1/4 Mile Results with Mild Stroker
King_vw61
King_vw61 is offline
PostPosted: Sun Nov 29, 2020 9:19 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
My 61 tank had the vent on the filler neck. We made it a -6 when the tank was new. I did a stainless pig tail and vented it down to the ground
1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en
RickS
RickS is offline
PostPosted: Mon Nov 30, 2020 5:10 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
If any fuel sloshes into that vent it will get trapped at the bottom of the pigtail. It will not take much to block off the air from passing, just like a plumbing p-trap.
GARRICK.CLARK
GARRICK.CLARK is offline
PostPosted: Mon Nov 30, 2020 6:19 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
When I fit a tank, I don't fit those in tank screens on the end of the pipe. Let a good filter do the job.
I fitted a CB return to tank fitting as an outlet. Granted, mine is a return to tank system but you could block one of the ports and just use it as an out let. It enables me to use a 13mm barb fitting and 13mm pipe to feed the pump. There is a filter before the pump so very little restriction before the pump takes over. Fuel cap is vented 13mm too.
HotStreetVw
HotStreetVw is offline
PostPosted: Mon Nov 30, 2020 10:08 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
I welded a -8 fitting to the filler neck similar to King, but used a Jaz roll over valve.
https://www.jegs.com/i/JAZ-Products/547/834-208-06/10002/-1
Jeff, what size vents are you running?
4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP
jpaull
jpaull is offline
PostPosted: Mon Nov 30, 2020 9:19 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
GARRICK.CLARK wrote:
Hey Jp what's the fuel ratio with WOT at the end of the track. Running out of fuel at the end will show it go super lean on the gauge.
I made a mistake when I only answered your question with just the 1 answer. I should have also mentioned that its not just at the end of the track in 4th gear, its in every other gear also starting at 4k like clockwork as its a carb tuning issue, not fuel supply to carbs or venting. But it was cool never the less to get some ideas from you, ivkings and Hotstreet
Every gear goes like this:
idles 13:1 to 2500rpms then 11-12:1 mains(170 with F2) to 4k and airs 13.8-14:1(1.7) from 4k and up.
My 4k up is lean, but it started at 15.8 when I first put the wideband on and I worked the airs down from 2.0 to 1.7
vwracerdave
vwracerdave is offline
PostPosted: Mon Nov 30, 2020 9:37 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
try some F-11 tubes.
jpaull
jpaull is offline
PostPosted: Mon Nov 30, 2020 10:03 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Thanks David, I will give those F11s a try.
Hotstreet, I had 36 vents in before, and went to 38s and it really liked those. Has the same bottom end as the 36s but pulls even harder above 4500 with the 38s. I have notwanted to try 40s unless i get more cam, and something larger then my current 1 5/8 exhaust. Worried I might lose some streetability. what say you?
jpaull
jpaull is offline
PostPosted: Mon Nov 30, 2020 10:10 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Had our #3 Child just a few hours ago. Esther Paull is healthy and doing well. When we found out she was gonna be a girl, we thought of one of the most inspiring books in the bible for women(while also hoping she will someday inspire others), and also thought maybe, just maybe, she might join the ranks of wonderful women that have contributed to High Performance VWs in some capacity.
fl59bug
fl59bug is offline
PostPosted: Mon Nov 30, 2020 10:13 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congratulations to you, your wife and new daughter Jeff. All the best to you all!
Wreck
Wreck is offline
PostPosted: Mon Nov 30, 2020 10:31 pm    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congratulations , happy to hear all went well and Mum and daughter are healthy and well .
57BLITZ
57BLITZ is offline
PostPosted: Tue Dec 01, 2020 12:28 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congratulations to one cool daddy!!! Cool
Jesucristo es mi Señor y Salvador!
calvinater
calvinater is offline
PostPosted: Tue Dec 01, 2020 4:33 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Let us know when you get Esther on the dyno. Cool Cool Cool
Congrats, three kids are the best.
#Bad Talk #Bad Talk #Bad Talk
"Will you stop touching me!"
"Albatross"!
madmike
madmike is offline
PostPosted: Tue Dec 01, 2020 5:02 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congrates , I have a 1 3/4 header collecting dust Wink
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
jpaull
jpaull is offline
PostPosted: Tue Dec 01, 2020 5:08 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Thank you Mark, Calvinator, fl59, Wreck, and MadMike I will PM you on that header VW Logo Idea
Bigjacksauto
Bigjacksauto is offline
PostPosted: Tue Dec 01, 2020 5:42 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congratulations Jeff!
https://www.facebook.com/groups/2778888602388847/?ref=share
1968 Beetle "Herbie" replica Father Son Project
1960 Beetle deluxe / Flint/Pebble Grey og 1200cc 36hp
1975 Westfalia bus sold
1967 SO 42 Westfalia Bus
(o\_!_/o)
GARRICK.CLARK
PostPosted: Tue Dec 01, 2020 6:12 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congrats Jeff and family
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Tue Dec 01, 2020 6:56 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
This is where a lot fall short of not using any type of a/f gauge. If you don’t know, you don’t know. You can’t tune what you don’t know.
Glad all is well with the baby. Congratulations!
Lingwendil
Lingwendil is offline
PostPosted: Tue Dec 01, 2020 6:57 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Awesome news!
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
Chickensoup
Chickensoup is offline
PostPosted: Tue Dec 01, 2020 7:23 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
congrajimitations sir!
'65 Tourist Delivery Build
'66 RIP
c77owen
c77owen is offline
PostPosted: Tue Dec 01, 2020 8:12 am    Post subject: Re: 1/4 Mile Results with Mild Stroker Reply with quote
Congrats Jeff! Great choice in name and I love the reasoning!
Page 7 of 8
