Hydraulic or not Hydraulic, how do I tell.
Slowroller63
Slowroller63 is offline
PostPosted: Mon Oct 03, 2022 6:57 pm    Post subject: Hydraulic or not Hydraulic, how do I tell. Reply with quote
Thank you for reading this, I hope it in the right section.
I have a 73 bus with a 2.0 GB motor that was rebuilt 10 years ago with no records.
Trying to adjust valves.
TDC #1 cylinder after adjusting to .006 I can pull the lifter away another 1/4 inch and it will snap back once I let go.
It feels like a Hydraulic lifter.
Rotating the motor 180* CLW #2 after setting to .006 they don't budge when trying to pull the lifter away.
A reliable source recommended I should adjust the ones that spring back like a hydraulic lifter and the ones that don't move I should adjust like the standard ones.
What do you think?
Grateful for any input even if it's sarcasm.
Thank you for any help.
Wildthings
Wildthings is offline
PostPosted: Mon Oct 03, 2022 7:16 pm    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
Sounds like they are hydraulic to me. Determining the point of contact can be tricky and can feel very different from one valve to another, and can even feel very different if you adjust the same valve twice. You need to turn the adjusting screw only with your fingers, back it off two+ turns to start with and then without applying pressure against the lifter slowly turn the screw in using only your fingers feeling carefully for the point of contact, which can be very subtle or very firm. Once you are sure that you have found the point of contact, turn the screw in another two turns or whatever amount someone else has convinced you has the correct mojo. It can help to do the two valve on one side and then running the engine a bit so those two valve can self adjust before doing to two valve on the other head.
The engine doesn't need to be either cold or hot to adjust hydraulic lifters, just at a temperature you won't burn yourself.
timvw7476
timvw7476 is offline
PostPosted: Mon Oct 03, 2022 9:59 pm    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
the true hydraulic VW set up features a spacer on the rocker pivots, can't miss it, that tells you if it's factory hydraulics. also, just pop a valve cover, engine cold, pop the distributor cap, rotate the alternator pulley nut till the rotor points at where the #1 tower on the cap should be. Check the #1 valves. If they are both .006" loose, that's a solid lifter engine.
You can't touch the lifters with the engine assembled, that's the rocker arm you are manipulating. : ) good luck with it.
Were it mine, I'd take the lazy path. Park it for two-three weeks, no starts. Then go out & start it up, if you hear lifter clatter for 40-300 seconds, it's a hydro lifter engine. They bleed done pretty bad. <<not sarcasm.
Wildthings
PostPosted: Tue Oct 04, 2022 2:51 am    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
On a properly maintained engine the lifters will not bleed down if left for weeks.
Abscate Premium Member
Abscate is offline
PostPosted: Tue Oct 04, 2022 3:26 am    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
That’s why the typically bleed down.
Laughing
mikewire Premium Member
mikewire is offline
PostPosted: Tue Oct 04, 2022 8:02 am    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
It's fairly easy to check and verify.
Grab a set of Viton pushrod seals. Pull the valve cover, rocker assembly, one pushrod and pull the pushrod tube out. Grab a magnetic wand a fish out the lifter and you'll be able to verify and check the condition.
-Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe 221(5) w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Classifieds Feedback
Slowroller63
PostPosted: Tue Oct 04, 2022 9:25 pm    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
Thank you all, they are Hydraulic.
The loud knocking is gone, the last guy that adjusted them must have thought they were standard.
I'm on the road tomorrow starting in Iowa heading to Calif.
Someone said there was form here that I could reach out to some help if I break down.
If you know please leave a link.
Thanks again for your emails.
joe
SGKent Premium Member
SGKent is offline
PostPosted: Wed Oct 05, 2022 10:39 am    Post subject: Re: Hydraulic or not Hydraulic, how do I tell. Reply with quote
joe
there used to be a group of air cooled people who could help but that data is so old - 15-20 years so it is unreliable. If you break down you best have a good towing insurance and money in the back to rent a U-haul, dolly and take it the rest of the way. I would think renting U-haul headed to CA would not be that bad because U-haul struggles to get items back to California these days with the outflow of people.
