porkchop-rob Samba Member
Posted: Tue May 11, 2021 3:24 pm Post subject: Door speaker placement |
Anyone see anything horribly wrong with my proposed speaker locations? They do not interfere with the glass, dash, or window crank. They will be flush mounted through the door panel and to the steel door itself.
_________________ 1965 Beetle
1968 Beetle Baja (Son's First Car)
1976 Bus with Subaru (Wife's Riviera Camper) |
BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Tue May 11, 2021 3:50 pm Post subject: Re: Door speaker placement |
Just be aware that, by design, water will weep down the window and into the bottom of your door. You need to have a properly installed vapor barrier to protect your speakers. I personally do not like speakers in the door due to the moisture/water issues. Regardless of where you mount your speakers, make sure the weeps holes in the bottom of the door are clear. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Posted: Tue May 11, 2021 3:58 pm Post subject: Re: Door speaker placement |
Good point. I will install some modified baffles to keep the speakers dry. _________________ 1965 Beetle
JaimeH  Samba Member
Joined: April 24, 2012 Posts: 266 Location: Canterbury, NH
Posted: Tue May 11, 2021 4:05 pm Post subject: Re: Door speaker placement |
That just seems like a lot of metal to be removed. I used the opening below with a piece of aluminum angle to catch the 4th screw and stiffen the panel. I put riv-nuts on the angle and bolted through the panel to that.
_________________ 1978 Transporter 2.0 FI, BA6
Special Thanks to Razor's Customs, Boscawen, NH |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17615 Location: San Diego, California
Posted: Tue May 11, 2021 4:06 pm Post subject: Re: Door speaker placement |
Yes, I see something wrong _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue May 11, 2021 4:09 pm Post subject: Re: Door speaker placement |
aeromech wrote: |
Yes, I see something wrong |
? _________________ 1965 Beetle
germansupplyscott Samba Member
Posted: Tue May 11, 2021 6:10 pm Post subject: Re: Door speaker placement |
If I had to guess I'd say aero is thinking "don't cut holes in your bus for speakers, find another way that doesn't involve cutting". _________________ SL |
Posted: Tue May 11, 2021 6:59 pm Post subject: Re: Door speaker placement |
germansupplyscott wrote: |
If I had to guess I'd say aero is thinking "don't cut holes in your bus for speakers, find another way that doesn't involve cutting". |
Late bay bus, already cut on by ASI to become a Riviera Camper....cut on by PO for a single DIN radio....further cut on by a different PO and converted to Subaru power.
I'm not the least bit worried about a little German steel being lost on the way to the enjoyment of my bus. _________________ 1965 Beetle
richparker Samba Member
Joined: November 24, 2011 Posts: 7490 Location: Durango, CO
Posted: Tue May 11, 2021 9:07 pm Post subject: Re: Door speaker placement |
Just mount them to the door card so the magnet goes into the bottom hole, no cutting required. As stated above, make sure you use a vapor barrier. It’s not hard, buy some plastic drop cloth, spray the door with adhesive, stick on the plastic (leaving room for the speaker) and trim. You can buy speakers with a shallow magnet designed to clear the window for doors.
_________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1785 Location: Newmarket, ON
JaimeH  Samba Member
Posted: Wed May 12, 2021 3:49 am Post subject: Re: Door speaker placement |
If you don't mind removing metal and you've verified no interference go for it. You may get more sound to the listener with them up higher. My bus has the armrest vent so I went low. I prefer the tweeter a little higher than where you have it and maybe angled. Mine are in pods at the base of the A pillar. I kept twisting the pods to get what I wanted. A DSP will help. It's usually better to have more signal and tune down though.
jakokombi Samba Member
Joined: August 15, 2010 Posts: 780 Location: Milwaukee
Posted: Wed May 12, 2021 4:40 am Post subject: Re: Door speaker placement |
If you are not apposed to cutting steel, I cut them into my dash and don't regret it.
https://www.thesamba.com/vw/gallery/pix/1368391.jpg _________________ 70 Sunroof Kombi
85 Motherfukinvanagon
73 Thing
72 Baja |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2074 Location: Ontario Canada
Posted: Wed May 12, 2021 5:19 am Post subject: Re: Door speaker placement |
I installed speakers in the kick panels under the dash snuggled in beside the headlite pots _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
Mberglo Samba Member
Joined: January 13, 2020 Posts: 387 Location: Huntsville, AL
Posted: Wed May 12, 2021 6:23 am Post subject: Re: Door speaker placement |
I installed dual 3.5" in the center of the dash. No cutting, and the sound bounces off the windshield right to you.
alman72 Samba Member
Joined: October 09, 2014 Posts: 2575 Location: MICHIGAN
Posted: Wed May 12, 2021 8:02 am Post subject: Re: Door speaker placement |
2 vintage Realistic speaker boxes behind my seats with a bunch of extra cordage to move them around anywhere when i am parked. even outside on the roof. |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5818 Location: Wamego, Kansas, USA
Posted: Thu May 13, 2021 7:20 am Post subject: Re: Door speaker placement |
Ha ha, we're getting way off the original question! But since that's happened:
You can buy vintage style speakers that take both the left and right signal and send it to the same speaker. (May be dual cone, I'm not sure.) That would work nicely in the dash spot.
In my Buses, I installed a single speaker in the dash spot. Then wired the positive of one side and the negative of the other side to it. Correction: Wired the positive wire of one side to the positive of the speaker, and the positive wire of the other side to the negative of the speaker. That is supposed to make it basically a center channel. (if I understood everything I read correctly!)
I do also have (in one bus) door speakers down low and (in the other bus) speakers mounted under the dash screwed to the air vent as someone else showed.
The center channel bounces off the windshield and provides a nice fill. Especially nice when listening to spoken word stuff (news, podcasts).
I actually also installed a "pot" to control the volume of the center speaker, so I can turn it down if listening to music and want a little more stereo separation. _________________ Dave Cook
1973 Wild Westerner
My Thing
Posted: Thu May 13, 2021 7:23 am Post subject: Re: Door speaker placement |
Quote: |
Then wired the positive of one side and the negative of the other side to it. That is supposed to make it basically a center channel |
I don't think it works that way.
And a dual cone just has two speakers with one input. It will play left or right, but not both. |
Posted: Thu May 13, 2021 7:32 am Post subject: Re: Door speaker placement |
Mberglo wrote: |
Thanks for the catch. Edited my post.
For "dual cone" wasn't thinking like a coax speaker (essentially a mid/low speaker, with tweeter in the middle) but basically two cones right next to each other, in one housing.
Here's an example: https://www.crutchfield.com/S-WVpy6vTHnTy/p_068D57...jMQAvD_BwE
Looks like it is a combo of the two ideas:
A "coax" speaker with the lows coming out of one combined cone (probably combined similar to how I described) with two high range cones for a little bit of stereo separation. _________________ Dave Cook
1973 Wild Westerner
My Thing |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5966 Location: Los Alamos, New Mexico, USA
Posted: Thu May 13, 2021 7:43 am Post subject: Re: Door speaker placement |
This may not be helpful advice, but I removed the stereo and speakers from my truck entirely. I just use an mp3 player (e.g. phone) and headphones. Speakers are so old school. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
