Joined: August 31, 2013 Posts: 13286 Location: North Carolina
Posted: Mon Apr 15, 2019 6:57 am Post subject: Re: My new 59 Ragtop. |
This price looks like a tune-up on a modern car.
Can anyone imagine plunking down 1/5 the cost of a modern car these days? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
stale air Samba Member
Joined: August 23, 2007 Posts: 5656 Location: Senoia Ga, formerly NorCal
Posted: Mon Apr 15, 2019 9:54 am Post subject: Re: My new 59 Ragtop. |
Malanthius wrote: |
ZEKE65 wrote: |
No hair board stuck to the floor pans? Wonder when they started that. My 65 took a day of scraping to get to the floor boards. Beautiful car! Nice find. |
right? Check out the battery tray!
That is exactly what your floor boards are supposed to look like. And, your car looks super dry, so congrats.
Keep up the good work, and keep the updates coming.  _________________ WANTED: Henry Veale Santa Rosa plate frames
Malanthius Samba Member
Joined: July 09, 2009 Posts: 211 Location: Palmdale, ca
Posted: Tue Apr 16, 2019 8:40 pm Post subject: Re: My new 59 Ragtop. |
Started restitching my rear seat top. Threading has started to deteriorate. but leatherette is still soft! Plastic piping is also mostly soft. There are a couple of spots where the round part of the piping has started to break away from the part that's sewn to the leatherette. Not too noticeable.
Posted: Wed Apr 17, 2019 8:02 am Post subject: Re: My new 59 Ragtop. |
Finished the rear seat. Now I can use it without worrying about it getting worse!
Posted: Thu Jun 04, 2020 10:00 am Post subject: Re: My new 59 Ragtop. |
Finally finished repainting my bug. The interior was left untouched. 99% of the seals remain original as well.
Busstom Samba Member
Joined: November 23, 2014 Posts: 4579 Location: San Jose, CA
Posted: Thu Jun 04, 2020 1:09 pm Post subject: Re: My new 59 Ragtop. |
Looks awesome. |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1924 Location: Fontana
Posted: Thu Jun 04, 2020 8:01 pm Post subject: Re: My new 59 Ragtop. |
Evil Clown wrote: |
Put hot water, bleach and soap in a sprayer, and tape off inside with plastic,
and it should clean that ceiling up with a brush...test small area 1st of course
(LET BLEACH SIT AT LEAST 10 MINS)
Rinse...Happy time  |
baby wipes work a lot better buy a box at costco _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
hsosa1 Samba Member
Malanthius wrote: |
nice 59 . _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Fri Jun 05, 2020 6:48 am Post subject: Re: My new 59 Ragtop. |
damn thats a nice car. i look forward to seeing your progress. _________________ -'85 c10 5.3 LS, cam, heads, long tubes, x pipe, 3 inch spin tech's
-'01 e46 325ci *tree modded
'65 Tourist Delivery Build
'66 RIP |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
rah253 Samba Member
Posted: Fri Jun 05, 2020 7:58 pm Post subject: Re: My new 59 Ragtop. |
What a great find and a gorgeous car! |
Bug-nut Samba Member
Joined: December 20, 2015 Posts: 494 Location: Knoxville, TN
Posted: Sat Jun 06, 2020 5:24 pm Post subject: Re: My new 59 Ragtop. |
TinCanFab wrote: |
If your venturi ring is still rubbing, double check that the rubber bump stop is still on the fan shroud, They always rot off. |
Yes this! Also, if you do need to end up replacing the stop, the correct one is pretty thin, about 1/8”. If I’m not mistaken, it’s the same piece that they use to plug the rear apron holes; although I’ve seen several with the much thicker plugs, around 1/4-3/8” long (like the bump stops for the glovebox door). The thicker ones will work, but I feel that it puts more stress on the thermostat when it’s cold and closed so I used the correct thinner one. I’m sorry I don’t remember which thread it was that discussed the proper rubber bump stop, but i do know it is on here, I believe in the oval forum. _________________ 1959 Fjord Blue Volkswagen Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1962 Austin-Healey Sprite
Snort wrote: |
A 59 Beetle is just an Oval-Window car with aspirations of modernity. |
Posted: Sun Jun 07, 2020 7:04 pm Post subject: Re: My new 59 Ragtop. |
TinCanFab wrote: |
It's not rubbing anymore once I adjusted it so maybe it's still there. I'll have to look for it because I had no idea it existed! Thanks! |
Posted: Sun Jun 07, 2020 7:11 pm Post subject: Re: My new 59 Ragtop. |
Thanks for the kind words all! Pulled the motor again this weekend. First rear main seal did not stop the leak. Sleeved the flywheel as it was groved. Took it for a nice cruise and it was bone dry when I got home! Runs like a champ!
