MarkWard Samba Member
Joined: February 09, 2005 Posts: 19073 Location: Retired South Florida
Posted: Fri Apr 09, 2021 9:00 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
The broken bolt is a problem. Not sure how you got it out and back in once and then managed to snap it off taking it back out. That might indicate it was cross threaded.
Someone skilled can likely address it with the intake installed, but won't be stoked to deal with it. That requires someone coming to you are towing it to someone.
The other option which is not that big a deal is to remove the intake runners from that side and bring the runner to someone to deal with the bolt.
Sorry that happened. As far as the injectors, There are other considerations besides fit. Injectors are sized and have flow rates made into them. Also you need to compare the resistance. There are low resistance injectors and high resistance injectors. You need to match the resistance to the VW injectors by verifying with an ohm meter. |
brickster Samba Member
Joined: January 05, 2004 Posts: 604 Location: CO, USA
Posted: Fri Apr 09, 2021 9:06 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
By all means, if you feel out of your element, seek professional help. Ask here for a recommended shop in your area if you go that route.
I have successfully used a screw extractor set to solve this problem. If you decide to do that, I recommend that you start with a drill bit that is smaller than the extractor size you choose. Then, move up to the next drill bit size, etc. until you can insert the extractor. Give the extractor a few taps into the screw to ensure it's biting before you try to turn it out. |
4Gears4Tires Samba Member
Posted: Fri Apr 09, 2021 9:08 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
If you do attempt to drill out the broken bolt, remember to stuff paper towels in the injector holes so you don't get metal shavings down into your motor. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
'85 Westy Sciuridae Domus Edition |
Posted: Fri Apr 09, 2021 9:16 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
If you've never drilled a broken stud/bolt, and used an extractor, which if the bolt is cross threaded, won't work well, I'd pass it on to someone experienced. You can easily "F" this up exponentially for the person that will end up having to fix it. Snapped drill bit, broken extractor or if you are unlucky. both.
I'm not saying don't attempt it, but if you are a virgin, I'm saying don't attempt it. So, I guess I am saying, don't attempt it. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
dabaron Samba Member
Joined: June 21, 2018 Posts: 2745 Location: Philly, mang
Posted: Fri Apr 09, 2021 9:53 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
i'm sure you can find an intake runner pretty easily... i know Dave has several lying around
remove the two 13mm bolts holding the runner, put paper towels in the intakes, take the runner to a shop and they can remove it if it's beyond your ability.
bravo for tackling the job, welcome to the learning curve. _________________ 1991 Vanagon GL Camper
i had no idea i wanted to be a mechanic |
Posted: Fri Apr 09, 2021 10:30 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
https://www.thesamba.com/vw/classifieds/detail.php?id=2314038
$13 shipped. Not even worth messing with drilling out the bolt. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
Posted: Fri Apr 09, 2021 10:33 am Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
Stupid question and I could look it up. Is there a left and right?
Edit: looked it up and there is a left and right. Different part numbers. |
Posted: Fri Apr 09, 2021 12:18 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
The runner length is different. I wonder if this is to offset the clamps? _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
DanHoug Samba Member
Joined: December 05, 2016 Posts: 5915 Location: Bemidji, MN
Posted: Fri Apr 09, 2021 12:59 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
my holding bolt broke. got it out with the usual arsenal of patience and tools. was cleaning up the threads with a tap and i knocked the manifold off the bench, hit on the tap and broke the tap off below the surface. i cried and used a different manifold. need to get the tap out someday. _________________ -dan
www.thefixitworkshop.com |
JSlate Samba Member
Posted: Fri Apr 09, 2021 2:03 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| dabaron wrote: |
bravo for tackling the job, welcome to the learning curve. |
I didn't think that section could be removed. I was going to say, getting access to that fastener would have been extremely difficult to keep straight line access.
If I can take it out and put it on a bench, I'm confident I can remove it. |
Posted: Fri Apr 09, 2021 2:04 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| DanHoug wrote: |
| my holding bolt broke. got it out with the usual arsenal of patience and tools. was cleaning up the threads with a tap and i knocked the manifold off the bench, hit on the tap and broke the tap off below the surface. i cried and used a different manifold. need to get the tap out someday. |
That's the perfect example of the exponential problems that can arise. You don't have a tap extractor?
edit:
| Quote: |
That's the right attitude. Good luck. |
Posted: Fri Apr 09, 2021 2:52 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| Intake gasket fits 2 ways. Only one way is correct. |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3422 Location: Vancouver, B.C.
Posted: Fri Apr 09, 2021 3:52 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| DanHoug wrote: |
Chuck Norris could scare that bolt stub out with a sideways glance. Considering how hard taps are, the broken tap would require a roundhouse kick. _________________ '86 Syncro Westy SVX |
Posted: Fri Apr 09, 2021 3:53 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| 4Gears4Tires wrote: |
The runner length is different. I wonder if this is to offset the clamps? |
It may not be obvious to you folks raised in North America, but to me, it is obvious that runner is for the left hand drive (LHD) Vanagons. The UK export RHD vans, not including Syncros, which used Syncro-specific (higher ground clearance) runners, had the short/long sides reversed, which allowed for the higher compression on the DJ engines. Operating these UK-designated vehicles on the right hand side of the road could lead to lean misfires.
Okay, back to work now . . . _________________ '86 Syncro Westy SVX |
Posted: Fri Apr 09, 2021 4:58 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
Really? Syncro specific runners? I have a 2wd engine/intake in my syncro and no problems with the intake runners hitting. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
Posted: Fri Apr 09, 2021 5:07 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
If you drive on the left side of the road, they will hit the tarmac.
Seriously, though, I was joking in my two posts above, which I think you were aware of. _________________ '86 Syncro Westy SVX |
Posted: Fri Apr 09, 2021 7:17 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| This is a headless thread. |
Posted: Fri Apr 09, 2021 8:44 pm Post subject: Re: Newbie Help - Air flow meter and fuel injectors |
| Howesight wrote: |
Seriously, though, I was joking in my two posts above, which I think you were aware of. |
I 100% thought you were serious. After finding enough Syncro specific parts that my van was and is still missing, intake runners were totally in the realm of plausibility. _________________ '87 Syncro Ferric Oxyhydroxide Superleggera Edition
