Splitcase Gearbox help...
Page: Previous  1, 2
PostPosted: Fri Mar 25, 2016 8:30 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
A am guessing a little bit but it looks like it's from late 1957 from the VIN # and rear end listing here:
http://www.thesamba.com/vw/archives/info/chassisdating.php
I do not know what N means.
ulme2004
ulme2004 is offline
PostPosted: Sat Mar 26, 2016 6:26 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
Thank you - EverettB for the late-1957 -information
The leading N seems to stay a mystery.....
PostPosted: Sat Mar 26, 2016 8:03 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
You can also look at the casting dates of the transmission case halves.
Example from earlier in this thread
Date decoding information:
http://www.thesamba.com/vw/forum/viewtopic.php?t=380362
Huetti_1989
Huetti_1989 is offline
PostPosted: Mon Mar 26, 2018 11:37 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
Hi.
I wounder about that Gearbox, is it a Splitbeatle or a Barndoor?
The former Owner build it out from a late Barndoor..
i couldn`t find any a Number like 2A....
Any Idea about that??
-Christian
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
djfordmanjack
djfordmanjack is offline
PostPosted: Tue Mar 27, 2018 12:52 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
Does it have reduction gear boxes on the axles, Christian ?
if the tri rib '29#' shift cover with the low shift rod input is original to the gear case it means that it is a 1953 to 1955 synchromesh ( except first gear) genuine Barndoor unit.
also this front (nose) cover will not fit on an early (non synchro) split bug without heavy modifications. so chances are good that the whole transmission is late BD. oil filler plug says so as well.
the date code 7 6 25 makes it a June 7th of 2nd workshift 1955. which of course is not a Barndoor anymore. but its still an early Wolfsburg ( post BD) date, and these 1955 buses still had the old axle and transmission cradle like a BD.
so most probably this transmission is a straight fit for your 54BD, but originally came in a very early non BD 1955 Wolfsburg bus.
54 Oval project
62 Dickholmer, Seeblau L360
Huetti_1989
PostPosted: Tue Mar 27, 2018 10:28 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
Thank you!
The reduction boxes were sadly cut off.
i am confused about the 29. Number?
Anyone know if and where the Wolfsburg bus Gearboxes have the Numbers?
is there a other way that i can check whats is inside this suprise box? Laughing
-Christian
My 1957 SC
MY 1967 Sparsamba:
My 1952 Panel:
My 1961 SO34:
Justin Horgan
Justin Horgan is offline
PostPosted: Tue Jan 26, 2021 5:17 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
On my split box casing it has the following stamps , 111.301.101A with the VW logo. Any idea which year this gearbox is from ? Thanks
PostPosted: Tue Jan 26, 2021 6:11 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
This is the part # of the casing.
Looks for a "2A-" serial number on the side, either near the nose cone or on a raised area a little behind the nose cone but on the side.
Example from earlier in this thread:
Justin Horgan
PostPosted: Thu Jan 28, 2021 4:41 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
Is the 2A stamping on the nose cone or on the gearbox casing ? I have found the following stamps on the nose cone 21.09.2 , I assume this is a part number, thanks
djfordmanjack
PostPosted: Thu Jan 28, 2021 6:22 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
the 21.*** is the cast part number on the nose cone.
you want to look for a stamped number on the case behind the nose cone .
54 Oval project
PostPosted: Thu Jan 28, 2021 11:18 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
On the side of the casing.
Maybe this is a better pic, also from page 1 of this thread:
Nosecone at the top of the photo above
Justin Horgan
PostPosted: Thu Jan 28, 2021 5:31 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
Thanks for your help gentlemen. I will try and post photos tomorrow of my gearbox . I don’t see any 2A stamping on the gearbox casing. It does come complete with its reduction boxes.
ron miche
ron miche is offline
PostPosted: Mon Nov 11, 2024 12:38 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
ulme2004 wrote:
Hallo, I need help in determination the model-year relation
of my barn find splitcase gearbox.
It seems to fit to a 58 T2 kombi
But is it an earlier gearbox? Which model year exactly?
The number is N 2A 1458901
what means N?
Regards Andreas
I also have a 57 gearbox with the N2 number
I also wondering what it means.
fmulon
fmulon is offline
PostPosted: Wed Mar 19, 2025 11:53 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
hi i have a gears box BD (for sale )number 2A-3822207 someone could confirm me its january 1955 please?
many thanks
View user's profile Send private message MSN Messenger Facebook Gallery Classifieds Feedback
PostPosted: Wed Mar 19, 2025 4:31 pm    Post subject: Re: Splitcase Gearbox help... Reply with quote
many thanks
On the VIN charts on the site, the last transmission # for 12/1954 is:
2A-380 323
So I think your transmission is from 1/1955 if it has 1 less digit, maybe its:
2A-382 207
RockStock
RockStock is offline
PostPosted: Thu Mar 20, 2025 6:59 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
-StockRocks-
PostPosted: Thu Mar 20, 2025 11:36 am    Post subject: Re: Splitcase Gearbox help... Reply with quote
Ok, so it's 2A-382 207
What I stated above should be correct
Page: Previous  1, 2
Page 2 of 2
