Traveling after Building a bus for travel in Europe "euroBus"
Page: Previous  1, 2, 3 ... 32, 33, 34 ... 49, 50, 51  Next
dobryan Premium Member
dobryan is offline
PostPosted: Sun Apr 11, 2021 5:43 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
4Gears4Tires wrote:
They're multiplying! I see you are 100% sold on the NAHT!
Yep, after camping in the euroBus a few times my wife said she likes it better than the westy by a lot.
Dave O
The Western Syncro build
owokie
owokie is offline
PostPosted: Sun Apr 11, 2021 6:07 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Better not let her set foot in a Florida.
dobryan is offline
PostPosted: Sun Apr 11, 2021 6:19 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
That is on an LT frame? If so too big. Cool
Dave O
owokie
owokie is offline
PostPosted: Sun Apr 11, 2021 6:29 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Yup. Meh, 15' vanagon vs 16' LT. Hardly make or break.
dobryan is offline
PostPosted: Mon Apr 19, 2021 6:23 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
I added a rear/front camera system. (Thanks to Tom Hutch for the recommendation.)
https://smile.amazon.com/gp/product/B07XZ1D226/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This allows a virtual rear view mirror to be added to the standard rear view mirror. It is especially needed since I have blocked a good portion of the limited rear view with the cook box and will also have bicycles later too.
Here is the camera placement. It is off center but the image it gathers is fine.
The unit strapped to the rear view mirror. I ran the camera and power wires up under the windshield gasket so they are not visible. Notice how little view there is out the back window, and no bikes yet...
Power wires coming out the bottom corner.
Camera wires going into the headliner. It took me about an hour to fish these to the back. Next time I'll do this when I have the bus apart...
And driving image.
The other great thing is that this unit captures a 5 minute loop of front and rear video. If I am ever involved in an accident maybe I can use it to prove my innocence if necessary. This could be especially important in Europe where language could be an issue. (I hope never to find out.)
$33,450
$120 Van Top rear camera
$33,570
Dave O
danfromsyr
danfromsyr is offline
PostPosted: Mon Apr 19, 2021 7:29 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
nice, how is the rear camera night vision?
dobryan is offline
PostPosted: Mon Apr 19, 2021 7:33 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
My understanding is that is excellent. I have not had it out at night yet though.
Dave O
dobryan is offline
PostPosted: Mon Apr 19, 2021 10:45 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
So I went out and got the euroBus weighed on Friday.
Me in the drivers seat, half a tank of gas.
I figure I have about 2-300 pounds more of equipment and travel stuff to add.
So the solo weight will be about 4700 lbs. If I carry three passengers and gear then add 800 pounds for a max weight of 5500lbs.
I have been thinking that the Nokians I have on there now are really good smooth road tires but really are not going to hack it on rough roads that I know I will encounter. I want to move over to an all terrain tire for durability but do not want to go larger diameter since I am running a stock 2.1 (otherwise I'd go for the 215/75/15 BFG KO2s).
These Yokohama Geolandars in 215/70/15 look like just the ones I need. Only 2% taller than stock and they are also sold in Europe for when I need a replacement.
Geolandar A/T G015 - Size: 215/70R15
https://www.tirerack.com/tires/tires.jsp?tireMake=...HR5G015OWL
Load range 98 is 1653 lbs but needs to be derated by 9% since that is the passenger vehicle rating. So 1500 lbs per tire gives me 6000 lbs max weight (my load distribution will be very close to 50/50 front/rear).
I am comfortable that I will be within the load rating for these tires.
Time to get some ordered and installed! Very Happy
Dave O
dobryan is offline
PostPosted: Mon Apr 19, 2021 12:46 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
And I finally started on the under floor storage bin. (I intend this for tools and parts that I hope to rarely have to access. This way I can save the under seat storage for camping and living gear. The other spare parts area will be the bin under the drivers seat.)
When I removed the vinyl plank flooring I discovered that untreated plywood was a bad choice as an underlayment. I will get 1/2" pressure treated plywood to replace this. (Obviously some water had been spilled in the bus and got the plywood wet...)
Nice clean floor ready for surgery.
Opening up.
Treating the open wound edges with rustoleum.
Test fit of the first 1/16" thick aluminum side piece.
Three sides sitting in place. (The rear piece will be placed on after the bin is created as it does not overlap the opening. The bin goes about 4 inches under the floor.)
And the bottom laid in place. The bin now needs to be riveted and 3M 5200 used to hold it together and weatherproof it.
The inside dimension is about 9.5 " wide and 6.5" deep. It hangs no lower than the gas tank or transmission so it should be fine. Basically the same as a propane tank.
Dave O
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Apr 19, 2021 1:17 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Ambitious cutting! But great utilization of otherwise wasted space. How are you going to access it? 2 small hatches? 1 large hatch?
dobryan is offline
PostPosted: Mon Apr 19, 2021 3:47 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
One large flush floor hatch. Lift off, no hinge.
Not sure what 'handles' I am going to put on it. I'd like to find something that can fit flush to the floor and then somehow pop up to grab.
Dave O
danfromsyr
PostPosted: Mon Apr 19, 2021 7:08 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
very nice and an easy DIY method for those who can't weld
there are all sorts of options in the 'recessed latch' world.
some can even be used with a length of wire to a slide pin as a remote operation.
https://www.google.com/search?q=recessed+latch
Abscate wrote:
Wolfram
Wolfram is offline
PostPosted: Mon Apr 19, 2021 7:16 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Dave,
something like this for your new storage container?
https://www.absolutemarine.co.nz/2-flush-latch-316...64EALw_wcB
88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage.
dobryan is offline
PostPosted: Mon Apr 19, 2021 7:23 pm    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Thanks for the suggestions. I think I’ll go with this one. Looks clean and will not get clogged by dirt/sand like some of the fancy pop up ones.
https://sea-dog.com/groups/2477-flush-hatch-pull
Thanks to Mike Hanyi for the reference.
Dave O
DuncanS
DuncanS is offline
PostPosted: Tue Apr 20, 2021 4:28 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
If you are going with that one, I would suggest upgrading to:
https://sea-dog.com/groups/2948-hatch-handle-latch
It is what I use on my boat as it secures the hatch and prevents rattling.
Clip the under the seat end with something like the engine deck lid uses and the front will be held securely down with the handle/locking mechanism. Or you could just salvage the hardware from a donor engine deck lid.
dobryan is offline
PostPosted: Sat Apr 24, 2021 7:18 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Over time I have noticed that the gel coat on the NAHT has been weathering. I did not want to have to wax and polish it every year to keep it in shape. Mike Hanyi (puchfinland) works in a boatyard and recommended that I go with a two part topside polyurethane paint, specifically the Awl Grip products.
Here is what I used.
I chose that version of white because it had no yellow/brown tint in it. I would have gone with a slightly cooler white but it was not in stock.
Sanded the NAHT with 220 grit sand paper. One coat of primer rolled on with a 4" roller (use the rollers that say they are for varnish. The regular foam rollers for house paint tend to fall apart when these paints are used.) Sanded the primer a few days later with 320. Then applied two top coats. I used the flattener to give the finish a semi-gloss vs gloss (thanks Mike!) and am very happy with the results. The paint appears bulletproof.
For application of the top coat I found that I needed to work in a 2' area, roll the paint out, then go back over that area with the roller in a slightly dry condition to knock down any tiny air bubbles and overlaps. This resulted in a nice dimpled finish similar to the Westy poptop. I did not sand between top coats, about 2 hours between coats was enough for the first coat to set up and be ready for rolling the second coat.
It took 20 ounces of paint (2base + 2flattener + 1converter = 20 oz total) for one coat rolled on.
$33,570
$150 Paint ($300 for the total but I only used 50% on this top. I'll do the West Coast Westy NAHT with the remainder.)
$33,720
Dave O
dobryan is offline
PostPosted: Sat Apr 24, 2021 7:28 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
And I assembled the storage box.
I will need some spacers for the side closer to the slider since that part does not have the ridges that are in the center portion. Fortunately some leftover jalousie window pieces that are cut off when I do a conversion were just the right thickness.
I pop riveted and 3m5200'd it together.
Now I'll start working on the floor and hatch.
Dave O
djkeev
djkeev is offline
PostPosted: Sat Apr 24, 2021 9:29 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Your top looks great!
I tried a foam roller but all I got were hundreds of bubbles!
I ditched that and got a very short nap roller.
Dave
Ghia
Vanagon
Beetle
dobryan is offline
PostPosted: Sat Apr 24, 2021 11:05 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
Dave
Yep, the go over is necessary or the bubbles stay there.
Dave O
DuncanS
DuncanS is offline
PostPosted: Sat Apr 24, 2021 11:11 am    Post subject: Re: Building a bus for travel in Europe "euroBus" Reply with quote
4" sausage or hot dog rollers. Make sure they can handle aggressive solvents.
After a second coat there will be no bubbles if you are careful.
Page 33 of 51
