Bambergvr6 Samba Member
Joined: December 28, 2003 Posts: 134 Location: Harker Heights, Texas
Posted: Thu Feb 18, 2021 10:10 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Been working on the Bug "Chester", last week was huge.
I installed a Puma Adjustable front beam w/ caster shims, an NOS SWF Turn Signal switch/ arm, wired up the Mexi-Bug OEM electric windshield washer, installed new 185 60 15 front and 195 65 15 rear Pirelli tires, and installed my external oil cooler/ AN8 fittings/ Lines. The cooler and external filter are connected to a full flow oil pump. I had to clearance the pulley tin, but otherwise all looks same, this modification should prove out later this year when our temperatures here reach 90-100.
As for the front end, it's now 2" dropped from where it was before, front height is at 24 1/2" (floor to fender lip), the rear torsion is unmolested, sits at approx 26 1/4". I plan to lower the rear 1 to 1.5" sometime in the near future. I also modified those front shock bump-stops (trimmed half of it off), reinstalled the Bilsteins, took off the Saches oil shocks (soft ride). Enjoy!
I also noticed that my car did not have any locking tabs on the bolts for the original front beam, I can only assume that those were not installed for YOM 1974. As my car is (was) unmolested and original, original beam with tow loop on passenger side.
_________________ ## ROG ##
(aka 007)
Moore VeeDub Garage |
J-Gaz. Samba Member
Joined: November 19, 2007 Posts: 743 Location: 253 Then, Now 206.
Posted: Mon Feb 22, 2021 10:23 am Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Wow! Your Build journey is incredible!
So glad to see you've come out on top with the accidents and setbacks -
This has me thinking that I might want to re-purpose some funds and upgrade the breaks on mine.
Then address some of the comfort and style updates.
It's a beautifully done 74 in every way you've done it! _________________ 1970 Beetle | Basically Stock 1600 SP |
Frankerbauer Samba Member
Joined: April 26, 2008 Posts: 153 Location: Central Florida
Posted: Fri Feb 26, 2021 4:23 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Your Bug looks fantastic!!!
Can I ask you a couple of questions; what are you using for wax for that shine?
Is Armor Shine any good? Also, I noticed that your I-beam shims are installed on the outside, mine are installed on the inside. Is that bad?? Lastly what shocks did u install on the front when u dropped it down??
Thanks for all the help, she is beautiful!!
Frank N.
 _________________ Purple 74 Standard Project: http://www.thesamba.com/vw/forum/viewtopic.php?t=346688
Last edited by Frankerbauer on Fri Feb 26, 2021 10:24 pm; edited 1 time in total |
Posted: Fri Feb 26, 2021 7:14 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Hi, what shims are tou referrimg too? the front beam caster shims? Kamei Spoiler shims?
The front shocks are Bilstein HDs with a modified bump stop. I had Saches oil filled when the car was stock height. _________________ ## ROG ##
(aka 007)
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4943 Location: Stuck in Ohio
Posted: Fri Feb 26, 2021 8:00 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
The satin black hood and driving lights are awesome. The car is really stepping out now and wearing the rally theme in a strong way.
Like everyone else I am really glad to read that you remained healthy during the smash up. I tell my kids all the time, if you don't want to break your bike then don't ride it - anything can be fixed. This, however, might have been taking it to the extreme. Excellent display of grace and patience in the reconstruction - taking it up a level in the process. _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
L51C_75 Samba Member
Posted: Tue Aug 24, 2021 9:05 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Wow great build thread! I also have a 74 Bug and running similar suspension and wheels as you, I have a stock width adjustable beam and same sport wheels but the in 914 5.5 ET 40 size. Curious on your front shock selection of running bilstiens with the cut bump stops, how does it ride? I am have the shorter Opel GT KYBs which are pretty good the roads where I live are not great and looking for more comfortable ride. Could the stock shocks be modified in a similar manner? |
Posted: Sun May 15, 2022 7:14 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Hello all, it has been a while. Allot has happend, but lets talk about the 1974 Bug. Last year late summer i went back to all orange hood and decklid, then installed a 2110cc engine with Super Diff/ Freeway Flyer Transmission. It transformed the 74 into a serious "Orange Racer".
Well this year, in February, i pulled the 2110cc back out, Needed to go thru the engine. Reinstalled it recently, retuned and all Sycnd up. I also reinstalled the Black Hood and Decklid.
(aka 007)
radstude Samba Member
Joined: January 29, 2005 Posts: 411 Location: Lynchburg Va.
Posted: Sun May 15, 2022 8:00 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Any pictures of the orange hood? _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
2002 VW Mexican Bug 1600i |
Posted: Mon May 16, 2022 4:26 am Post subject: Re: 1974 Standard - Texas Survivor Refresh |
(aka 007)
spencerfvee Samba Member
Posted: Mon May 16, 2022 9:38 am Post subject: Re: 1974 Standard - Texas Survivor Refresh |
.......................................................................................................................wow is all i can say after all the bad luck . you had . you picked your self up and went for word . and you put your bug back together . great job . great looking bug .love it spencerfvee ps whats the dogs name ? |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79680 Location: Sneaking up behind you
Posted: Mon May 16, 2022 9:51 am Post subject: Re: 1974 Standard - Texas Survivor Refresh |
The roof rack it out of character for the look. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon May 16, 2022 1:39 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
My Dog's name is "Scarlet", she is 4 yrs old, my garage Pal and ultimate Watch Dog/ House Alarm/ VW Car alarm...
So I have had some time off, family visiting. I have had lots of time to work in the garage, So i am about to give the 74 a wash. I took the rack off, Glenn was right, it has a good look without it.
enjoy the new photos
(aka 007)
Glenn  Mr. 010
Posted: Mon May 16, 2022 1:42 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Bambergvr6 wrote: |
I took the rack off, Glenn was right, it has a good look without it. |
Love the car and highly impressed with you vision and skill.
The dog is a cutie. _________________ Glenn
Member #1009
#BlueSquare
Posted: Mon May 16, 2022 2:12 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Yes, with the Rally theme black lids really makes it! The 4 rally lights, really completes the package! Great looking Bug! _________________ 1967 VW Fastback (Past)
1971 VW Bug (Past)
1975 VW Bus (Past)
creative native Samba Member
Posted: Mon May 16, 2022 4:05 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
007 Bambergvr6, Chester looks better every time I see him. It really is amazing how far you've taken him since you found him. _________________ "The holy land is everywhere." ~ Black Elk
1979 Westfalia P27, California FI emissions spec. 100% VW fleet: '79 Westfalia, 2019 VW Atlas SEL Premium (Terra Brown/Shetland Beige), 2005 Passat GLX.
Last edited by creative native on Mon May 16, 2022 4:10 pm; edited 1 time in total |
Rome Samba Member
Joined: June 02, 2004 Posts: 10587 Location: Pearl River, NY
Posted: Mon May 16, 2022 4:08 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Well this year, in February, i pulled the 2110cc back out, Needed to go thru the engine. Reinstalled it recently, retuned |
What were the symptoms on the engine so that you needed to take it back out? Did you completely disassemble it? What are the spec's on it? Just like the rest of the '74, the engine looks very cleanly put together. |
Posted: Mon May 16, 2022 5:19 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
A couple things, it was blowing oil out during hard runs, started running rough, like on 3 cylinders, ran a compreasiin check, all apprix 155 psi, ended up being a fowled/ bad NGK spark plug and one pinched output breather hose coming from the VS breather Tube to air driver's side carb filter.
I added a 2nd crankcase breather on the fuel pump flange and also found that my aftermarket (Chrome) oil dipstick was not correctly marked, it qppears i was also running the car about 1/2 liter too full. I bought a new dipstick and checked it with my original 74 stick, the new one ia perfect, the chrome, well it needs to be re-indexed, to properly show the oil level.
Engine Back in the car, have logged more than 50 miles over past couple of days, (highway speeds and in town driving) and no more oil pushing out.
Very happtly.
* What is up Duane, i see you have a Bay Window Bus now... So envious! Looks choice my friend. _________________ ## ROG ##
(aka 007)
Posted: Thu Apr 27, 2023 8:13 pm Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Well it has been about a year since I last reported in on this Thread. I figured it is time to provide an update. Two of the biggest pieces of news are the new Seats and the Steering wheel. Swapped out the 73 Sport Bug Seats for a pair of Scat Procar 90s in Black Vinyl and i now have a 1977 Scirroco Sport Steering wheel. But i have a few other small items that have been changed. I have added a Vintage Speed HTE Rallye Gas Pedal, sourced out some chrome overriders, changed the "D" plate in the rear to a "USA", now running an LED H4 bulb in my headlamps. All of this makes for a Fantastic driving Bug (absolutely live driving this car), now sporting a vintage Super Bug decal on the rear window.
Last year in November, I took her to Dade City, Florida (I live in Texas, but a Florida native), for Bug Jam 2022. Camped there four 3 nights, Competed in the Modified Late Model Bug Class, had a Vendor display setup and participated in the Poker Run. What a great time, great friends and people. Met so many new friends. I took 3rd in the class and won $100 for the worst hand.
I have a new Bug that i have been working on, will likely be sharing that soon, but in a different forum, as it is a 1964.
Enjoy the pictures!
(aka 007)
nbvolks Samba Member
Posted: Fri Apr 28, 2023 7:54 am Post subject: Re: 1974 Standard - Texas Survivor Refresh |
Bambergvr6 wrote: |
I think you may have posted this elsewhere, but now I can't find it. Where did you get the brackets to mount your driving/fog lights? I also have a 74, so I need a way to securely mount them to the mount them to the bumper, since the supports aren't an option, like earlier cars. |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7508 Location: Houston, Texas
Posted: Fri Apr 28, 2023 7:57 am Post subject: Re: 1974 Standard - Texas Survivor Refresh |
I like what you've done. I have a 64 as well. _________________ www.vwnos.com [email protected]
