Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Sat Sep 17, 2016 12:56 pm Post subject: Ignition/Steering Lock ID T2 |
To link to this post
| Code: |
| [url=http://www.thesamba.com/vw/forum/viewtopic.php?t=663815&start=0&postdays=0&postorder=asc&highlight=]Ignition/Steering Lock ID T2[/url] |
As always thanks to all the posted information!
This should be used as reference material only. Inspect your parts to make sure they match. The information out there is sparse and the parts books leave a lot to be desired.
Let's start with the parts descriptions. Between the parts and repair manuals, it seems VW could not make up their minds on what to call these parts. So I am using the parts manual descriptions. The following parts can be found by them self's or in a number of combinations.
1. Ignition/Steering Lock Housing
2. Steering Lock
3. Ignition Starter Switch
4. Lock Cylinder with keys
IGNITION/STEERING LOCK HOUSING (steering column)
I was unable to locate part numbers for these.
Note: the later housing came with either one or two set screws to hold the steering lock in place.
1975-79 Steering lock housing with plastic cover. Note the half round and square ends on the white ignition switch.
STEERING LOCK (ignition barrel)
1968-69 Steering lock
211 905 889 - Non-locking Intermediate housing: note square portion that changes to round, this has no lock pin to engage in the steering shaft.
211 905 887 - Note: square portion that changes to round with lock pin protruding from the end of it.
1970 only Steering lock
211 905 887 A - Note: door buzzer wire connection, tapered cylinder with lock pin.
1971 Steering lock
211 905 859 B
No Pic?
1971-? Steering lock
211 905 887 C - Note: I could not find any information on this. Seen some pix of it in 1971? It is listed by Vendors as fitting 71-74?
1972-M74 Steering lock
211 905 887 D - Note: (71 to 74 ch.#164 059) will fit 1971 with some modification to the Steering lock housing.
M74-79 Steering lock
211 905 851 BH - Note: (74 from ch.#164 060 to 1979)
IGNITION STARTER SWITCH (ignition switch)(electrical part)
1968-70 Ignition switch
311 905 865 A - Three wire ignition switch
1970 Ignition switch
311 905 865 B - 70 only Four wire ignition switch with buzzer contact, non-locking column
1971-M74 Ignition switch
111 905 865 F - (71 to 74 ch.#164 059)
M74-79 Ignition switch
111 905 865 L - Note: (from 74 ch.#164 060 to 79) ignition switch note the little half round boot on the bottom
LOCK CYLINDER WITH KEYS
1968-70 Lock cylinder
211 905 855 - Note: with "L" profile keys
211 905 853 A - Note: with "L" profile keys
1971-72 Lock cylinder
211 905 855 B - Note: with "R" profile keys
1973-79 Lock cylinder
211 905 855 C - Note: with "R" profile keys
COMBINATIONS
1968-69
211 905 851 L- Steering, housing, lock, switch
67-69
211 905 851 F - Steering Housing Complete
1968-69
211 905 859 - Steering, housing, lock
1970
211 905 859 A - Steering, housing, lock
1973-74
211 905 851 AL - Steering, housing, lock, switch
1968-72
T2 Steering column decal
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10808 Location: the past
RixiesRide Samba Member
Joined: August 31, 2005 Posts: 708 Location: Stockton, CA
Posted: Sat Feb 24, 2018 12:34 pm Post subject: Re: Ignition/Steering Lock ID T2 |
Can someone please verify what year(s) this goes to?
I was told it came out of a '71 bus. Looking at the above pictures it looks like a '68-69.
I do know it won't fit a '73.
Thank you! _________________ 1973 Wild Westerner "Mr. Peabody"
1967 Beetle "Sherman"
http://s13.photobucket.com/albums/a269/RixiesRide/WW/ |
elge_b Samba Member
Joined: April 06, 2022 Posts: 2 Location: Kuna, Idaho, USA
Posted: Wed Apr 06, 2022 9:58 am Post subject: Re: Ignition/Steering Lock ID T2 |
| RixiesRide wrote: |
Thank you! |
Do you still have this part? I am in desperate need of the ignition/steering lock housing for a 69 T2. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42998 Location: at the beach in Northern Wokistan
Posted: Wed Apr 06, 2022 3:57 pm Post subject: Re: Ignition/Steering Lock ID T2 |
have you checked with Ken Madsen at thebusco to see if he has one? _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
elge_b Samba Member
Posted: Wed Apr 06, 2022 4:19 pm Post subject: Re: Ignition/Steering Lock ID T2 |
| I was able to find one. Thank you for the suggestion. |
nemobuscaptain Samba Member
