal driving conditions, a stock doghouse oil cooler will be adequate for a 1915. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
| skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out  |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 2075 Location: North Carolina
Posted: Thu Apr 30, 2020 8:43 am Post subject: Re: best place for an remote mounted oil cooler |
| Under the package tray, above the transaxle |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80472 Location: Sneaking up behind you
Posted: Thu Apr 30, 2020 8:45 am Post subject: Re: best place for an remote mounted oil cooler |
| MitchS046 wrote: |
| I recently came in possession of a Gol cooling kit |
Don't use it, its designed for a forward facing front engine and they have been proven not to cool adequately in a rear engine car. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Apr 30, 2020 8:46 am Post subject: Re: best place for an remote mounted oil cooler |
| kangaboy wrote: |
| a stock doghouse oil cooler will be adequate for a 1915. |
i want to use the gol cooler just for the looks and thought to keep the temps down to go with the remote mounted cooler _________________ Slow is smooth, smooth is fast,
~ mark divine |
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1386 Location: Southern California
Posted: Thu Apr 30, 2020 8:51 am Post subject: Re: best place for an remote mounted oil cooler |
They work if you buy the right one and keep the lines short. I put mine drivers side under package tray. Filter under driver fender. Look up CBR dual pass cooler.
_________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
Posted: Thu Apr 30, 2020 9:52 am Post subject: Re: best place for an remote mounted oil cooler |
| ivkings4 wrote: |
did you do all plumbing in AN lines? isn't that a bit overkill and expensive? _________________ Slow is smooth, smooth is fast,
~ mark divine
vandenabeele andries Samba Member
Posted: Thu Apr 30, 2020 10:07 am Post subject: Re: best place for an remote mounted oil cooler |
Above the tranny. The shorter your lines the better.
Best regards |
Posted: Thu Apr 30, 2020 10:09 am Post subject: Re: best place for an remote mounted oil cooler |
| vandenabeele andries wrote: |
Best regards |
hey Andries hoe bedoel je boven de versnellingsbak? is daar überhaupt plek voor? _________________ Slow is smooth, smooth is fast,
~ mark divine |
rens040 Samba Member
Joined: August 10, 2015 Posts: 80 Location: Netherlands
Posted: Thu Apr 30, 2020 10:32 am Post subject: Re: best place for an remote mounted oil cooler |
Does it get enough cool air above the transmission?
What is the downside of longer lines but more cool air on let’s say a front mounted oil cooler? |
Posted: Thu Apr 30, 2020 10:35 am Post subject: Re: best place for an remote mounted oil cooler |
| rens040 wrote: |
that is what I also was wondering as the 911 from that era also had their oil coolers up frond also you have a lot more oil in your system _________________ Slow is smooth, smooth is fast,
~ mark divine |
Posted: Thu Apr 30, 2020 11:23 am Post subject: Re: best place for an remote mounted oil cooler |
Long lines = dry starts. The lines are about 40 each. Well worth the piece of mind. How much is a new engine when your oil line bursts?? _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
Posted: Thu Apr 30, 2020 11:25 am Post subject: Re: best place for an remote mounted oil cooler |
| ivkings4 wrote: |
| Long lines = dry starts. |
but why did almost all rear engined cars from that era have oil coolers in the frond? and couldn't that be fixed with an electric oil pump that primes the oil system just before you start the engine like an electric fuel pump? _________________ Slow is smooth, smooth is fast,
~ mark divine |
Posted: Thu Apr 30, 2020 11:47 am Post subject: Re: best place for an remote mounted oil cooler |
Dont see the dry start either.
The thermostate and filter can be located close to the engine.
So When cold you have a short circuit.
Only when warmed up oil will flow to the cooler.
Well not entirely as most thermostats let some flow to the cooler even when cold... |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
| MitchS046 wrote: |
| ivkings4 wrote: |
did you do all plumbing in AN lines? isn't that a bit overkill and expensive? |
AN fittings have advantages and dont always have to be expensive. You can use cheap brass pushlock fittings w/rubber hose, anodized aluminum pushlock, braided hose with screw together aluminum fittings, or fully crimped Teflon hose like in his pics. Viking is running one of the most expensive type 1 NA race motors you can build that will fit into a street car. In his case, the cost is justified. _________________ Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092 |
slalombuggy Samba Member
Posted: Thu Apr 30, 2020 1:17 pm Post subject: Re: best place for an remote mounted oil cooler |
You guys referencing 911s fail to take into account that system was a drysump system that held 11-14 liters of oil.
I spent over $500 on AN fittings on my turbo engine. Cheap insurance. |
Nightshift Samba Member
Posted: Thu Apr 30, 2020 1:28 pm Post subject: Re: best place for an remote mounted oil cooler |
| MitchS046 wrote: |
It is just not needed in your climate or with your engine. Just because you have it does not mean you need to use it. I actually removed my remote cooler. |
Vioflita1286 Samba Member
Posted: Thu Apr 30, 2020 9:40 pm Post subject: Re: best place for an remote mounted oil cooler |
| MitchS046 wrote: |
This is where I put it. What do you think? |
wheel607 Samba Member
Posted: Fri May 01, 2020 1:48 am Post subject: Re: best place for an remote mounted oil cooler |
[quote="slalombuggy"]You guys referencing 911s fail to take into account that system was a drysump system that held 11-14 liters of oil.
I spent over $500 on AN fittings on my turbo engine. Cheap insurance.[/quote
They have no idea that they are talking about a dry sump system that holds 12 quarts of oil. Apples and oranges. |
Posted: Fri May 01, 2020 4:40 am Post subject: Re: best place for an remote mounted oil cooler |
That is a remote filter... where is the cooler? Or am I missing something? Why the extra loop in the lines? _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
