crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1401 Location: Cincinnati, Ohio
Posted: Sat Nov 13, 2021 2:35 pm Post subject: Mounting a vise to a workbench |
I have a 6ft Husky workbench from Home Depot. The legs are of hollow steel and the leg mounting brackets are really close to the edge of the wood surface. I have a small vise that I want to install on one of the front corners. The holes of the vise fall directly in line with the steel construction below.
I am trying not to riddle this work surface but I am not sure how to mount this vise. I have thought about using lag bolts, but I'd certainly prefer to use nuts and bolts for a more secure mounting.
Does anyone have this same bench that has a vise mounted on it?
https://www.homedepot.com/p/Husky-Ready-to-Assembl.../206288247 _________________ 1963 Ragtop |
adventurebob Samba Member
Joined: August 06, 2020 Posts: 107 Location: Colorado
Posted: Sat Nov 13, 2021 2:44 pm Post subject: Re: Mounting a vise to a workbench |
That ones gonna be rough... Im not sure lags would give enough strength to use a vise as its meant to be used. Mine is mounted to a 2" oak top with steel plate under the wood. I beat the crap out of stuff in the vise so it has to be mounted really solid. |
Posted: Sat Nov 13, 2021 2:48 pm Post subject: Re: Mounting a vise to a workbench |
so far as long as I've had my VW (3 years), I've only need my vice to hold things, and not so much for beating. Not that it won't ever happen, but certainly rare _________________ 1963 Ragtop |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35730 Location: Conejo Valley, CA
Posted: Sat Nov 13, 2021 2:53 pm Post subject: Re: Mounting a vise to a workbench |
I would use a thick base on top, with another thick plate underneath, bolted through the wood bench top using bolts and large washers. It may be worth drilling it and bolting the vice to it before mounting, countersinking the bolts if needed.
That way you are not relying on the thin top for strength. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79282 Location: Sneaking up behind you
Posted: Sat Nov 13, 2021 3:53 pm Post subject: Re: Mounting a vise to a workbench |
Drill hold and add either wood blocks or some steel plate underneath to reinforce the top.
I made my own workbench and one for my son.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Sat Nov 13, 2021 4:04 pm Post subject: Re: Mounting a vise to a workbench |
I made my own bench that looks almost exactly like Glens. I pre-drilled through the top into the 2x4's. This allowed three of the four mounting points to line up over the 2x4's and I used lag bolts.
The last one I just cut the lag bolt short, and just went into the top surface. Like Crankbait, I just use it to hold stuff, rarely do I ever pound on it much. But I definitely do some light to moderate hammering from time to time. It's plenty stable for what I do.
Now if I was going all blacksmith on it, I'd probably use a plate and bolt for the last mounting point. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 32880 Location: Hot Arizona
Posted: Sat Nov 13, 2021 5:16 pm Post subject: Re: Mounting a vise to a workbench |
Glenn wrote: |
in Phoenix, I have a workbench that I put together from a kit in the early 1980s, looks somewhat like Glenn's. Even my bench vise is mounted in almost exactly the same place.
I posted to add two suggestions:
1. I securely mounted the workbench to studs behind the wallboard.Especially important when I've also mounted my bench-mounted engine stand at the end of the bench (near the bench vise).
2. I mounted my 6" bench grinder to a short piece of 2 x 4; then when I need to use my bench grinder, I set that 2 x 4 into the bench vise to secure it. I also have a bench-mount drill press bolted at the opposite end of the bench. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
Posted: Sat Nov 13, 2021 5:18 pm Post subject: Re: Mounting a vise to a workbench |
Cusser wrote: |
Glenn wrote: |
in Phoenix, I have a workbench that I put together from a kit in the early 1980s, looks somewhat like Glenn's. Even my bench vise is mounted in almost exactly the same place. |
Left handed also? _________________ Glenn
Member #1009
#BlueSquare
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18041 Location: Eugene, OR
Posted: Sat Nov 13, 2021 6:55 pm Post subject: Re: Mounting a vise to a workbench |
The jaws of my 5" vice hang over the front edge, so I can clamp long stuff vertically when desirable. It's inboard from the end of the workbench. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5395 Location: Good Hope, GA
Posted: Sat Nov 13, 2021 8:52 pm Post subject: Re: Mounting a vise to a workbench |
if your using the bench with a engine adapter, make sure the bench is stable and secure. unlike this...
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52602 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Nov 13, 2021 11:04 pm Post subject: Re: Mounting a vise to a workbench |
Sounds like a job for Mighty Putty!
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
typ914 Samba Member
Joined: October 19, 2012 Posts: 231 Location: Atlanta, Ga
Posted: Sun Nov 14, 2021 4:04 am Post subject: Re: Mounting a vise to a workbench |
Best and one of the cheapest work bench is an old commercial flush wood door. 1-3/4” thick nominal size is 36” x 80” or 84” you can find 96”one too. The core of the doors are usually made of a very dense particle board, solid. Find a door supply company in your area and ask if they have any door that are damaged or they can no longer sell. They will probably just give it to you to get it out of their way. At least that’s what we do if we have any. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8834 Location: Sunset, Louisiana
Posted: Sun Nov 14, 2021 5:09 am Post subject: Re: Mounting a vise to a workbench |
I would try to mount the vice to the top before securing the top to the legs. Use carriage bolts from the bottom and countersink them slightly so they don't foul up the legs.
I built my own bench on top of some old cabinets salvaged from my house remodel. My vice is mounted on the corner as close to the edges as I can get it so it can be used on the side or on the front. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13946 Location: White Mountains Arizona
Posted: Sun Nov 14, 2021 11:50 am Post subject: Re: Mounting a vise to a workbench |
When I mounted my Columbia on the bench I used heavy stove bolts. The fixed portion of the jaw is parrallel with bench top. This allow a square or plumb area for stuff hang down.
https://www.etsy.com/ca/listing/1012351931/vintage-columbian-d43-12-swivel-bench
It is pretty heavy duty _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1635 Location: Anderson, SC
Posted: Sun Nov 14, 2021 1:18 pm Post subject: Re: Mounting a vise to a workbench |
I just mounted my 6" Columbian last week. The base only has three holes, I guess since there's usually a table leg in the way on that corner anyway. I used long bolts and fender washers. The table is 2x2" 1/8" wall tubing with a 1/2" steel plate under the stainless top.
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Zundfolge1432  Samba Member
Posted: Sun Nov 14, 2021 4:53 pm Post subject: Re: Mounting a vise to a workbench |
Ok here’s another Columbian vise. I built the bench over 20 years ago when wood was cheap, vise came from a flea market cheap. It’s seen a lot of action
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10989 Location: Black Forest, CO
gt1953 Samba Member
Posted: Wed Nov 17, 2021 2:14 pm Post subject: Re: Mounting a vise to a workbench |
Took the time to show off mine....Columbian D 45. Was out scouting VW parts and the fellow had this sitting on the ground...asked if it was for sale, yes, picked it and a small anvil for thirty five bucks. Quite the deal.
It is mounted with the fixed jaw in parallel with the front of the bench. The bench is 2x6 sub top with 3/4 plywood on top.
72 type 1
72 Squareback
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23643 Location: NYC/Upstate/ROW
Posted: Wed Nov 17, 2021 2:38 pm Post subject: Re: Mounting a vise to a workbench |
Be careful with that COLUMBIAn free base, it was prone to fires in a Pryor life. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
KEGZ Samba Member
Joined: October 11, 2021 Posts: 288 Location: Whales Vagina
Posted: Wed Nov 17, 2021 2:52 pm Post subject: Re: Mounting a vise to a workbench |
Abscate wrote: |
Be careful with that COLUMBIAn free base, it was prone to fires in a Pryor life. |
But when that fire hits your ass, it’ll sober you up real quick.. |
