westy66 Samba Member
Joined: November 11, 2004 Posts: 349 Location: Cleveland, OH
Posted: Mon Feb 20, 2012 1:55 pm Post subject: Suitable hose for brake fluid use |
after searching here and elsewhere im coming up empty on a replacement for a hose to connect the upper and lower brake fluid reservoirs (on my 68 ).
all ive found some hydraulic hose at McMaster, but im wondering if its pliable/flexible enough to be able to be clamped onto the reservoirs and not leak.
http://www.mcmaster.com/#hydraulic-fluid-hose/=gc1oyv
Joined: January 01, 2007 Posts: 17915 Location: sticksville, ct.
Posted: Mon Feb 20, 2012 2:32 pm Post subject: |
i used chemical resistant PVC tubing like this
http://www.graylineinc.com/tubing-materials/polyurethane.html
it was pretty cheap at our local agriculture supply house. it has been on my 70 single cab since 09 with no ill effect _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3443 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Feb 21, 2012 10:27 am Post subject: |
Bob,
Hit up Euclid and see if the blue hose for a bug will fit. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42889 Location: at the beach
Posted: Tue Feb 21, 2012 11:38 am Post subject: |
7mm blue brake hose (make sure that is the size you need) is part number N203501 _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Tue Feb 21, 2012 12:30 pm Post subject: |
| The 7mm bug stuff is much too small. This is closer to 3/8 or 7/16. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4852 Location: Kaneohe
Posted: Tue Feb 21, 2012 1:11 pm Post subject: |
I have used vinyl aquarium tubing for bleeding the brakes and there seems to have been no deterioration when it it has been left wet for several years. but ...
And related questions:
I would like to purchase a wash bottle to fill my upper brake fluid reservoir.
I found this on the Grainger Supply website. This wash bottle may be suitable, but is the material resistant to brake fluid? And, where can I buy only one locally.
Aloha
tp |
SGKent  Samba Member
Posted: Tue Feb 21, 2012 2:40 pm Post subject: |
| Tom Powell wrote: |
Aloha
tp |
Brake fluid should be kept in a solid sealed container at all times because it is designed to pull moisture into itself. That means when it is exposed to air it pulls water from the air. If you use a fill bottle like that you will have to empty it each time you use it back into a sealed bottle. Many professional shops will even tape the necks of their sealed brake fluid bottles once they have been opened to slow the process. Even Castrol LMA (low moisture absorbsion) fluid will eventually pull enough moisture from the air to allow rust. _________________ George Carlin:
Posted: Tue Feb 21, 2012 3:05 pm Post subject: |
True what you say SGKent. I checked Prestone website for synthetic brake fluid and nothing about moisture absorbing characteristics. I will heed your advice about storage.
In the meantime I'll still be looking to buy a wash bottle for filling the top reservoir.
Aloha
tp |
Posted: Tue Feb 21, 2012 8:14 pm Post subject: |
The filling issue has me considering relocating the reservoir to behind the seat. I'm dumping my cracked 68 only one for the $19 Wolfsburg special
Posted: Thu Feb 23, 2012 2:58 pm Post subject: |
jpeters Samba Member
Joined: May 06, 2005 Posts: 1063 Location: Woodsfield, Ohio
Posted: Thu Jan 16, 2014 1:17 pm Post subject: |
Anyone ever find a solution to this? I'm in the exact same boat. I would like to run a rubber line from the upper to lower reservoir in order to replace the metal line on my 68. I nicked the metal line with the grinder when cutting out the floor and now it needs replaced. The biggest I saw online doing a quick search was 7mm, but I know that will be too small. Is the chemical resistant PVS tubing the best answer? _________________ '73 Westy
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'66 Bug
'63 Bug (Big Bore 40hp)
@neverdnf on Instagram |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13602 Location: West Coast, USA
Posted: Thu Jan 16, 2014 2:39 pm Post subject: |
| jpeters wrote: |
| Anyone ever find a solution to this? I'm in the exact same boat. I would like to run a rubber line from the upper to lower reservoir in order to replace the metal line on my 68. I nicked the metal line with the grinder when cutting out the floor and now it needs replaced. The biggest I saw online doing a quick search was 7mm, but I know that will be too small. Is the chemical resistant PVS tubing the best answer? |
This topic comes up quite a bit in threads on adding power brakes to 68-70 buses. Aeromech has a good tutorial with a nice debate afterwards. I can't copy the link from my phone here, sorry, and happy searching. He also contacted Gates and found a hose from their barricade line, I believe, that was certified brake fluid resistant.
There is also a thread on converting to a dual-reservoir style setup from a late beetle. You would use blue rubber VW brake fluid hose to make short connections to metal brake lines that you bend through the bus, and then use more blue VW brake fluid hose to make connections to the nipples on the master cylinder. _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
Skoolieman Samba Member
Joined: January 31, 2011 Posts: 573 Location: Chattanooga TN
Posted: Thu Jan 16, 2014 4:27 pm Post subject: |
[quote="asiab3"]
| jpeters wrote: |
There is also a thread on converting to a dual-reservoir style setup from a late beetle. You would use blue rubber VW brake fluid hose to make short connections to metal brake lines that you bend through the bus, and then use more blue VW brake fluid hose to make connections to the nipples on the master cylinder. |
This is what I did I relocated the reservoir under the drivers seat using brake line and blue beetle hose two years later hasn't leaked a drop. _________________ '69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion |
Posted: Fri Jan 17, 2014 9:44 am Post subject: |
| jpeters wrote: |
In another thread on the same topic they said that this EPDM tubing would work.
http://www.mcmaster.com/#9776t11/=qafox5
Anyone have any experience with it? Seems like it should work. I would relocate the reservoir, but I don't plan on adding power brakes anytime soon. There won't be any pressure involved, so it seems like it should work. |
It says it works with Ethylene Glycol, however, the way its worded makes me think it wouldnt be suitable for a brake system. FWIW I didnt relocate mine because I added power brakes, I relocated it due to lack of quality available parts for a 69. _________________ '69 Westfalia Camper~Cassidy
Casey Ryan Samba Member
Joined: August 06, 2008 Posts: 340 Location: Downers Grove, IL
Posted: Fri Jan 17, 2014 10:27 pm Post subject: |
I have a 71 and just solved this problem.
Gates makes a DOT certified Vacuum hose that will withstand brake fluid. In the 71 it's a 15/32 inner diameter hose. You can search for "Gates 27233 Power Brake Vacuum Hose" and get it at Carquest or O'Reilly. It fits perfectly on the 71 reservoir pictured earlier in the thread.
If that's too big, there's also a smaller diameter hose 11/32 if you search "Gates 27232 Power Brake Vacuum Hose".
I was able to get it at carquest same day for about $10 for 3ft.
It has a larger outer diameter than the original so I had to enlarge the holes with a step-bit.
I took a bunch of pics and posted them here:
http://www.vwbusblog.com/photos?album=71BusBrakeFluidReservoir
Aeromech is the one that found this hose, but I can't find the thread that he said it in.
Casey _________________ '78 Riviera Camper
Blog: www.facebook.com/VWBusBlog |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17731 Location: San Diego, California
Posted: Thu Sep 30, 2021 6:14 pm Post subject: Re: Suitable hose for brake fluid use |
I posted that in like 2014 and have used the gates hose several times. I just recently got some feedback that the gates hose had swelled. He said he thought that brake fluid had gotten into the sidewall somehow. I trust the guy who said this so Iโm passing along this info. Iโm looking for a good substitute but doubt Tygon tubing would work just because itโs so easy to find I figure that if it was the solution, I would already be using it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23370 Location: Oklahoma City
Posted: Thu Sep 30, 2021 8:16 pm Post subject: Re: Suitable hose for brake fluid use |
Look.....start learning the rules about about materials!
The ONLY "RUBBER" that works well with brake fluid is EPDM. Its what all of the inner seals are made of in the brake system....and the windshield and window gaskets (because of its great UV resistance).
The most bad ass rubber in the world against solvents and gasoline.....rubbers like "VITON"....fluoroelastomers.......die an ugly and tragic death with brake fluid. So don't use them.
Likewise.....EPDM and earlier EPR (used with 1950's and earlier mineral based brake fluid).....die an ugly death when exposed to SOLVENTS and VOC's like gasoline.
Yes....as Skills noted....you "can" get away with a basic "PVC"...vinyl based.....if you like the look and strength. It WILL harden up over time but will not dissolve or melt.
You CAN also use pure silicone rubber. Its has no issues with brake fluids...but is expensive, harder to find and tears very easily. Its just not the right stuff....but will work.
EPDM rubber tubing is not hard to find .McMaster Carr and many rubber/hose companies have miles of it. Just search for it.....ask for it.
EPDM.....now you now what it is. Ray |
Posted: Thu Sep 30, 2021 8:28 pm Post subject: Re: Suitable hose for brake fluid use |
Send a link Ray and Iโll let you off the hook _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Abscate Samba Member
Joined: October 05, 2014 Posts: 24294 Location: NYC/Upstate/ROW
Posted: Fri Oct 01, 2021 4:22 am Post subject: Re: Suitable hose for brake fluid use |
I use Tygon for brake bleeding amd with just that short exposure I have to clip the end off the next time I bleed.
For constant contact, EDPM hose only. _________________ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐บ๐ธ ๐ ๐ ๐ |
