cyclehobby Samba Member
Joined: August 29, 2013 Posts: 160 Location: North Jersey
Posted: Tue Sep 21, 2021 9:22 am Post subject: Re: Filling transaxle oil while on jack stands? |
Me too. Simple. _________________ 1967 Beetle
Northern NJ |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3338 Location: N.E. Oklahoma
Posted: Tue Sep 21, 2021 9:56 am Post subject: Re: Filling transaxle oil while on jack stands? |
| richparker wrote: |
| Cusser wrote: |
| I use a gear oil pump that screws into the container, from auto parts store. |
This is what I use as well. |
Good method, for sure - I did it that way, when, I was younger... z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Sun Sep 26, 2021 8:01 am Post subject: Re: Filling transaxle oil while on jack stands? |
| While the engine is in, I just jack up the driver side rear wheel and remove the wheel,put a jack stand under the car and pump in the fluid. |
ekrossi Samba Member
Joined: March 16, 2008 Posts: 195 Location: outside Jonesborough, TN
Posted: Fri May 09, 2025 8:18 am Post subject: Re: Filling transaxle oil while on jack stands? |
Reviving and old post here.
I've spent more time changing my swing axle boots than I care to admit. My question is do the boots ever become so filled with oil that they need to be opened up and drained periodically? |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 810 Location: Reno NV
Posted: Fri May 09, 2025 8:59 am Post subject: Re: Filling transaxle oil while on jack stands? |
| just put it on and forget it intel they leak again. set the seam at the 10 or 2 O'clock position. some say 9 or 3 |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Fri May 09, 2025 9:00 am Post subject: Re: Filling transaxle oil while on jack stands? |
| ekrossi wrote: |
Nope. _________________ 1960 Ragtop w/Semaphores "Inga" |
richparker Samba Member
Joined: November 24, 2011 Posts: 7818 Location: Durango, CO
Posted: Fri May 09, 2025 9:13 am Post subject: Re: Filling transaxle oil while on jack stands? |
Hey, my old thread.
Since I’ve posted this I went to jacking the whole car up so I can fit under it and just pumping in the oil in till it starts coming out the fill hole, just like I do on my bus. Then I move on to something else as posted on the first page.
I’m currently using SuperTech 80/90 GL5 gear oil. It says right on the container that it’s good for yellow metals. I was using STP prior and can definitely feel the difference between the two oils. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab |
Posted: Fri May 09, 2025 9:37 am Post subject: Re: Filling transaxle oil while on jack stands? |
| "can definitely feel the difference between the two oils." as to what? I use GL5 myself. I have read the posts about the yellow metal debate between GL4 and GL5 and its always about the protecting the yellow metal but they forget there is a Ring and Pinion in the trans with some steep gears. |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1081 Location: San Juan Islands
Posted: Fri May 09, 2025 10:06 am Post subject: Re: Filling transaxle oil while on jack stands? |
I do level on stands or lift, axles down (already mentioned fill is above axles). Fill until dribbles out a little, rotate drum often. Walk away for 20-30 minutes, come back, rotate drum, top off. Should be good after that.
If you want to get a little extra oil in the box:
Jack the drivers (fill side) up just a little allowing the passenger side to be slightly lower. You'll notice the gear level drops below the fill port. Presto, can get another 1/4-ish quart in there if you like. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Fri May 09, 2025 2:42 pm Post subject: Re: Filling transaxle oil while on jack stands? |
| halfassleatherworks wrote: |
It shifts better.
I run the same oil in my bus. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’71 Double Cab |
indianpeaksjoe  Samba Member
Posted: Mon May 12, 2025 7:54 am Post subject: Re: Filling transaxle oil while on jack stands? |
FWIW if people find this thread via google I don't use a pump on my transmission but these bags of transmission oil. Makes it super easy.
-Joe _________________ Adventures in owning a 66 beetle |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1063 Location: South Florida
Posted: Mon May 12, 2025 12:10 pm Post subject: Re: Filling transaxle oil while on jack stands? |
| +1 for Valvoline FlexFill - Bag is wonderful, top is form'd helpfully, and it even has the original German trans oil stink! |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1029 Location: Eastern north carolina
Posted: Tue May 13, 2025 5:20 pm Post subject: Re: Filling transaxle oil while on jack stands? |
| I just did this the other day with the Valvoline flex bags. Very easy to use and you can squeeze it into the fill hole from an almost level plane. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2861 Location: Santa Cruz, CA
Posted: Tue May 13, 2025 6:37 pm Post subject: Re: Filling transaxle oil while on jack stands? |
| Cusser wrote: |
If using one of these pumps, here's a tip to make the job a little easier: Fill a large pot with water, put it on the stove and heat to a boil. Turn off the flame and place the jugs of oil in the heated water for 15-20 min. This will thin out the oil and make pumping it into the trans much easier, and the job will go quicker too. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
wdfifteen Samba Member
Posted: Wed May 14, 2025 6:20 am Post subject: Re: Filling transaxle oil while on jack stands? |
Well, it was a quick, and really dirty way to do it, but...
I jacked the car up and let the axles hang. Then filled the trans to almost the level of the fill hole, but not quite. Then left the plug out and let the car down. Rolled it back and forth until the axles leveled out. When the oil stopped running out, I jacked it back up enough to put the plug back in.
I told you it was dirty. |
Posted: Wed May 14, 2025 6:23 am Post subject: Re: Filling transaxle oil while on jack stands? |
| MrGoodtunes wrote: |
Do they sell it in no-synthetic in those flex bags yet? They work really great, but I don't need synthetic for a car that's driven less than 1000 miles a year. The flex bads of synthetic was $20 a quart when I last filled a car. |
Posted: Wed May 14, 2025 11:33 am Post subject: Re: Filling transaxle oil while on jack stands? |
| wdfifteen wrote: |
Do they sell it in no-synthetic in those flex bags yet? ... |
Have not seen such. What I'm doing now is keeping the used bag, but filling it with Redline MT-90; based on this post & posts before it in this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?p=10382167#10382167 |
Bielakt13 Samba Member
Posted: Thu May 15, 2025 10:03 am Post subject: Re: Filling transaxle oil while on jack stands? |
| indianpeaksjoe wrote: |
-Joe |
How many of these bags did it take to fill it up? |
