Superdiff in a daily driver.
Bad bug
Bad bug is offline
PostPosted: Wed Dec 07, 2022 1:42 pm    Post subject: Superdiff in a daily driver. Reply with quote
As the heading states is there anyone here running one in a true 5 days per week daily driver car. The car is IRS.
Alstrup
Alstrup is offline
PostPosted: Wed Dec 07, 2022 2:34 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Not me, but I have a couple of customers who do.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
UK Luke 72
UK Luke 72 is offline
Not quite daily but I did the Ray Valero mods to mine and it has been fine on the street. Some longer journeys too
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
Bad bug
Bad bug is offline
PostPosted: Wed Dec 07, 2022 2:38 pm    Post subject: Re: Superdiff in a daily Reply with quote
Thanks for the replies so far, Luke, how did you find the diff to be, is it hard to drive the car on the street.[/list]
UK Luke 72
PostPosted: Wed Dec 07, 2022 2:43 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
To be honest I haven't found it any different in terms of how it feels.
When I've launched the car in damp conditions, both wheels spin whereas before one would spin up. Not sure if the same would be true if I launched it hard on dry tarmac but I'm not trying to break anything.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Dec 07, 2022 2:44 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
I had a Superdiff in my daily for 10 years and put over 125,000 miles on it.
Changed the gear lube and found bits in it.
Took the transaxle apart and found the spider gears have seen better days.
Replaced it with a ZF LSD.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
petrol punk
petrol punk is offline
PostPosted: Wed Dec 07, 2022 2:48 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
If the guy who I bought my IRS tranny from is to be believed it has a super diff. I've never had an issue or really noticed any difference from the stock diff in my other splitcase trans oval.
36hp '56 European DeLuxe oval
'70 bug 1835cc
Bad bug
Bad bug is offline
PostPosted: Wed Dec 07, 2022 2:53 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Thanks for all the replies, Glenn, a limited is not in rhe cards for me at the moment. Luke, are you running a swing axle backend car?
UK Luke 72
PostPosted: Wed Dec 07, 2022 3:01 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Yes
madmike
madmike is offline
PostPosted: Wed Dec 07, 2022 3:03 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
The Swing axle super diff were the problematic ones Wink Old IRS supers no issues, Glenns was where? made in Brasil?
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Mr. 010
Glenn is offline
PostPosted: Wed Dec 07, 2022 3:04 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Yes.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bad bug
Bad bug is offline
PostPosted: Wed Dec 07, 2022 4:55 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Glenn did your brazilian superdiff cover look like a stock diff cover. I had a look at weddle site and saw this.
https://weddleindustries.com/products/5160/5160
Saw this also and thought it was the cost of and LSD. Hell, price is on it's way up.
https://weddleindustries.com/products/5162/5162
Mr. 010
Glenn is offline
PostPosted: Wed Dec 07, 2022 5:03 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
This is the side cover on my tranny. BTW, i have a Berg 5.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
madmike
madmike is offline
PostPosted: Wed Dec 07, 2022 5:16 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Glenn has a Factory HD Aluminium cover, Just as strong as some aftermarket ones Wink
RickS
RickS is offline
PostPosted: Wed Dec 07, 2022 6:41 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
That Aluminum Super Diff is made by Dave Folts. It is really nice, uses 091 side and spider gears. Call Dave directly if you want one. I bought one from him last month for SIGNIFICANTLY LESS money then Weddle charges. The only issue is Weddle is out of stock on the HD spider gears for it. I called last week for an update and they told me they expected them last week, so should be soon.
Clatter
Clatter is offline
PostPosted: Wed Dec 07, 2022 8:00 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Doesn’t it have less strength now that it’s been machined down like that?
That’s done for weight savings, or maybe looks? Think
I remember the old Transform shop used to do that…
Bus Motor Build
It does not exist!
Clatter
Clatter is offline
PostPosted: Wed Dec 07, 2022 8:08 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
A super diff won’t drive any different than a regular 2-spider diff.
Unless it’s a cheap POS and breaks, locking things up,
(Like a lot are nowadays, especially swing axle).
It’s not a TBD or LSD or spool…
Late Vanagons came stock with a 4-spider a.k.a. “Super” diff.
Bus Motor Build
It does not exist!
Mr. 010
Glenn is offline
PostPosted: Wed Dec 07, 2022 8:20 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
A Super Diff is still an "open" diff. It just spreads the load across 3 spider gears instead of just 2.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Clatter
Clatter is offline
PostPosted: Wed Dec 07, 2022 9:15 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
Razz
Ya,
I hear ya!
Supposed to be 4 spiders,
But with the quality of most,
One’s just along for the ride..!
Bus Motor Build
It does not exist!
AlteWagen
Troll
AlteWagen is offline
PostPosted: Thu Dec 08, 2022 3:45 pm    Post subject: Re: Superdiff in a daily driver. Reply with quote
I think there are two different part groups that are being discussed
-Gear carrier/differential housing
-Spider gear assembly
The common term 'super diff' refers to a HD gear carrier which is where the ring gear bolts to and houses the spider gear assembly. This HD casting if being used on the street needs to be drilled so there is proper oil flow over the spider gears.
Here is a comparison pic. Note how open the stock carrier is which allows the needed splash oiling on the spider gears.
Super diff shown with oiling mods
The spider gear assembly in stock form only uses two spider gears. The 4 spider gear assembly or more commonly known as the 'beef a diff' helps spread the load to more gear teeth compared to stock set up. While this 4 spider setup is the usual upgrade when installing a HD gear carrier it can also be used in the factory carrier for an upgrade as well.
Stock 2 gear setup (swing shown)
Beef a diff
Official Dual Carb Thread
