ChrisPEI Samba Member
Posted: Tue Dec 15, 2020 8:42 am Post subject: 16 Syncro build to follow |
Hey guys & girls,
I purchased a rare 16" syncro panel van from Dream & Drive in NL. Its got a 2.5L water boxer, with completely brand new drive train. We are building it up as a promotional van for a new drinks brand we are launching. If you want to watch and follow along, check out Bruce's instagram:
https://www.instagram.com/bruce_van_dam/
Bruce was used in a French military base to transport explosives and has spent most of its life stored inside (maybe it was in a special underground base?) so he is bone dry with no rust. Really exciting project.
I have one question for the community - as a water cooled engine, I no longer need my air intakes and I am home in Canada for the holidays and wanted to take the time and use my brothers welding shop to craft some custome covers for them, with the right side having a design (and later upgrade to a snorkel) and the left hand side I want to use for a special purpose.
I want to have it as a lockable door / hatch for 240v electrical points to the roof, as well as possible audio stereo conneciton.
Has anyone done this sort of thing before? Does anyone have precise measures for these covers they can share? I didnt think to take precise measures when I was in Netherlands.
Cheers,
Chris |
4Gears4Tires Samba Member
Posted: Tue Dec 15, 2020 9:42 am Post subject: Re: 16 Syncro build to follow |
Sucks you're using instagram. I won't be able to see any of your pictures. They lock everyone out without an account nowadays.
Maybe you could consider using imgur to host or upload the images directly to the forums. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1509 Location: Deep South of the Great White North
Posted: Tue Dec 15, 2020 9:50 am Post subject: Re: 16 Syncro build to follow |
https://www.vanagonlife.com/vanagonshop/vents _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2938 Location: North Carolina
Posted: Tue Dec 15, 2020 10:02 am Post subject: Re: 16 Syncro build to follow |
In the original design, the passenger air intake is still used for feeding air, although many conversions just pull it from the engine compartment. The only plug-and-play aftermarket oil cooling option also uses the air flow from the D pillar. While I like the idea of having fun with that space, it's not necessarily where I'd start, if that makes sense.
But, it's your lego block, build it your way! _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Tue Dec 15, 2020 10:26 am Post subject: Re: 16 Syncro build to follow |
The rear vents still provide cooling air for the engine compartment and air for the engine intake as well as letting the hot air escape when you park.
You do get air in from the bottom, but why screw with a proven design?
It is also a good habit to walk past them after you park and sniff for any gasoline fumes that might indicate a leaking fuel line. _________________ This free advice is worth exactly what you paid for it.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18861 Location: Retired South Florida
Posted: Tue Dec 15, 2020 10:34 am Post subject: Re: 16 Syncro build to follow |
Quote: |
We are building it up as a promotional van for a new drinks brand we are launching |
Interesting choice for marketing a new product. Good luck with both. We drink water. |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 2011 Location: Pittsburgh PA (ish)
Posted: Wed Dec 16, 2020 8:31 am Post subject: Re: 16 Syncro build to follow |
Amazing. I have never come across these before and I have no idea why. This is exactly what we want to make (my brother is a welder)
Indeed, we intend to keep a vent function but want to have a port for connections to the roof (RCA, power, solar etc)
Will post some before photos of the van.. |
Posted: Wed Dec 16, 2020 8:39 am Post subject: Re: 16 Syncro build to follow |
Bruce exterior
Bruce interior
Bruce hauling back another panel van (that was a barn find, not moved in 25 years and mint condition, contact Mark and Dream & Drive in Amsterdam)
Posted: Wed Dec 16, 2020 8:40 am Post subject: Re: 16 Syncro build to follow |
Bruce being torn down for spraying and a bit of body work to repair some dings
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1683 Location: Between Here and There
Posted: Sat Feb 13, 2021 5:21 pm Post subject: Re: 16 Syncro build to follow |
Beautiful van. Following! _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Posted: Thu Mar 11, 2021 11:26 am Post subject: Re: 16 Syncro build to follow |
Silver top and deep navy body...
There was a lot of debate that the blue was too dark - almost black but we stuck to our guns
Posted: Thu Mar 11, 2021 11:27 am Post subject: Re: 16 Syncro build to follow |
Bruce with a full lenght front runner roof rack
And below, an LPG install for the propex and domestic needs. We later painted the tank black and have since added one more....
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 977 Location: Sammamish, WA
Posted: Thu Mar 11, 2021 12:11 pm Post subject: Re: 16 Syncro build to follow |
Looks great ! Any plans for the interior? _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Fri Mar 12, 2021 6:07 am Post subject: Re: 16 Syncro build to follow |
pnwkayaker wrote: |
Looks great ! Any plans for the interior? |
Some photos of the CAD model
Posted: Fri Mar 12, 2021 6:08 am Post subject: Re: 16 Syncro build to follow |
And rendered with lighting
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Fri Mar 12, 2021 11:49 am Post subject: Re: 16 Syncro build to follow |
Killer, not sure what your doing with the fridge. I would have the counter above, then the chest fridge on drawer pulls. That way you can keep stuff on the counter when you need to open fridge. |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 450 Location: Coquitlam, BC
Posted: Fri Mar 12, 2021 11:53 am Post subject: Re: 16 Syncro build to follow |
WOW - a brave color choice on a vehicle with such large, flat panels - lots of trust in the body man. Looks entirely straight and awesome! Interior renderings are fantastic - looking forward to following the progress and more pics. _________________ 1991 Westfalia EJ251, 1972 Volvo 1800 ES |
Posted: Sun Mar 14, 2021 5:22 am Post subject: Re: 16 Syncro build to follow |
coqwesty wrote: |
WOW - a brave color choice on a vehicle with such large, flat panels - lots of trust in the body man. Looks entirely straight and awesome! Interior renderings are fantastic - looking forward to following the progress and more pics. |
Thanks. It’s branded with decals for our new brand so it breaks it up. Will post photos shortly .../ |
Posted: Mon Apr 26, 2021 6:36 pm Post subject: Re: 16 Syncro build to follow |
