1959 Mango walkthru metal rehab.
Page: Previous  1, 2, 3 ... , 16, 17, 18  Next
Burlyhammer
Burlyhammer is offline
PostPosted: Sat Oct 29, 2022 3:37 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
Huetti_1989 wrote:
Nice to see a Update again!
Do you habe a idea how to prevent the patina rust? And how to prevent the underside from rust?
-Christian
We used phosphoric acid to prep the bare metal, then silver master coated everything prior to any painting underneath. We used the phosphoric acid to prep everything else. We plan to use self etching primer over that before painting. I’m hoping that will do the trick.
Burlyhammer
PostPosted: Fri Dec 02, 2022 1:22 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
I've been pecking away with the small parts blasting and painting as I go. I also started cleaning the exterior. I now have the inside ready for primer, and color where color should be. The next post should be a good one:
ddutch
ddutch is offline
PostPosted: Sun Dec 04, 2022 10:34 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
I like what you did with that door, it came out very nice with the original paint preserved and just the right amount of patina. Very curious to the outcome of the paintjob for the interior.
braddick
braddick is offline
PostPosted: Mon Dec 05, 2022 7:27 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
Great progress mate
Looking forward to the next update
Just painted the repair section on mine, took a bit to get the match right but think I’ve nailed it now
Cheers
Burlyhammer
PostPosted: Wed Dec 14, 2022 2:14 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
My goal is to keep as much original paint as possible. The door still needs some work but is getting there. The plan for the interior is to be clean. I think it’s going to be pretty nice.
Thanks ddutch!
Burlyhammer
PostPosted: Wed Dec 14, 2022 2:15 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
braddick wrote:
Great progress mate
Cheers
Your bus is looking great. You’ve done an awesome job!!!
Thanks braddick!
Burlyhammer
PostPosted: Wed Dec 14, 2022 2:20 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
The inside is painted! I used self etching primer over the Mastercoat and then covered that with the Mango. My paint gun gave up the ghost after the primer so I had to go to Harbor Freight and bought the $25 special. I’m not a painter and it’s obvious if you look closely. There are a bunch of runs that need to be wet sanded out. But it’s green now!
von_hansel Premium Member
von_hansel is offline
PostPosted: Wed Dec 14, 2022 8:31 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
The best thing to happen to this bus was finding you.
Your work is inspirational.
I look forward to seeing the first driving pic/ video Very Happy
Mugatu wrote:
KWZ
KWZ is offline
PostPosted: Wed Dec 14, 2022 12:29 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
This thread is so porny
'57 sunroof Standard
'63 15 window
'65 Westy SO44
'67 13 window
Huetti_1989
Huetti_1989 is offline
PostPosted: Thu Dec 15, 2022 1:21 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
looks good and unbelievable, unreal with that nice Paint!
-Christian
My 1957 SC
http://www.thesamba.com/vw/forum/viewtopic.php?t=605363&postdays=0&postorder=asc&start=0
MY 1967 Sparsamba:
https://www.thesamba.com/vw/forum/viewtopic.php?t=757182
My 1952 Panel:
https://www.thesamba.com/vw/forum/viewtopic.php?t=797388
My 1954 Deutsche Bundespost:
http://www.thesamba.com/vw/forum/viewtopic.php?t=621802
My 1961 SO34:
https://www.thesamba.com/vw/forum/viewtopic.php?t=716285
My 1991 Westfalia California:
http://www.thesamba.com/vw/forum/viewtopic.php?t=650751
Burlyhammer
PostPosted: Thu Dec 15, 2022 1:19 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
My friend Matt, the owner of this bus bought it from a junkyard after it sat there for years being picked apart. I am so glad he rescued it and decided to put it back on the road.
Thanks von hansel!
Burlyhammer
PostPosted: Thu Dec 15, 2022 1:20 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
Laughing
Burlyhammer
PostPosted: Thu Dec 15, 2022 1:23 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
-Christian
The color looks awesome. I can't wait to roll it out into the sunlight. Seeing the inside painted is extremely motivational!
Thanks Christian!
P.S your truck is absolutely one of my all time favorites!
edgood1
edgood1 is offline
PostPosted: Sat Dec 17, 2022 5:15 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
This is another epic build. I can wait to see it again!
'87 Syncro :: Subaru eng
'63 Samba Conversion ::(photo album)
'65 Westfalia
'65 Bug
Huetti_1989
PostPosted: Sat Dec 17, 2022 7:10 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
Burlyhammer wrote:
-Christian
Thanks Christian!
What is the plan on the outside? How did you stop that surface rust growing?
I am always come back here to watch your build threads!
-Christian
My 1957 SC
MY 1967 Sparsamba:
My 1952 Panel:
My 1961 SO34:
Burlyhammer
PostPosted: Mon Jun 19, 2023 12:53 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
A lot has happened since this thread was last updated. I found out that my friend Matt that rescued this bus from the junkyard, as well as many other buses over the years from scrapyards, junkyards, fields, and sometimes driveways was not doing well. Unfortunately he passed away in January. He was a good friend and a bus guy through and through. He will be missed.
When we talked about the bus last summer around the time I was finishing the majority of the metal work he had asked me to finish the bus, and I agreed to it. We talked about how he wanted it to be, and that's the direction we were going in. After he passed I found out that he had left the bus to me, so I plan to finish the bus the way he wanted it (with the exception of the safaris). It has been slow going since the beginning of the year, but my son and I have been picking away at it, and are getting near the end of the project. I did not take as many pictures as I usually do, but it is moving forward. I know Matt is keeping an eye on us and I hope he approves. The pictures are out of order a little bit, but you will get the idea.
Whenever I updated the thread Matt would text me and say he saw his bus on Mango TV, so here is the Mango TV update:
When I took the Sportwagen cutout off of the bus and cleaned off the primer, I saw this dealer badge. It is from Key West, FL. The port of entry on the M Code plate is Miami so I am guessing this is where it was sold new.
Walk Thru KO
Walk Thru KO is offline
PostPosted: Mon Jun 19, 2023 1:10 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
I'd say you need to go ahead and give this bus a name - Matt. Sorry for the loss of your friend
Stocknazi
Stocknazi is offline
PostPosted: Mon Jun 19, 2023 3:24 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
Curious how difficult it was to re-bend the edge of the decklid after replacing the inner structure?
WANTED:
Thomas Jefferson
Bills85Westy
Bills85Westy is offline
PostPosted: Mon Jun 19, 2023 10:41 pm    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
Sorry to hear about your friend. Losing people close to us always sucks.
You are doing that bus justice and Matt will know it.
89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L
ryans65
ryans65 is offline
PostPosted: Tue Jun 20, 2023 5:24 am    Post subject: Re: 1959 Mango walkthru metal rehab. Reply with quote
My condolences-
You are making your friend proud by the work you've put into this thing! Keep the hammer down!
Page 17 of 18
