Brake Fluid - Power Bleeder Line Burst - OUCH
Syncro Jael
Syncro Jael is offline
PostPosted: Wed Jun 17, 2020 9:58 am    Post subject: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
It was a sad moment this week.
Replacing the Brake Fluid in the van using my Power Bleeder. I have used a power bleeder for years and years. Filled it with new DOT4 Brake fluid. Made the connection to the fluid reservoir. Pumped the bleeder to 10psi. Then went down under the right rear of the van and started bleeding brake fluid. I noticed that the flow slowed down to a near stop.
Went back up to see the pressure in the tank. Shocked
The line had burst and sprayed the entire front interior of the van and dash with brake fluid. It almost completely emptied the Power Bleeder that was half full. About a quart. Boo hoo!
It shot a stream across my Recaro Drivers seat then through the center of the van back across the rear bench. The drivers side of the van took the brunt of the blast.
I hurried and pulled the rubber floor mats and started wiping the dash, seats, VOW center console, and wet vacuumed the rear cushions and carpets. The brake fluid was pooled on the Recaro's. Twisted Evil The finish on the leather is not going to ever be the same. Pray
Then I noticed that my dash vents, aftermarket gauges, lower center vent, and everything else "Plastic" was falling apart and cracking. The drivers side air vent fell apart. I started to remove everything and brake fluid was dripping down through the wiring and was everywhere!!! My gauge pod in the ashtray started to crumble as did all the plastic parts on the dash. All of the plastic knobs, covers, vent control cover, bulb holders, everything plastic.
Needless to say, I am posting this so that others will be more aware of this catastrophic event that could happen. Make sure your Power Bleeder hose is new and cover the line with a towel or something to keep it more contained if this should ever occur.
DAMMIT! These plastic parts are very difficult to find and replace. Brick wall
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
dobryan Premium Member
dobryan is offline
PostPosted: Wed Jun 17, 2020 10:08 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Oh NO! That royally sucks.
(I know it is after the fact, but I do not use the Motive tank for brake fluid itself. I just use it to pressurize the master cylinder reservoir and keep an eye on the level and top it up as needed.)
I am so sorry. Crying or Very sad
Dave O
Traveling after Building a bus for travel in Europe (euroBus)
The Western Syncro build
Syncro Jael
PostPosted: Wed Jun 17, 2020 10:16 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
This is a great afterthought. I too should approached bleeding this way.
It always costs me to learn simple things.
Rolling Eyes
jlrftype7
jlrftype7 is offline
PostPosted: Wed Jun 17, 2020 10:23 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
We feel your pain, and wish you a speedy recovery on that now damaged Interior. Crying or Very sad Crying or Very sad Crying or Very sad
‘84 Tin Top - Hilga....Auto
Jake de Villiers
Jake de Villiers is offline
PostPosted: Wed Jun 17, 2020 10:36 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Oh Ron, your lovely van... Crying or Very sad
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
hardway
hardway is offline
PostPosted: Wed Jun 17, 2020 12:46 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Brake fluid is water soluble. Copious mounts of flowing water is the best mitigation strategy after a spill. As long as it keeps foaming there is brake fluid still present. Get it out of the fabrics and carpet and insulating pads to save the paint.
That sucks.
Syncro Jael
PostPosted: Wed Jun 17, 2020 12:52 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
I’m trying to take apart the instrument cluster. It’s crumbling before my eyes
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Jun 17, 2020 1:00 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
So very sorry to hear this - what a nightmare.
It's all replaceable and hopefully among the many on the Samba the plastic bits can be located.
I can appreciate what a stressful time this is for you.
dabaron
dabaron is offline
PostPosted: Wed Jun 17, 2020 6:34 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
i feel for you, mine failed at the cap and it emptied the jug into the dash and all over the fuse panel, and down onto the cardboard i had put down.
what a nightmare.
i'm going to be using mine again soon, time to hook it up to the spare mc/tank i have.
1991 Vanagon GL Camper
Steve M.
Steve M. is offline
PostPosted: Wed Jun 17, 2020 7:12 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Shisen.
Feel for you 100%.
I unfortunately through experience learned to wrap an oil absorber around piping connections inside the interior when working on hydraulic systems.
Experience is a hard teacher, it gives the test before the lesson.
jimf909
jimf909 is offline
PostPosted: Wed Jun 17, 2020 7:29 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Yikes. I felt like I was reading about a forest fire raging through an 1800s logging town. Here's hoping you're able to repair the losses.
- Jim
Butcher wrote:
Guilty as charged.
ALIKA T3
ALIKA T3 is offline
PostPosted: Wed Jun 17, 2020 9:47 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Damn bro! That blows Sad
That always why was I never used them in the van and made a tire valve adapter to the reservoir cap for pumping slowly. It’s time consuming but our reservoirs are getting brittle too....
ZsZ
ZsZ is offline
PostPosted: Wed Jun 17, 2020 10:03 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
I was always afraid of pressurizing the tank. The clutch hose looked a weak point but the tank popping out from the master would be the disaster I was afraid of.
So we always used the 2 person pump-hold-bleed method. Recently I bought a cheap chinese compressor attachment which made it easier. Still do it two person as better to watch the fluid level continously, but can be done alone.
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
hans j
hans j is offline
PostPosted: Wed Jun 17, 2020 11:09 pm    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Yup it happens, and it really sucks when it does. Happened to me using our other shops bleeder a couple weeks ago, except it sprayed brake fluid all over my diag cart with about 30k in electronics in it. I only really just lost my laptop, but it could have been much worse! I spent about 7 hours cleaning everything up.
Best thing is to replace the hose every couple of years.
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
Wildthings
Wildthings is offline
PostPosted: Thu Jun 18, 2020 12:39 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
To flush the brake fluid I have never had to do anything more than open one front and one rear bleeder at a time and let gravity do the work. It takes a bit of time to flush the lines this way, but if you do it simultaneously with changing your oil or doing other service work, the time is not wasted.
I would like to find a new "shield" to protect the instrument cluster from brake fluid drips as mine is cracking around where it fits of the fill for the reservoir.
As other suggested brake fluid will dissolve in water, so a hose with a spray nozzle is about the fastest cleanup you can do.
syncrodoka
syncrodoka is offline
PostPosted: Thu Jun 18, 2020 12:44 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Yup
IdahoDoug
IdahoDoug is offline
PostPosted: Thu Jun 18, 2020 8:09 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Also, I know this seems self-serving, but that's what we pay all that insurance for. Believe it or not, owner mistakes and the damage are covered. To replace all those bits would be a couple thousand dollars, and it's under comprehensive, not a traffic crash that could increase your rates.
?Waldo?
?Waldo? is offline
PostPosted: Thu Jun 18, 2020 9:49 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
I've used a power bleeder also and put the fluid into the bleeder. I have had a leak when using the bleeder under the hood of a different vehicle. It made a mess but not nearly as disastrous as what you describe. I appreciate the warning and will consider it when bleeding the brakes on Vanagons.
tjet
tjet is offline
PostPosted: Thu Jun 18, 2020 10:39 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Was it a Motive bleeder?
Westaru
Westaru is offline
PostPosted: Thu Jun 18, 2020 10:50 am    Post subject: Re: Brake Fluid - Power Bleeder Line Burst - OUCH Reply with quote
Ron,
Fellow Utahn here, and I had the EXACT thing happen to me last fall with my Motive power bleeer. I was bleeding the brakes, and I lost pressure at the caliper and heard dripping. Got up to see the cab, and saw brake fluid EVERYWHERE, even dripping from the headliner. I don't think it is overstating to say this was a catastrophic experience.
From my experience, here is what I had to do:
    Steam clean the entire interior of the van. I did it once myself but couldn't get rid of the smell of brake fluid. Then paid to have it done professionally.
    Removed dash and wiped down everything, wire looms, etc. Used Deoxit on all grounds and connections.
    Stereo shorted and went up in flames upon powering it up. Had to replace.
    Had a few shorts (brake fluid is conductive) that took forever to short out. I had to completely disassemble the light and other switches around the cluster, clean them with deoxit, and then reassemble to get them sorted.
    Plastic - clean as much as possible. Had to get color matched paint for the lower heater cover and the gauge cover as both were stained badly (superior paint in murray did a fantastic job of this, perfectly matched in spray cans).
    Finally, I'm STILL looking for a replacement gauge cluster - my gauges were fine, but the lenses and plastic around them is etched and looks awful. I've been looking for 9 months now and still haven't found a replacement.
FWIW, I reached out to Motive, and they gave me a line of 'the instructions to the power bleeder say to replace the line regularly." They offered to replace the bleeder, but I was so pissed that I couldn't even respond to their email. No sorry, nothing other than I should have followed instructions that weren't included with my bleeder. FWIW, my instructions do NOT say anything about this, so they must have recently added it for liability reasons.
Best of luck to you, it is a pretty awful cleanup. There is a good interior detailer in Bluffdale that uses steam to clean and did a great job with my interior. I was out around $500 and a few days of work, and I hope I can find another cluster at some point - I don't even care about pricing at this point if I can just find one.
1984 Vanagon Westfalia EJ22
