dobryan Samba Member
Joined: March 24, 2006 Posts: 17147 Location: Brookeville, MD
Posted: Thu Jan 28, 2021 5:53 pm Post subject: Power antenna install (Hirschmann HIT AUTA 2050) |
I just finished installing a power antenna on the euroBus and since I could not find an install topic I documented what I did.
I did see a facebook post where someone took some pics of their install but not really documented. But it gave me the basic knowledge to do this.
I used a Hirschmann HIT AUTA 2050 power antenna for Mercedes.
https://www.ebay.com/p/1222989461
The installation was actually very easy in general. It took about one hour or so this afternoon.
Remove the existing antenna. Unscrew the nut on top of the antenna fairing at the base of the antenna mast. Remove the front grill and drivers headlight assembly. Pull the antenna downward. (If you want you could tie a piece of string or something to the other end of the antenna lead at the radio so you maybe could pull the new antenna lead along but I had the instrument cluster off already and it is easy to route the new antenna lead with the cluster off.)
On the power antenna remove the fairing assembly completely. You will reuse the stock VW antenna faring you removed and the new nut from the power antenna.
Now it is time to open up the hole in the body interior so the power antenna will pass thru. Use a 1 3/8" step bit on a right angle drill and clean up the edges with a rat tail file and the new antenna will just fit thru.
Insert the new antenna assembly in from the bottom until the antenna base comes out the stock hole on top.
Now use a battery to raise the antenna. Black to ground and both the green and red leads to positive will raise the antenna (just the red lead to pos and black to ground will lower it).
Slide on the original fairing and the new nut and hand tighten.
Now align the antenna base unit so that the antenna is vertical and the base is turned to be parallel with the side body panel as shown. You need to get it out of the way of the headlight bucket. It should be just barely clear of the big resistor under it.
Get creative and fashion a bracket for the base of the antenna unit. The kit has the material to use.
Do a dry fit of the headlight bucket and realize that your bracket is in the way and use a common blunt force tool to persuade the bracket out of the way. You can do a better bracket than that mess.
Ground the black wire on the body.
Feed the antenna lead and two power wires up thru the 1 3/8" hole into the space behind the instrument cluster and route them to the radio.
Insert pipe insulation material in the annular area to keep critters out.
Pull off the nut and fairing and repaint the fairing matte black, add some silicon to the base, and reinstall and tighten the nut gently.
You should be done!
(What really makes this work so well is the use of the original fairing piece as the power antenna hardware is not made for the steep angle of the Vanagon front end.) _________________ Dave O
The Western Syncro build
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5709 Location: Bemidji, MN
Posted: Thu Jan 28, 2021 5:57 pm Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
NICE write-up. i still think power antennas are one of the coolest things on cars. and very practical. _________________ -dan
www.thefixitworkshop.com |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Thu Jan 28, 2021 6:24 pm Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Very cool. I've wanted to do this for a very long time. I have a stash of vintage Hirschmanns, but matching up the stanchion and mast was always the hurdle. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Jan 28, 2021 6:53 pm Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Nice work! Thanks for documenting and sharing. |
4Gears4Tires Samba Member
Posted: Fri Jan 29, 2021 7:52 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Are stock Vanagon antennas unpowered/manual pull? I have never touched mine. I assumed it was just broken because it didn't extend when I turned on the stereo and since I don't use the radio I didn't pay it any mind. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
DuncanS Samba Member
Posted: Fri Jan 29, 2021 8:07 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Posted: Fri Jan 29, 2021 8:13 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
This is the one piece item which seemed to be standard in the 80's. The PO of my '91 weekender had an external telescoping unit which failed. Don't know if that was factory or not, but tracked down a one piece item and replaced the broken antenna. Have never had any problems with the one piece guys, which were on several of my T3's, in carwashes or my low garage overhead. One less thing to electrical go wrong, but........still think the retracts are cool. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
Posted: Sat Jan 30, 2021 6:03 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
I worked for Mercedes back in the 70/80’s. Hirshman antenna's were a big item, most of the higher end models had them.
Let's just say I kept a good inventory of replacement masts and entire units for the failure rate was sky high!
The slightest bend in the shaft from hitting a leaf while in motion would tweak the mast just enough to not retract.
The nylon feed "wire" would get chewed up by the internal gears or water would simply infiltrate the motor and it would go kaputz.
They often fail to retract fully. I have an 86 SL in my garage right now with the mast stuck up about 6”.
Keep the mast well lubricated and only have it up when you must.
I understand with shipping this unit and storing this unit you want to minimize damage but do be careful with it.
Ghia
Vanagon
Beetle
Posted: Sat Jan 30, 2021 7:49 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
djkeev wrote: |
Dave |
Thanks for the advice. I will determine how to lube it.
I already have plans for a cap for it to keep out most of the water when retracted.
And I will add a switch so I can keep the antenna retracted when using the radio on bluetooth for music from my iphone.  _________________ Dave O
Posted: Sat Jan 30, 2021 7:56 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Some of the modern HUs will send a signal through the blue wire to retract the antenna when it's not in radio mode. _________________ Casey--
y u rune klassik? |
Posted: Sun Jan 31, 2021 8:25 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
dobryan wrote: |
Zeitgeist 13 wrote: |
Some of the modern HUs will send a signal through the blue wire to retract the antenna when it's not in radio mode. |
Hmmm. I’ll have to try mine. I did not do a bt test yet. Thanks. |
Tested the radio on blue tooth with my iphone yesterday and the antenna stayed up. Looks like a switch is in my future... _________________ Dave O
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7205 Location: Honolulu,Hawaii and France
Posted: Sun Jan 31, 2021 1:04 pm Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Very cool. I've wanted to do this for a very long time. I have a stash of vintage Hirschmanns, but matching up the stanchion and mast was always the hurdle. |
I looked at this for so long, I could never find confirmation of matching angle and gave up.
This looks nice but ready about the failure rate, I think I`ll keep it a fantasy  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
TurtsMcSlow Samba Member
Joined: August 07, 2015 Posts: 78 Location: Derby City, Cantuckee
Posted: Sun Jan 31, 2021 2:53 pm Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Document your switch install as well please. Great write up, thanks for this. |
Posted: Sun Jan 31, 2021 4:13 pm Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
ALIKA T3 wrote: |
This looks nice but ready about the failure rate, I think I`ll keep it a fantasy  |
Since I've owned MBs for decades, I have lots of experience with Hirschmanns. It's not so much failures, as just that they're kinda fiddly. If you don't lube the mast regularly they'll get stuck and won't fully retract. If it gets really stuck, then the mast gear ribbon will strip out. Then you just replace the mast, which isn't too bad. The only other issue is if water migrates down and into the motor housing. Then it's a lot like what happens with the power door lock actuators getting wet...more fiddly stuff. _________________ Casey--
y u rune klassik? |
Posted: Mon Feb 01, 2021 7:27 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Yeah, same with the BMW world. Very common to switch to stubby antennas because of this. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
Ronzo_volvo_guy Samba Member
Joined: December 31, 2015 Posts: 194 Location: Connecticut
Posted: Mon Feb 01, 2021 9:35 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
Forum;
...another newby questions from a (dad of a new '87 Westy owner): What circuit is that power resistor behind the headlight for (what section/page/link on Wiring Diagram might I find it in)...I'm just coming up to speed on details of these vehicles...
I'd like to ask about the published Wiring Diagrams (we have both factory and Haynes manuals)...how consistent with the published WDs are the actual cars (owner changes obviously notwithstanding)...on vintage Volvos, the consistency is quite good, so I have learned to trust the published WDs and I often say: "The color codes and wire gauge in the factory WD is you friend" ...can the same be said for the Westy and VW published WDs?
TIA, and Cheers from a snowy Connecticut wonderland! |
Posted: Mon Feb 01, 2021 9:46 am Post subject: Re: Power antenna install (Hirschmann HIT AUTA 2050) |
I believe that resistor is for the cooling fan. The Bentley wiring diagrams are sorta helpful, in the same way a road map from 1977 might get you part of the way home. You [gulp] might need to stop and ask for directions. _________________ Casey--
y u rune klassik? |
