What's this Ghia part and Where does it go?
Page: Previous  1, 2, 3 ... 26, 27, 28, 29, 30, 31  Next
jeffrey8164 Premium Member
jeffrey8164 is online now
PostPosted: Fri May 22, 2020 8:59 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
My 70 came with A/C. I held onto it while trying to find a few replacement parts to make it look presentable. Never found any so I ended up tossing it. If it were me, Iíd offer it in the classifieds for a while and see if anyone has a need.
ďLet he that is without oil throw the first rodĒ
(Compression 8.7:1)
https://www.thesamba.com/vw/forum/viewtopic.php?t=696460&highlight=rose
NoDents
NoDents is offline
PostPosted: Tue Jun 02, 2020 6:35 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Not a part but holes.
What are these 2 holes near the latch for?
71 Ghia.
No Dents
1963 Bug - Sold in 1980
1966 Karmann Ghia Convertible - Stolen in 1988
1971 Karmann Ghia Convertible, resto/mod COMPLETED 10/2020
Marcdeb
Marcdeb is offline
PostPosted: Tue Jun 02, 2020 6:56 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
71 Ghia.
I don't know what the holes are for, but my 71 Ghia has the same holes as well. So it's not anything done after the car left the factory.
Marc
1971 Karmann Ghia Cabriolet
Restoration thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc
sputnick60
sputnick60 is offline
PostPosted: Wed Jun 03, 2020 2:25 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Can a screwdriver go through the holes to access the grub screw for the pull wire? Two different holes covers LHD & RHD variants
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
2014 Passat B7 130TDI wagon (cheats in tests)
"Have no fear of perfection - you'll never reach it."(Salvador Dali)
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Wed Jun 03, 2020 4:05 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I have these holes as well in my LHD 71. I thought at least one was a drain hole. The only screwdriver that would fit would be a very slim style. Never could figure out what these were, so left them alone.
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
NoDents
NoDents is offline
PostPosted: Wed Jun 03, 2020 6:25 am    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thanks guys.
Just wanted to make sure I wasn't missing something during reassemble.
No Dents
rbsurfguy
PostPosted: Sat Jun 06, 2020 1:15 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I know what this part is, but unsure of the year, and didn't want to start a new thread.
I got this and another door, in another color, with a bunch of stuff I bought at an airfield warehouse. The guy had no idea exactly what kind of car they went on, even though there was a deck lick with a KG badge on it, as well as a hood, so I took the whole lot.
Question is, can anyone advise by looking at the door handles and door panel what year range this would be? The other door unfortunately doesn't have the door panel, otherwise I could help someone with a set, only have for the right door. I've heard the chrome strips on the door panels are kind of hard to come by, but these are not in very good condition, unless they can be polished up.
Any info would be helpful,
Jeff
2012 Passat-Sold
c21darrel
c21darrel is offline
PostPosted: Sat Jun 06, 2020 2:31 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Inside door handle suggest pre 65. There is a door difference thread in ghia forum that will get you even closer.
GhiaBuild
rbsurfguy
PostPosted: Sat Jun 06, 2020 3:13 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Noted, thanks Darrel.
Jeff
2012 Passat-Sold
Loren Premium Member
Loren is offline
PostPosted: Sat Jun 06, 2020 3:55 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
You can also pull a door latch and there will be a date stamp on that. There is also a date stamp on the arm of the window regulator. Assuming these parts are original to the door you can get a more accurate date of manufacture.
rbsurfguy
PostPosted: Sat Jun 06, 2020 4:02 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thank you Loren, I will check those spots, everything appears to be original.
Jeff
2012 Passat-Sold
mooopers
mooopers is offline
PostPosted: Wed Jun 17, 2020 4:12 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Any ideas what these are? 1960 Ghia
rbsurfguy
PostPosted: Wed Jun 17, 2020 4:59 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I was going to say they look like the chrome strips that sit on the outer top side of the door on top of the window rubber/scraper, but not sure if that was on a 60 Ghia. Plus they look like aluminum as opposed to the heavier metal strips I have on my 71. Waiting to see what they are.
Jeff
2012 Passat-Sold
mooopers
mooopers is offline
PostPosted: Wed Jun 17, 2020 5:01 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
They are aluminium. Not curved at all
Rsellen
Rsellen is offline
PostPosted: Tue Jun 30, 2020 3:41 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Jeff, the paint color appears to be pampas green which was only available 60-62. I only know that because its the same color as my ghia. If you think its original paint. Iíd love to see some good photos of the door card. Looking for ideas for color combinations for my interior.
Jeff
Rsellen
Rsellen is offline
PostPosted: Tue Jun 30, 2020 4:41 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
I know where it goes, but donít know what it is or if I need it. Working in the engine compartment of my 74 ghia. Iíve seen photos of other engine compartments with some sort of electrical device mounted to the fire wall. (See photos) I was wondering what that device is? Is it the external voltage regulator? My current motor has a generator, but looking to put in an alternator. Do I need this thing in order to do it?
(Thanks to Redlabel 6 for letting me borrow this photo.
74 Ghia
07 GTI
99 Passat Wagon
92 Passat
87 GTI
86 GTI
78 Rabbit
NoDents
NoDents is offline
PostPosted: Tue Jun 30, 2020 4:43 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
It's a diagnostic port for the dealership.
An early attempt at OBD connection.
No Dents
Rsellen
Rsellen is offline
PostPosted: Tue Jun 30, 2020 4:53 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
Thatís funny Laughing I guess I donít need it then. Thanks....
74 Ghia
07 GTI
99 Passat Wagon
92 Passat
87 GTI
86 GTI
78 Rabbit
NoDents
NoDents is offline
PostPosted: Tue Jun 30, 2020 4:55 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
When you remove it make sure no bare wire ends will cross or get grounded.
No Dents
Rsellen
Rsellen is offline
PostPosted: Tue Jun 30, 2020 4:57 pm    Post subject: Re: What's this Ghia part and Where does it go? Reply with quote
No worries, It was never there. No loose wires (that I know of). Who knows what the PO did with them.
74 Ghia
07 GTI
99 Passat Wagon
92 Passat
87 GTI
86 GTI
78 Rabbit
Page 27 of 31
