Best Car Camping Stoves and Equipment
JudoJeff
JudoJeff is offline
PostPosted: Fri Oct 29, 2021 9:04 am    Post subject: Best Car Camping Stoves and Equipment Reply with quote
BEST CAR CAMPING STOVES AND EQUIPMENT
Car camping stoves are not built into a camper, but are taken out and setup on a picnic table, etc to cook. Only two burner models will be covered here.
My camper has a built-in stove, but I don’t like to cook inside. Too much bother to clean afterwards, and lingering odors. Learned this lesson by cooking bacon once!
All of the comments here are my opinions, and you can post rebuttals as long as you’re nice about it.
Stoves: (All are two burners, are easy to carry or store, and run on propane.)
GOOD: Coleman Classic, sells for $44 new, often found unused at tag sales for $20.
This is a solid, last forever unit. The burners are rated at 9000 BTUs, which is weak and takes forever to boil water. The company got so many complaints all the newer models approach 20,000 BTUs. You must light the flame, no auto-ignitor. OK spacing between the burners for large pots. A frying pan and coffee pot fit no problem. Many griddles will fit on this stove, and give you more versatility.
BETTER: Eureka Ignite Plus, sells for $100-$140. 20,000 BTUs, wide spacing between the burners fit large pots, push button auto-ignitor. Solid, well built unit, will give years of service. Burners allow a simmer setting to keep your burritos warm.
BEST: Camp Chef Everest, sells for $90-$140, rated at 20,000 BTUs, wide spacing between the burners fit large pots, twist knob auto-ignitor. Very solid, well built unit, will give years of service. Burners allow a simmer setting to keep your burritos warm. Auto ignitor is hard to turn.
You can get most of these in a model that has one burner and a grill. Nice if that’s the way you like to cook. I’d suggest buying a two burner, and buying a separate griddle and grill, which you can place over the burners when required. I’ve done that for years!
Comments about single burner stoves:
I find these unsafe, and poorly designed. The ones that are attached to a propane one pound bottle tipped over so often they now come with a Mickey Mouse plastic bottom. Someone bumps the table, and you get a pan of hot bacon grease in your lap !
They are now made wider and flatter. Poor heat output, especially the ones that use butane. If you use a very large pot you can melt the plastic.
Especially dangerous is the cast iron model that sells for $20. If you left it out in the rain, the water gets into the burner. When you light it, the propane blows everything out and into your face. They rust while you watch, too.
Comments on white gas Coleman stoves:
While these are great and last forever, I don’t like to carry the cans of gas. For $15 you can buy an adapter to run them on propane, which I recommend. It plugs in and out easily, and doesn’t permanently changeover the stove. You can still use the gas tank if you want to.
If your gas stove has stopped working, clean the regulator and it will be fine again. Carbon builds up in it when the wrong gas type is used. You can buy a new regulator for a dollar…
NESTING COOKWARE SETS
GOOD: GSI Base Camp, $90-$120, compact storage for your cooking set, frying pan and two pots with covers. Handles are built in, with a silicone cover. Thin metal, and tinny. Pots can thwack as you heat them up, and spray hot oil at you. While these are much better quality than crap like Ozark Trail produces, I’d spend the tiny bit more on the next set.
BETTER: Stanley Pro Cook set, $90-$135. Very well built, with a 3-ply bottom which disperses the heat. Set includes compact storage for your cooking set, frying pan and two pots with covers, two pot holders, cutting board, and spoon/spatula. Lids have holes to easily drain them.
BEST: Magma cookware, comes in a variety of sets, from 7 to 10 parts. (They consider a bungi-cord one of the parts…) $90-$250, look on eBay for best deals. Handles are not attached, so make sure they are part of the set. (Impossible to find) These have a much thicker, 3 ply bottom, heavier sides, and are very solid. They will last a lifetime. I wouldn’t hesitate to buy a used set. Popular with boaters, too. A carry bag is available for very neat storage, Amazon has the best price.
Comments:
If you own a dutch oven or LeCrueset pot, you can make almost anything on these stoves.
A pressure cooker works well, too. One of the above sets and a dutch oven should be all you need to produce great meals!
If you make a mess of the stove cooking something messy, it is easy to clean. The grill will pop off, and then you can cover the burner heads with plastic wrap or tinfoil. Spray oven cleaner on it and let it soak . Scrub with an SOS type pads.
Post any comments and tell us which stove or cookware you prefer.
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout)
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Oct 29, 2021 9:16 am    Post subject: Re: BEST CAR CAMPING STOVES AND EQUIPMENT Reply with quote
Thanks for the hints and reviews!
My 2c: Can't beat the original.
I am cleaning and returning to service the one my dad bought around 1960. I even has the (tattered) original box! I have a later heater and lantern.
I like white gas models. Most can run regular gasoline but you have to clean the jet afterwords. But you never run out. Same fuel runs heater, lantern. Nothing to throw away when empty (most local stores no longer recycle propane canisters). I guess I like the vintage look and it brings back good times from childhood. They seem crude but as a Boy Scout backpacker in my youth, that was living the high life to have a stove!
But I admit the propane ones seem to burn cleaner. I might check out the converters, especially since I can change back if I don't like it.
I like the thin aluminum pots and pans. I can clean them with sand if water isn't available. I don't mind if they get beat up or dirty (on the outside!), and can even use them on a campfire if needed without my freaking out. I keep one thicker fry pan since the thin ones distort and burn food in spots.
Emily's Owner Premium Member
Emily's Owner is offline
PostPosted: Fri Oct 29, 2021 4:35 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
I have a Coleman Fold-N-Go that I use. It's quite compact and is useable with 2 fairly good sized pots if need be. It doesn't have a windscreen, but that's usually not a big deal for me.
We also have my family's old white gas Coleman stove, which I find fussy, and a newer big Coleman 2 burner propane stove. I'm not the biggest fan of alcohol stoves having set the curtains on fire on a sailboat trying to get dinner started when quite heeled over (overnight race) Shocked .
I still tend to use the Fold-N-Go the most. My dad, being a big snow camping fan when we were kids, also has a huge assortment of mountain climbing stoves and whatnot - we will have the most epic garage sale in the future Rolling Eyes
Xargaret
ITMC - OG Den Mother
What (and I cannot stress this enough) The Actual Fuck?!
1974 Transporter
2025 Subaru Outback
busdaddy
busdaddy is offline
PostPosted: Fri Oct 29, 2021 5:16 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
I love the old Coleman white gas stove, the ritual to fire it up, and the smell screams CAMPING!. But I did upgrade to the propane version a few years ago, it bought me alot more space under the jump seat (size of folded stove and fuel), and it's lighter too. Same with lanterns, old school cool is great, but convenience and weight/size wins sometimes.
Those upgrades look really nice, but I don't usually get too gourmet when roughing it, so some basic fast heat for coffee and simple meals is all I need.
Слава Україні!
Pruneman99
Pruneman99 is offline
PostPosted: Fri Oct 29, 2021 5:46 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
I have the original one like KTphil posted. My father gave it to me with two Colman lanterns. They are quite a bit older than I am, and work great.
I've only need to replace the plunger seals. I got a replacement plunger, and it was garbage Sad
Not much is made to last like the old stuff!
vwmerckx Premium Member
vwmerckx is offline
PostPosted: Fri Oct 29, 2021 6:21 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
Vintage Coleman Stove in Rocky Point, Mexico, Circa 1964. My father's Coleman stove which I still have and carry in my '71 Westphalia - but sure wish we still had his 1963 !!
Our mother....we were the only ones that camped there for years...then got overgrown with tourists
Fuzzy headed me looking out at the ocean....
Q-Dog
Q-Dog is offline
PostPosted: Fri Oct 29, 2021 6:55 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
Someone gave me a propane stove that has a grill and a burner. Works OK, but I dislike the throwaway fuel canisters so I bought a hose that lets me use it with a regular propane tank and I use it around the house once in a while.
I prefer white gas stoves for camping. I have a single burner gas stove I bought for backpacking almost 40 years ago that goes on almost every hiking or car camping trip I do. I sometimes carry it in the RV too.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
Busstom
Busstom is offline
PostPosted: Sat Oct 30, 2021 12:11 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
JudoJeff wrote:
Thanks for the reviews. I too have this stove, for several years, so needless to say I'm happy to see you rated it "Best." Smile
I also suggest an upgrade that puts it miles ahead of the as-delivered stove out of the box: the flexible regulator kit. The rigid elbow pipe regulator that they ship it with is absurdly awkward and the weight of the cylinder lying at an angle puts a bending force on the valve fitting where it enters the stove housing, which is totally unacceptable. Instead, the flexible hose (available separately) stands the cylinder upright, puts the cylinder as much as 31 inches away, eliminates any undue stress on the fitting, and the super handy plastic base that comes with it accommodates both the tall, skinny "torch" type cylinders as well as the short, chubby "camp gas" type cylinders.
I also use my stove to cook in the garage or outside on hot days so I don't add unnecessary heat into the house in the summer. So I give the Camp Chef two thumbs up.
Anyway, here's a link to the invaluable flexible regulator (which I stumbled onto after dropping the other piece of junk on the garage floor and breaking the regulator, leading to uncontrolled gas flow out the pipe once screwed onto a cylinder!).
https://www.campchef.com/mountain-series-flexible-regulator-kit.html
67rustavenger
67rustavenger is offline
PostPosted: Sat Oct 30, 2021 7:10 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
I bought this little Coleman single burner stove this year. It's great for making coffee on a camp out early morning.
The onboard Butane canister is convenient for onboard storage. Just make sure to release the lever that activates the fuel inlet to the stove, when transporting.
The little espresso maker was a gift from my Daughter when she was stationed in Italy. Works great if you want your head to burst from the extremely strong brew! Shocked
I'm a huge fan of the White gas stoves and lanterns. They work very well. When properly maintained.
When my girls were young. I used to carry a Coleman lantern while they were tricker treating. Very Happy
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
djkeev
djkeev is offline
PostPosted: Sat Oct 30, 2021 12:28 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
I too have this stove, my main reason fr getting it was the high btu's.
Many....most? Camp stoves are anemic and take an hour to boil water!
Plus it adjusts down to the tiniest simmer flame, most stoves can't do that either!
We ave an all electric house, I keep this stove handy for use during power outages.
Dave
Ghia
Vanagon
Beetle
gt1953
gt1953 is offline
PostPosted: Sat Oct 30, 2021 5:52 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
I have one just like KTPHIL and vwmerckx. Found it at the Phoenix Park and Swap circa 1976 for a grand total of 4.00. Still works today, has cooked many meals, even have the toaster accesory. Conveted to propane, but still have the tank if needed.
72 type 1
72 Squareback
vanagonjr
vanagonjr is offline
PostPosted: Tue Nov 02, 2021 3:56 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
… You must light the flame, no auto-ignitor. .
I have one on these green ones with an igniter.
One thing I like about these is you can get any part at all. They are simple to take apart and clean it out 100%
I’ve probably had mine 30 years now, have even flown with it on trips.
Only thing I hate is green canister disposal. I have about 20 of these in my shed that I need to fill with water and cut in half to recycle.
Note when camping in Acadia Nat Park, every trash can spot has 10-15 of these sitting near by. Most of them have plenty of fuel. So I walk over pick a few up and I have fuel for the weekend for free!
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
JudoJeff
JudoJeff is offline
PostPosted: Tue Nov 02, 2021 6:16 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
Vanagonjr,
You can easily refill the canister with an adapter that costs $15.
Watch the YouTube video on how to do it. I’ve done it for years. Dumpsters are great source for empties. Last time I actually purchased one, they were under $1! (Now approaching $6 each…)
They sell a more expensive one pound bottle that is meant to be refilled.
I also use 5# and 11# bottles if I know LP use will be high, cooking for a large group.
vanagonjr
PostPosted: Tue Nov 02, 2021 9:32 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
JudoJeff wrote:
Vanagonjr,
I have seen both and the reviews of both are somewhat mixed. It seems that there have been several batches of the refillable bottles that had a defect - just guessing by the dates of reviews.
I’ll have to review this again as I’d like to refill.
cdennisg
cdennisg is offline
PostPosted: Wed Nov 03, 2021 3:20 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
vanagonjr wrote:
JudoJeff wrote:
Vanagonjr,
The refill system works OK, but all too often the seal in the top of the refilled can will start leaking. Then you end up wasting the gas inside it, as you do not want to store it that way. Gotta be careful with this stuff.
I buy partial and sometimes full green bottles at yardsales and such. Same with white gas. I have about five gallons of white gas stored away, and likely have less than ten bucks invested it it. That stuff is about $15/gallon now!
I recently bought a nice aluminum camp stove at a yard sale. It is intended/marketed towards pilots of small aircraft utilizing remote airstrips.
Kangaroo Stove. Excellent stuff.
Abscate
Abscate is offline
PostPosted: Thu Nov 04, 2021 5:08 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
JudoJeff wrote:
Vanagonjr,
You can refill some but not the disposal kind. Look for the “$10,000 fine if transported refilled “ warning label to figure out which is which.
Reason. Propane in cheap cylinders must be dry to stop corrosion. Gas BBQpropane is not dry
Fuel value of the white gas stoves far exceeds butane amd propane. We use the white gas stoves. You don’t need to carry a gallon of white gas fuel, a liter will last you a week
cdennisg
cdennisg is offline
PostPosted: Tue Nov 09, 2021 2:11 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
Abscate wrote:
JudoJeff wrote:
Vanagonjr,
They are still "refillable", just not when the safety police are watching.
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Tue Nov 09, 2021 3:50 pm    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
When we camp, we often camp, we use a Coleman stove with 2 burners and a 5 pound Propane tank. I attach a "Tree" to the tank and attach the lantern to the top of it. The "tree" has 3 ports to connect whatever suits your fancy. If we have more than a few families on these outings, we connect additional stoves to the tree!
But I truly believe any stove that has a view of the ocean within 200 feet is PRIMO! Something like this would be AWESOMW! Oh check out that "live edge"!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Craig
Craig is offline
PostPosted: Thu Nov 18, 2021 8:18 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
Century grasshopper
Abscate
Abscate is offline
PostPosted: Thu Nov 18, 2021 8:25 am    Post subject: Re: Best Car Camping Stoves and Equipment Reply with quote
Sorry to go off topic , but as a bacon lover.....
Camp and sailing bacon strategy.
Cook at home, then refrigerate. At camp, just warm it up with the eggs for one minute. No grease to clean up.
