Dash light escutcheon tool
Merian
Merian is offline
PostPosted: Sun Feb 14, 2021 4:06 pm    Post subject: Dash light escutcheon tool Reply with quote
djkeev
djkeev is offline
PostPosted: Sun Feb 14, 2021 5:46 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
Photo?
I'm trying to place in my mind what you are trying to remove but not coming up with it.
Dave
Ghia
Vanagon
Beetle
Merian
Merian is offline
PostPosted: Mon Feb 15, 2021 1:17 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Feb 15, 2021 1:22 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
The only item I can think of on a T3 which uses that kind of escutcheon is the aux. heater timer knob. Lots of old aircooled VWs used those, as well.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
djkeev
djkeev is offline
PostPosted: Mon Feb 15, 2021 1:54 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
If that tool is the two ears for the old style Beetle nut.
A small diameter pipe nipple, a file and a few minutes of time to make your own.
Dave
Ghia
Vanagon
Beetle
fxr
fxr is offline
PostPosted: Mon Feb 15, 2021 3:38 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
I always used curved long-nose pliers for those sort of fittings.
Jim Crowther
Vespa GTS 300
djkeev
djkeev is offline
PostPosted: Mon Feb 15, 2021 3:41 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
These nuts were most often installed on painted dash boards.
You can often see the nut behind the knob.
Needle nose work but they also mar the nut and It is easy to slip and scratch the dash.
Dave
Ghia
Vanagon
Beetle
Ahwahnee
Ahwahnee is offline
PostPosted: Mon Feb 15, 2021 7:16 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
I've been able to remove them using half of a wooden clothes pin as a drift (pointed at an angle into one of the slots). That method will even work when they are way too tight.
dgbeatty
dgbeatty is offline
PostPosted: Mon Feb 15, 2021 9:06 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
A proper fitting special purpose socket/tool is essential to reduce the possibility of accidental damage BTDT!
Schau in das Buch
djkeev
djkeev is offline
PostPosted: Mon Feb 15, 2021 11:11 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
I used an air hose quick connect fitting and some pipe.......
https://www.thesamba.com/vw/forum/viewtopic.php?t=696644
Dave
Ghia
Vanagon
Beetle
Merian
Merian is offline
PostPosted: Tue Feb 16, 2021 7:03 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
djkeev
djkeev is offline
PostPosted: Wed Feb 17, 2021 8:05 am    Post subject: Re: Dash light escutcheon tool Reply with quote
Merian wrote:
I need the 4 pin type tool.
o
Yes you said that but refuse to post a photo or further explain.
We are all guessing here.
What does the four pin tool do? Share some information.
Or are you just trolling? If so, this thread will be removed.
Dave
Ghia
Vanagon
Beetle
jlrftype7
jlrftype7 is offline
PostPosted: Wed Feb 17, 2021 11:01 am    Post subject: Re: Dash light escutcheon tool Reply with quote
I've seen shallow 4 pin or 4 tab tools for Antenna nuts on some older German Antennas, but not a 4 pin for dash work. I only have the old Snap-On 2-pin/blade escutcheon tool, S5908B. I agree with Dave/Mod, the right sized tubing or pipe, worked with a hacksaw or abrasive cut-out saw or even Dremel tool, could become a 4 pin or 4 tab escutcheon tool for very little money.
Think Think Think
‘84 Tin Top - Hilga....Auto
vanis13
vanis13 is offline
PostPosted: Wed Feb 17, 2021 12:34 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
djkeev wrote:
o
Dave
I've dealt with that poster previously. At 5K posts unlikely trolling but I have found his communication short, unclear, and "take and no give" expecting the reader to understand his mind and not expressing any gratitude for the help provided....not a pleasant experience.
Merian
Merian is offline
PostPosted: Wed Feb 17, 2021 1:23 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
djkeev
djkeev is offline
PostPosted: Wed Feb 17, 2021 2:44 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
First, uploading photos is simple......
Just follow this link.
https://www.thesamba.com/vw/forum/viewtopic.php?t=289807
Second, you kept insisting you need a four pin tool for a Vanagon light switch. No Vanagon has a switch that needs a four pin tool to remove it.
Turns out this is a non Vanagon PO installed switch which could be from anywhere.
There is no way on God's green earth that we can tell which tool you need to fit to an unknown fastener from an unknown source.
Again, post a photo if you want real help.
Dave
Ghia
Vanagon
Beetle
vanis13
vanis13 is offline
PostPosted: Wed Feb 17, 2021 3:52 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
Simple/hard (shrug) it is how its done here.
Personally I find it EXTREMELY simple compared to other platforms I'm a part of especially since I was educated how to do it with the link right in the create post window. Also like that the pics stay here instead of some 3rd party that will eventually charge me to keep them.
Are you making a statement?
Are you asking one of us to send one to you?
What are you trying to accomplish about expressing your need?
Zeitgeist 13
PostPosted: Wed Feb 17, 2021 5:05 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
We should probably create a thread devoted to Yelp-style reviews of each member's posting style.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
11BC2
11BC2 is offline
PostPosted: Wed Feb 17, 2021 5:10 pm    Post subject: Re: Dash light escutcheon tool Reply with quote
Dancing
