Camper fluorescent tube over sink
mr matt
mr matt is offline
PostPosted: Mon Mar 01, 2021 12:58 pm    Post subject: Camper fluorescent tube over sink Reply with quote
Hi,
A few things about this light,
Where is a source for replacement ( did not see one listed at BD), and does anyone know of the wattage?
I am considering to change it over to LED.. but on the other hand like the soft fluorescent lighting. Would be good to compare so any known source for an LED switch-out?
Thanks!
1955 3-fold semaphore Oval beetle
1971 Convertible beetle
1977 Westfalia, FI, Berlin interior
MorkC68
MorkC68 is offline
PostPosted: Mon Mar 01, 2021 2:25 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
We replaced our Westy's flourescent tube with this 12v LED light:
Bought from here:
https://www.vehiclewiringproducts.co.uk/c-55-light...amp-10-30v
Maybe there is a US based supplier (or the one here in the UK ships) or eBay?
Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
www.markcheluphotography.com
My photography work : https://lencilcreations.picfair.com/
mr matt
mr matt is offline
PostPosted: Mon Mar 01, 2021 3:02 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
That is nice, but visually, want to keep the inside stock, light bulbs are an exception tho"!
But thanks again for the idea.
Wildthings
Wildthings is offline
PostPosted: Mon Mar 01, 2021 9:25 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
I have an LED tube light in my '91 Vanagon Multivan that looks very much like a florescent tube.
ivwshane
ivwshane is offline
PostPosted: Tue Mar 02, 2021 4:11 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
The light is easy enough to modify to remove the fluorescent bulb and to replace it with an led strip instead and still use the switch.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
mr matt
mr matt is offline
PostPosted: Tue Mar 02, 2021 9:11 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Great, thank you both!
I wonder if the fluorescent tube is still available tho. Mine is not burned out, just curious.
MorkC68
MorkC68 is offline
PostPosted: Tue Mar 02, 2021 1:45 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
No problem buddy!
- Subaru EJ20
- 180W Solar System
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Tue Mar 02, 2021 4:18 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
This may or may not help, but I have this in my stash:
Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page.
mr matt
mr matt is offline
PostPosted: Tue Mar 02, 2021 5:10 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Wow, amazing you have that! is quite old.
What does it say on the tube end?
How long is it.... 12 inches?
Looked up the numbers, not expecting to find anything on the web, which I did not.
but there are 12volt tubes out there... did not research extensively...
https://www.amazon.com/Camco-54880-F8T5-Fluorescen...amp;sr=8-4
EZ Gruv
King of Plaid
EZ Gruv is offline
PostPosted: Tue Mar 02, 2021 6:02 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
It's 11 7/8 inches tip-to-tip
The marking on the bulb itself just say 'Phillips' and 'Made in Holland' and 'TL', then something I can't really make out.
Eric
mr matt
mr matt is offline
PostPosted: Tue Mar 02, 2021 6:49 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Ok thanks, for fun, in my spare time, will look for one.
Maybe i will call Philips & see what they have
telford dorr
telford dorr is offline
PostPosted: Tue Mar 02, 2021 8:49 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
It's probably a standard T5 fluorescent lamp - F8T5CW, 12 inch, 8 watt, by Philips and others.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Wildthings
PostPosted: Tue Mar 02, 2021 9:12 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Here is the LED striplight I have in my '91 Vanagon:
mr matt
mr matt is offline
PostPosted: Wed Mar 03, 2021 6:13 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Telford, thanks for the further details, I've seen some like that but not running off of 12 volts. Mostly likely will be in a RV website store.
Led strip looks good! did you have to remove the ballast from your light?
Wildthings
PostPosted: Wed Mar 03, 2021 6:57 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
None run off of 12v, the ballast in the fluorescent fixture boost the voltage up to the several hundred volts the bulb requires. With an LED the voltage has to be dropped either in the bulb or in the fixture to the low voltage the LED diodes need.
The LED strip light I show above totally replaces the original fluorescent fixture and bulb.
Zed999
Zed999 is offline
PostPosted: Wed Mar 03, 2021 7:59 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Common misunderstanding. No such thing as a 12V florescent tube.
jtauxe Premium Member
jtauxe is offline
PostPosted: Wed Mar 03, 2021 9:48 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
I have a spare fixture and bulb in my stash if you are interested.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
mr matt
mr matt is offline
PostPosted: Wed Mar 03, 2021 3:01 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Zed,
When doing my research, I read on the site I listed above, the following..
Question:Are these 12 volt ? Thank You
Answer: Hi yes they are 12 volt.
By Carl's RV Parts & Service SELLER on April 27, 2015
Answer: Yes....we use in our motorhome.
Question:Are these 12. Volt or 110
Answer:Hi they are 12 volt. Thank you
John, thanks but mine are both working. Just wondered what non-led replacement is out there if any...
But reading more questions/answers, another person states he is using them in 110 socket, so guess you are correct.. never knew that. I thought the ballast and matching bulb is specific for 12V or 110 current.
vwmaniaman
vwmaniaman is offline
PostPosted: Fri Mar 05, 2021 9:45 pm    Post subject: Re: Camper fluorescent tube over sink Reply with quote
Just in case you didn't know or remember, you can test a fluorescent tube by holding it in your hand near a CB radio antenna when you key the mic. If it lights then at least you know it still has gas in it and you can use a meter to test to be sure that the filament is not open.
Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio
View user's profile Send private message Send e-mail AIM Address Classifieds Feedback
NASkeet
NASkeet is offline
PostPosted: Sat Mar 06, 2021 1:17 am    Post subject: Re: Camper fluorescent tube over sink Reply with quote
The fluorescent tube in the Westfalia-factory-fitted fluorescent light above the sliding-door aperture, of my British specification, 1973 model-year, VW "1600" Type 2 Westfalia Continental motor-caravan, is rated at 8 watt. There is an identical duplicate that I retro-fitted on the opposite side.
Regards.
Nigel A. Skeet
https://vwt2oc.co.uk
