Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10498 Location: Sunshine Coast B.C.
Posted: Thu Dec 10, 2020 3:23 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Thanks. Bear in mind though that given my foray today into auto tranny Sinka's, any rep I had is now tarnished. So, take my measurements for what they're worth. LOL. Actually, I took care line up the clutch housing faces for those pics so measurements are fairly accurate.
If you ever go to a WBX tranny, but keep engine at air cooled position, some pics of how I adapted the WBX tranny to air cooled engine position. Flipped mount idea was courtesy of ?Waldo?. Rereading my notes, I would've done things differently and better but this was first time at this with beginner level fabricating skills so.....
https://goo.gl/photos/GXTagUdjdekict8R7
Even with removed material, mount is still fine afaik. e.g. no cracking.
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10413 Location: Orbiting San Diego
Posted: Thu Dec 10, 2020 5:01 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
I think it would be a much better idea to move the engine/aircooled tranny rearward to the wbx position now. Less work overall for the long term.
Mark |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12169 Location: Port Manteau
Posted: Thu Dec 10, 2020 5:13 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
It will give easier access to the clutch slave and starter. This is especially true if you delete the firewall. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
charleslabri Samba Member
Joined: December 08, 2019 Posts: 649 Location: Nashville/Yosemite
Posted: Thu Dec 10, 2020 10:06 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
When Mark tells you some tips to make your project move forward, it carries a whole lot more weight than my meager suggestions. He's probably forgotten more than I'll ever know about these vans. I strongly suggest you follow his recommendations. _________________ Casey--
y u rune klassik? |
Posted: Fri Dec 11, 2020 5:57 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Zeitgeist 13 wrote: |
When Mark tells you some tips to make your project move forward, it carries a whole lot more weight than my meager suggestions. He's probably forgotten more than I'll ever know about these vans. I strongly suggest you follow his recommendations. |
Referring to marks comment about the CVs?
Currently if I extend Greg’s brackets (which do not work for aircooled tranny position) I keep everything bone stock.
If I modify the trans location to be more like a wbx and fit Greg’s mounts, I end up changing 1) trans mount 2) shift linkage 3) CV angle 4) clutch slave position.
Seems a no brainier to keep stock locations and modify Greg’s mounts.
After being pretty active on the forum here for about a year, I agree... mark is def weighted in his knowledge of vans. A legend _________________ -------------------------------------------------
An example of my labor in action:
https://www.instagram.com/wileythewesty/
My Build Thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=730525&highlight= |
Posted: Fri Dec 11, 2020 9:26 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
One other thought is that the 091 trans was only available here for around 2.5 years, so they're kinda rare. They're also a bit weaker than the 091/1. Your new engine produces monster level torque, so if you grenade your current trans in the future, it might be difficult to locate a similar unit as opposed to the stronger and more readily available 091/1. If you move the trans mount now, you'll be able to swap in any trans, including a five speed 094. Options.
Btw: regarding the CV angle, with the drivetrain shifted rearward my axles are now a straight run to the hubs, rather than angled forward as they were in the aircooled donor van. _________________ Casey--
y u rune klassik? |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10090 Location: Where?
Posted: Fri Dec 11, 2020 12:09 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
charleslabri wrote: |
My plan is that if the trans grenades, likely ill just turn my ride into a syncro. |
In that case you will need to move the engine rearward to the later position. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 194 Location: Bellingham, WA
Posted: Fri Dec 11, 2020 12:58 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Ive thought about this.. i did some serious beefing already to the 091 trans.
Want to buy some parts? |
Posted: Fri Dec 11, 2020 2:13 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
pjn_wyo wrote: |
if i had anywhere reasonable to store syncro parts, id say yes. But r/n i dont ;( _________________ -------------------------------------------------
My Build Thread:
Posted: Tue May 04, 2021 6:52 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
whew, ok. I am back at it after the winter.
finished off the drilling on my airbox today from the vanistan fresh air vent, mounted my rear infinitybox powercell, and did some general cleanup.
ill get some pics rolling in as i start back on the project.
heres where Im at:
My Build Thread:
Posted: Thu May 06, 2021 5:21 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
I finally installed the lever for the vanistan fresh air vent. Looking good. Ill end up clipping the lever part on a U bolt somewhere on the dash when i get there.
next i did some of this fake soundproofing up front so i could feel better about my life
Lastly, since the weather is FINALLY warm, I did a bunch of prep work and cleaning on the battery box area. Plan here is to put some fiberglass down, and then drill out drainage holes. There was some rot that I cut out (small bits) and didnt want to weld a whole new pan in, since the metal was good most places. Someone stop me if im insane for adding fiberglass- dunno, seems like a good idea.
Ill probably finish it off with either 3m rubberized undercoat that ive got leftover from the underside or some fake soundproofing stuff.
My Build Thread:
Posted: Tue May 11, 2021 11:29 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Started laying down the initial wiring for the battery box and the infinity box stuff.
rear drivers side behind the brake light:
passenger seat box (all fiberglassed and nice:
passenger dash above glovebox:
My Build Thread:
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Tue May 11, 2021 6:50 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
nice seeing progress again! Keep the momentum going  |
Posted: Tue May 11, 2021 8:14 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
My mind was blown when I went to the Infinity Box site. Lots of really cool possibilities with that setup. _________________ Casey--
y u rune klassik? |
Posted: Wed May 19, 2021 8:12 am Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Took the single wiring run that goes front to back and did some prepping on it.
wrapped the 8ga infinibox power feed wires in a protective loom, and then wrapped that into a fiberglass high temp loom from del city electrical.
Making good progress here on the details of the electrical.
some pics:
My Build Thread:
Posted: Sun May 23, 2021 4:10 pm Post subject: Re: 1981 (@wileythewesty) TDI conversion, from ground up |
Due to the different position of the Aircooled from the WBX trans, I had to cut my firewall and relocate the N75 sensor down on a different location on the firewall. I bought new silicone 8mm hoses to accommodate this:
Secondly, I was a little concerned with the ~18-22awg wires that came with the boxeer kit for the fuel pump and water pump,
Since I already rewiring everything, I decided to rebuild the connectors with 14awg. Greg assured me that max draw was around ~4amps. This 14awg gives me the headroom that I need.
My Build Thread:
