Jokon Semaphore Replacements
bigbulli
bigbulli is offline
PostPosted: Tue Jul 21, 2020 12:16 pm    Post subject: Jokon Semaphore Replacements Reply with quote
Does anyone have a wiring diagram they could share. Mine work OK but the indicator light on the speedo doesn't come on.
1954 Barndoor
1955 Oval
TinCanFab
TinCanFab is offline
PostPosted: Tue Jul 21, 2020 2:15 pm    Post subject: Re: Jokon Semaphore Replacements Reply with quote
Have you tried with a regular bulb in the Jokon?
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
bigbulli
bigbulli is offline
PostPosted: Wed Jul 22, 2020 10:57 am    Post subject: Re: Jokon Semaphore Replacements Reply with quote
I did think that might be the issue but it wasn't.
There is a power wire and an earth back to the speedo. If I earth the earth wire to the body the light comes on. But I can't figure out the circuit which should only earth when the indicator is on.
1954 Barndoor
1955 Oval
Bub
Bub is offline
PostPosted: Wed Jul 22, 2020 8:18 pm    Post subject: Re: Jokon Semaphore Replacements Reply with quote
You want it to flash? Or is that an LED flasher bulb?
Typically you run the circuit through a blinker relay. When you move the switch it completes the circuit (through the flasher) the bulb is always grounded (since the circuit is closed via the switch) and it will flash.
If that bulb is a flasher then forget the blinker relay.
There are a million variations on this depending on hardware, but that's where you start.
If it's just the light in the speedo you want to get working, it probably has to ground through the flasher. Remember that the lower speedo lights have the housing live from the ignition switch (and the bulbs ground at the oil pressure and regulator to light up )And it may not work since that bulb outside is an LED. I got mine to work by adding a wire from each semaphore circuit to the speedo bulb- but put a diode in each wire. The diode keeps the circuits separate/ so current doesn't go back to the other side.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
bigbulli
bigbulli is offline
PostPosted: Sun Jul 26, 2020 11:58 am    Post subject: Re: Jokon Semaphore Replacements Reply with quote
Thanks Bub!
1954 Barndoor
1955 Oval
bigbulli
bigbulli is offline
PostPosted: Tue Jul 28, 2020 5:40 am    Post subject: Re: Jokon Semaphore Replacements Reply with quote
Still looking for a copy of the original paper instructions which came with the Jokon's
1954 Barndoor
1955 Oval
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Tue Jul 28, 2020 7:03 pm    Post subject: Re: Jokon Semaphore Replacements Reply with quote
… don't want my Jokons to blink - just connected as the semaphores were - real easy...
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
