1964...Diamond in the Rough
Page: Previous  1, 2, 3 ... 24, 25, 26, 27  Next
sportin-wood
sportin-wood is offline
PostPosted: Sat Jan 02, 2021 12:24 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
flyboy161 wrote:
.....after pulling about 6” of string, “snap”, it cracked right down from top to bottom in front of the driver.
Man, that's one of my biggest concerns with my '66 project. Trying to re-use my original windshield when the time comes, and having it break. If it does, I'll have to see if I can find a vendor that ships a good replacement to this podunk town....
Dave
1966 Bug project
1973 Thing project
flyboy161
flyboy161 is offline
PostPosted: Sat Jan 02, 2021 12:28 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
The 65 and up windshields are a little more forgiving. They have a slight curve to them. 64 and down are perfectly flat and if it isn’t just right, *crack*.
1968 Westfalia
https://www.thesamba.com/vw/forum/viewtopic.php?t=792825&highlight=
My father's 1970 Beetle-
http://www.thesamba.com/vw/forum/viewtopic.php?t=603879
The 1964...Diamond in the rough
http://www.thesamba.com/vw/forum/viewtopic.php?t=612776
My 1958 Morocco Bug-
http://www.thesamba.com/vw/forum/viewtopic.php?t=611483
67rustavenger
67rustavenger is offline
PostPosted: Sat Jan 02, 2021 2:13 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
flyboy161 wrote:
but the windshield ended up cracked in short order. It was not fitting very well in the hole and after pulling about 6” of string, “snap”, it cracked right down from top to bottom in front of the driver.
I had that happen. On the second to last windshield that I installed. Mine was the last 6" of string to pull at the drivers side upper corner. Same thing, "snap!" Twisted Evil
It happens. But it is so deflating when it does.
I guess congrats are in order on getting back to work. I think.
Take care!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
flyboy161
PostPosted: Sat Jan 02, 2021 4:41 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
I just took two weeks off for Christmas/New Year’s. Need to go back to work so I can get some rest, lol
1968 Westfalia
rstrobel
rstrobel is offline
PostPosted: Sun Jan 03, 2021 9:55 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
You're so close to being done! Can't wait to see what it looks like. It's a beautiful bug!
1967 VW Beetle
1993 VW Cabriolet
My 67 build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=716767
•(__)•
(O\!/O) <--- supposed to look like a beetle Very Happy
flyboy161
PostPosted: Mon Jan 04, 2021 8:07 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Thank you! So close is right. FedEx notified me the carpet and door cards are arriving today.
1968 Westfalia
flyboy161
PostPosted: Sat Jan 09, 2021 2:29 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Still waiting on a windshield, but I took the Diamond out of que. Today’s exercise was carpet, rear quarter cards, and seats.
1968 Westfalia
flyboy161
PostPosted: Sun Jan 10, 2021 4:59 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
I am now officially out of work on the Diamond until I get a windshield. Everything else is done. Today the door cards went on.
My high tech vapor barrier...courtesy of Hefty yard bags. I redid the headliner material at the base of the arm rest bracket and cut a piece of old carpet to replace the piece I threw away that acts as a buffer between the bracket and the door card.
Drivers door was comparatively easy. Clips lined up nicely on the Wolfsburg West/TMI door cards.
Passenger door card clips lined up very well. It was only a minor challenge to engage the arm rest in its bracket and then slide ever so slightly left and right to line up the clips.
1968 Westfalia
matthew henricks
matthew henricks is offline
PostPosted: Fri Jan 15, 2021 7:50 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Just finished reading the whole thread. Great Job. Will be following along and asking questions.
flyboy161
PostPosted: Sun Feb 07, 2021 6:49 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Finally done! Today, my buddy Raymond and his friend Junior came over and helped get the windshield in.
I changed out exhaust tips also. Mine, were a little rusty Laughing
Now, for a test drive
1968 Westfalia
67rustavenger
PostPosted: Sun Feb 07, 2021 7:23 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Congratulations on a job well done.
I hope that you wiped all the finger prints around the windshield off before rolling the car into that very bright daylight outside to admire your hard work!
And yet you haven't posted a picture of your car in the direct sunlight.
I look forward to the first drive impressions and PIC's
The car came out beautiful.
Enjoy the ride. You deserve it!
Buy Once, Cry Once!
flyboy161
PostPosted: Sun Feb 07, 2021 9:01 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Thanks dude! Weather permitting, tomorrow I’ll take some outside pictures. My road trip was a short one; no low beams. A little troubleshooting and found the low beam wire at the dimmer switch was teeny bit too short, and had become disconnected. I made a jumper, and have low beams again. Yay!
1968 Westfalia
Airstream65
Airstream65 is offline
PostPosted: Mon Feb 08, 2021 5:16 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Your car looks great! I recently replaced my exhaust tips with stainless steel pea shooters, look great and no chirping!
keegs
keegs is offline
PostPosted: Mon Feb 08, 2021 5:46 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Inspiring.. thanks
flyboy161
PostPosted: Mon Feb 08, 2021 8:35 am    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Thank you, thank you. I have a plan to build up another 40hp long block to swap in to the Diamond. I have thought about the stainless steel resonators. I’ve been really impressed with the stainless steel bumpers. I’d like to put them on the rebuilt motor. Truth be told, I “borrowed” these off the ‘58 motor because they were the correct length.
1968 Westfalia
flyboy161
PostPosted: Mon Feb 08, 2021 2:12 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
What a long strange trip this has been. Today was the Diamond's first foray into the world since the middle of last year. She performed flawlessly as I drove her to work. One hiccup with the gas gauge but other than that, no problems. I had planned on going by the body shop so they could see the finished car but they were closed. I di go next door to the VW dealer and they "ooo'd and awed" at it for awhile. They took pictures and were very nice. So, for 67Rustavenger...
1968 Westfalia
67rustavenger
PostPosted: Mon Feb 08, 2021 3:46 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Wow! I'm stunned.
That is just lovely outside.
I'm surprised the VW dealer didn't ask you if they could display that beautiful Beetle in the show room. Of course the thing would get finger prints all over.
Again. Nice work.You have done very well for yourself. Congratulations!
And thanks for putting up with my pic requests. I have to live the beautiful car idea through the eye's of others. Our paint shops here want the life of a first child to do the level of quality work that went into your Diamond.
Buy Once, Cry Once!
flyboy161
PostPosted: Mon Feb 08, 2021 6:10 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Thanks again, man. Sounds like you should send your car down here for body work, if you're not in a hurry to get it back. Smile
1968 Westfalia
67rustavenger
PostPosted: Mon Feb 08, 2021 6:34 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Lol! Don't think for a minute. That I haven't thought about it.
There is a body shop in town down by the tracks that did a 68+ bug a year or two back.
I saw it outside the shop before the owner picked it up. The car looked pretty good.
I don't think the shipping costs to Ga. Would save me any $$$$$.
Buy Once, Cry Once!
flyboy161
PostPosted: Mon Feb 08, 2021 6:45 pm    Post subject: Re: 1964...Diamond in the Rough Reply with quote
Meh, just flat tow it out here. Visit for awhile. You can have some Georgia bbq and sweet tea! LOL
1968 Westfalia
Page 25 of 27
