Vanagon Misfire and Stall fault finding
ZsZ
ZsZ is offline
PostPosted: Tue Jun 22, 2021 12:39 am    Post subject: Vanagon Misfire and Stall fault finding Reply with quote
This vid popped up on my YT start page, looks like it has good info on fault finding:
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
djkeev
djkeev is offline
PostPosted: Tue Jun 22, 2021 3:52 am    Post subject: Re: Vanagon Misfire and Stall fault finding Reply with quote
Smart guy with diagnostic skills.
Plus,
He owns tools that I don't and honestly? Never will.
Dave
Ghia
Vanagon
Beetle
wesitarz
wesitarz is offline
PostPosted: Tue Jun 22, 2021 5:28 pm    Post subject: Re: Vanagon Misfire and Stall fault finding Reply with quote
Ha,ha,ha,.ha. Just watched it in my feed. No longer my engine but interesting.
DanHoug
DanHoug is offline
PostPosted: Tue Jun 22, 2021 5:58 pm    Post subject: Re: Vanagon Misfire and Stall fault finding Reply with quote
great skills and use of the scope and gas meter... but i wonder if instead of adding a ballast resistor to a "new" coil he should have checked the spec of the coil installed. there's so many different specs on these Bosch coils with the identical form factor, so maybe one with a high primary current got installed and was causing the ECU to fault.
it was great to find out that the ECU will 'multi-strike' with high coil amperage. it's another parameter i need to check out and find the baseline for.
-dan
www.thefixitworkshop.com
16CVs
16CVs is offline
PostPosted: Tue Jun 22, 2021 11:55 pm    Post subject: Re: Vanagon Misfire and Stall fault finding Reply with quote
Great point. There are many different coils and they specifically list a separate coil for a Digifant or newer van. Makes you wonder if the van just has the wrong coil on it?
Samba member # 14980
ZsZ
ZsZ is offline
PostPosted: Wed Jun 23, 2021 1:41 am    Post subject: Re: Vanagon Misfire and Stall fault finding Reply with quote
I think the owner threw on a significant amount of money and preferred "no parts required" repair rather than start buying "maybe this will be good now" parts.
Maybe a VW/Vanagon spacialized shop (or an advanced home mechanic Wink ) would investigate which vendor/brand/partnr coils are good to use.
Zoltan
Robw_z
Robw_z is offline
PostPosted: Thu Jul 01, 2021 6:43 pm    Post subject: Re: Vanagon Misfire and Stall fault finding Reply with quote
Whatever the speculation, this guy seems a lot smarter than me and like he knows what he's doing. I'm now curious if my engine is "missing out" on running better due to an issue like this, I can't pass emissions in spite of many new sensors and a good motor.
I wonder if this thread title is not doing the video contained therein justice, I almost didn't click.
-Rob
