dabaron Samba Member
Joined: June 21, 2018 Posts: 2748 Location: Philly, mang
Posted: Fri Jan 22, 2021 3:32 pm Post subject: driver's door not flush at the top |
after work i was out in the Westy, maked tea and listened to some tunes. i went to shut the gas valve and noticed the driver's door at the top is not flush with the body.
at the waist line, the door is nearly flush
but up at the top, a very noticeable (now that i'm looking at it) difference.
why is this like that and can i fix it? maybe the door is all catawampus and needs the hinges adjusted?
the seal in the door at the top is pancaked and has worn a hole in it. before i drop the dosh on a replacement, i'd like to sort it so it doesn't chomp another seal. _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5998 Location: Bemidji, MN
Posted: Fri Jan 22, 2021 4:03 pm Post subject: Re: driver's door not flush at the top |
take a long 2x4, put it in the window with the door open, open the vent glass, and standing on a ladder tweak the top of the frame inward. doesn't take much to make a difference. _________________ -dan
www.thefixitworkshop.com |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 712 Location: long Island new york
Posted: Fri Jan 22, 2021 4:42 pm Post subject: Re: driver's door not flush at the top |
Why not try adjusting the hinges? They are adjustable... _________________ Enjoy the ride....
72 bug
80 westfalia |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2956 Location: North Carolina
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32987 Location: Reading Pennsylvania
fxr Samba Member
Joined: December 07, 2014 Posts: 2709 Location: Bay area CA
Posted: Fri Jan 22, 2021 7:49 pm Post subject: Re: driver's door not flush at the top |
| djkeev wrote: |
Fixes sagging doors too from old people using the door as an entry/exit crutch.
OI!  _________________ Jim Crowther
Vespa GTS 300 |
dobryan  Samba Member
Joined: March 24, 2006 Posts: 17380 Location: Brookeville, MD
