Stretching clutch cable.
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 9:24 am    Post subject: Stretching clutch cable. Reply with quote
Hi folks. I have a strange issue. I have what acts like a stretching clutch cable. At first I thought it was the classic loose tranny ground scenario, which part of it may have been. I cleaned and tightened the transmission to body ground and checked the Bowden tube and all appear normal. After about 15 minutes of driving, shifting the bus starts to act like my clutch is out of adjustment again. Any thoughts? I don't think it is the cross shaft, because after it cools down it seems to be in adjustment again. Is there another ground I am missing perhaps?
cmonSTART
cmonSTART is offline
PostPosted: Sat Sep 18, 2021 9:39 am    Post subject: Re: Stretching clutch cable. Reply with quote
So, does it feel like it stretches when it warms up, but goes back to normal when it cools down?
'78 Bus 2.0FI
de K1IGS
mikewire Premium Member
mikewire is offline
PostPosted: Sat Sep 18, 2021 9:41 am    Post subject: Re: Stretching clutch cable. Reply with quote
Can you expand on what you are experiencing?
Like hard to go into gear? Or...?
What's the condition of your shift bushings and coupler?
-Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe 221(5) w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Classifieds Feedback
SGKent Premium Member
SGKent is offline
PostPosted: Sat Sep 18, 2021 10:10 am    Post subject: Re: Stretching clutch cable. Reply with quote
check the transmission ground strap. If it is a bad or corroded connection then the clutch cable carries the load and gets hot. Also check the last weld where the tube ends. If it is bad the tube can flex. If you have to weld it make sure whomever does it doesn't poke thru the tube to leave a spot the cable can chaff on.
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 10:17 am    Post subject: Re: Stretching clutch cable. Reply with quote
yes
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 10:19 am    Post subject: Re: Stretching clutch cable. Reply with quote
Yes, on start up and early driving, shifting is pretty normal. Then it starts grinding into gear like the clutch isn’t fully disengaged.
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 10:22 am    Post subject: Re: Stretching clutch cable. Reply with quote
Hi Steve. Transmission ground strap was the first thing I did. Cleaned and tightened. I’ll see if the cable is hot next time I drive it. Bowden tube looks good, but I will double check.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Sep 18, 2021 10:26 am    Post subject: Re: Stretching clutch cable. Reply with quote
no idea what you have here. T1? T4?
either way, sounds to me like a failing pilot bearing.
i've had 2 T4 buses that shifted fine cold but couldn't get to shift after about 10-15 mins. after 1/2 hour, you couldn't shift at all
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
aeromech
aeromech is offline
PostPosted: Sat Sep 18, 2021 10:33 am    Post subject: Re: Stretching clutch cable. Reply with quote
Does the pedal free play seem to change and then change back or is it just the difficulty in changing gears that changes?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
TomWesty
TomWesty is offline
Too lazy to put it in my sig line. T1 with OG tranny. 1971 Westy.
aeromech
aeromech is offline
PostPosted: Sat Sep 18, 2021 10:44 am    Post subject: Re: Stretching clutch cable. Reply with quote
I’ve seen cables start snapping strands. This causes cable stretch but you tighten the wing nut and it just stretches more. Doesn’t seem to be your case.
Might be the needle bearing going. Not too hard on a 1971 to change. How long has it been since you looked at the clutch?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
cmonSTART
PostPosted: Sat Sep 18, 2021 10:48 am    Post subject: Re: Stretching clutch cable. Reply with quote
Same here - really sounds like a pilot bearing or some other issue. I have had clutch cables stretch because they're breaking as Aeromech said, but they never go back to normal when cooled down obviously.
Is your pedal freeplay changing?
'78 Bus 2.0FI
de K1IGS
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 11:37 am    Post subject: Re: Stretching clutch cable. Reply with quote
Thanks!
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 11:39 am    Post subject: Re: Stretching clutch cable. Reply with quote
I’ll check freeplay. I need to do pilot bearing and all shift bushings/ coupler. Thank you!
Wildthings
Wildthings is offline
PostPosted: Sat Sep 18, 2021 11:52 am    Post subject: Re: Stretching clutch cable. Reply with quote
Just run a band clamp around the torsion tube and the clutch tube and tighten it up well, no need to do any welding. One can even just use cordage if they are good with knots.
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 2:45 pm    Post subject: Re: Stretching clutch cable. Reply with quote
Thanks!
SGKent is offline
PostPosted: Sat Sep 18, 2021 3:03 pm    Post subject: Re: Stretching clutch cable. Reply with quote
if the ONLY reason you are worried about the cable is because the trans shifts hard, check the oil in it, and also consider a new pilot bearing.
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 5:04 pm    Post subject: Re: Stretching clutch cable. Reply with quote
I drove it quite a bit today and I think I need to adjust the clutch cable once more, but more importantly I think it’s time for shift coupler and bushings. The cable didn’t seem to stretch any and I noticed if I went from neutral to first it would grind going in to first. If I went into second before shifting into first it would not grind. This was while being at a stop. This all started when I was jacking my bus up and down a lot and putting it on ramps etc. to do brake work. I think shifter stuff that was already old and decrepit just got even more decrepit due to the flexing.
SGKent is offline
PostPosted: Sat Sep 18, 2021 5:19 pm    Post subject: Re: Stretching clutch cable. Reply with quote
the syncho in 2nd is stopping the shaft from spinning. Then it goes into gear. It could be a bad pilot bearing or a warped clutch disc too. Use a tape measure to check free play like in the video at the link below I set up a couple years ago to assist someone else.
http://kentcomputer.com/77VW/clutch_freeplay.AVI
TomWesty
TomWesty is offline
PostPosted: Sat Sep 18, 2021 5:38 pm    Post subject: Re: Stretching clutch cable. Reply with quote
I think I measured about an inch, but I’ll check it again.
